1N5819WT
Plastic-Encapsulate Diodes
SCHOTTKY BARRIER DIODE
SOD-523
FEATURES
Low Forward Voltage Drop
Guard Ring Construction for Transient Protection
Low Reverse Recovery Time
Low Reverse Capacitance
MARKING: S4
S4
MAXIMUM RATINGS ( Ta=25℃ unless otherwise noted )
Symbol
Parameter
Value
Unit
40
V
RMS Reverse Voltage
28
V
Forward Continuous Current
350
mA
IFSM
Non-Repetitive Peak Forward Surge Current@t=8.3ms
2
A
PD
Power Dissipation
150
mW
Thermal Resistance From Junction To Ambient
667
℃/W
Tj
Junction Temperature
125
Tstg
Storage Temperature
-55~+150
VRRM
Peak Repetitive Reverse Voltage
VRWM
Working Peak Reverse Voltage
VR
VR(RMS)
IFM
RΘJA
DC Blocking Voltage
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Reverse voltage
Reverse current
Forward voltage
Total capacitance
Reverse recovery time
www.slkormicro.com
Symbol
V(BR)
IR
VF
Ctot
trr
Test conditions
IR=100μA
Min
Typ
Max
40
Unit
V
VR=30V
5
VR=20V
2
VR=10V
1
IF=1mA
0.27
IF=5mA
0.32
IF=20mA
0.37
IF=200mA
0.6
μA
V
VR=0V,f=1MHz
50
pF
IF= IR=200mA, Irr=0.1×IR, RL=100Ω
10
ns
1
1N5819WT
Typical Characteristics
Forward
1000
Characteristics
Reverse
1000
Characteristics
(uA)
Ta=100℃
100
REVERSE CURRENT IR
FORWARD CURRENT
IF
(mA)
Ta=100℃
Ta=25℃
10
100
10
Ta=25℃
1
1
100
200
300
FORWARD VOLTAGE
400
VF
500
0.1
600
10
REVERSE VOLTAGE
(mV)
Capacitance Characteristics
50
VR
40
(V)
Power Derating Curve
200
Ta=25℃
(mW)
150
PD
40
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
f=1MHz
30
50
10
10
15
REVERSE VOLTAGE
www.slkormicro.com
VR
25
50
75
AMBIENT TEMPERATURE
(V)
2
100
Ta
125
1N5819WT
SOD-523 Package Outline Dimensions
'LPHQVLRQV,Q0LOOLPHWHUV
0LQ
0D[
0.770
0.510
0.500
0.700
0.250
0.350
0.080
0.150
0.750
0.850
1.100
1.300
1.500
1.700
0.200 REF
0.010
0.070
7° REF
6\PERO
A
A1
b
c
D
E
E1
E2
L
SOD-523 Suggested Pad Layout
www.slkormicro.com
3
'LPHQVLRQV,Q,QFKHV
0LQ
0D[
0.020
0.031
0.020
0.028
0.010
0.014
0.003
0.006
0.030
0.033
0.043
0.051
0.059
0.067
0.008 REF
0.001
0.003
7° REF
很抱歉,暂时无法提供与“1N5819WT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07884
- 500+0.06318
- 3000+0.05098
- 6000+0.04580
- 24000+0.04126
- 51000+0.03878
- 国内价格
- 50+0.07400
- 500+0.05870
- 3000+0.04590
- 6000+0.04080
- 24000+0.03640
- 国内价格
- 1+0.19360
- 200+0.06446
- 1500+0.04026
- 3000+0.03212
