SS32
SS310
THRU
3.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
20 to 100 Volts
CURRENT
3.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
DO-214AA(SMB)
.155(3.94)
.130(3.30)
.083(2.11)
.075(1.91)
MECHANICAL DATA
.185(4.70)
.160(4.06)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.093 grams
.012(0.31)
.006(0.15)
.096(2.44)
.083(2.13)
.008
MAX.
(.203)
.220(5.59)
.200(5.08)
.050(1.27)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SS32
SS33
SS34
21
30
40
28
40
SS35
At TL=100 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
SS38
SS39
80
56
80
90
63
90
60
42
60
80
0.55
0.85
0.70
0.2
Ta=100 C
10
-65
+125
-65
-65
+150
SS310
UNITS
100
70
100
V
V
V
A
3.0
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 3.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJL (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
SS36
50
35
50
+150
A
V
mA
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (SS32 THRU SS310)
FIG.2-TYPICAL FORWARD
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
40
60
80
100
120
140
160
180
200
LEAD TEMPERATURE ( C)
PEAK FORWAARD SURGE CURRENT,(A)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
~S
S
36
~S
S
31
~S
S
32
38
10
4
S3
S3
SS
S
S
0.5
SS
5~
2 ~
1.0
10
SS
3
SS
1.5
INSTANTANEOUS FORWARD CURRENT,(A)
2.0
34
50
2.5
3
SS
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
100
.01
80
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
60
8.3ms Single Half
Tj=25 C
Sine Wave
40
JEDEC method
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
1
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
700
600
500
400
300
200
10
1.0
Tj=75 C
.1
Tj=25 C
100
.05
.1
.5
1
REVERSE VOLTAGE,(V)
5
10
50
100
.01
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SS34-SMB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25563
- 300+0.20738
- 1200+0.18058
- 3000+0.14211
- 国内价格
- 1+0.24310
- 200+0.15840
- 1500+0.13640
- 3000+0.12100
- 国内价格
- 20+0.27887
- 200+0.22623
- 600+0.19700
- 3000+0.15504
- 12000+0.13984
- 18000+0.13163
