TXC CORPORATION
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD TSX 2.5 x 2.0
NOMINAL FREQ.
26.000000MHz
TXC P/N
OZ26030001
REVISION
S1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER
CONFIRMATION
(Singnature)
(Date)
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
(for glass crystal only:Pb used in sealing glass material is exempt from EU directive)
FMT-DOC024 VER.G
TXC confidential and proprietary document
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
SMD TSX 2.5 x 2.0
NOMINAL FREQ.
26.000000MHz
TXC P/N
OZ26030001
REVISION
S1
PE/RD
Robin Huang
QA
MFG
Alex Huang
Rick Lo
4-Aug-17
NOTE:
(1) The green product standard set by TXC is based upon the international standards. Related information is publicly
described on the TXC's Website, and updated regularly. The document is compliant with the latest green product
quality system directives at the time.
(2) Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3) Revision "Ax" is production ready. PE, QA and MFG's approval required.
MSL:Level 1
RoHS Compliant
FMT-DOC024 VER.G
TXC CORPORATION
Rev
Revise page
S1
N/A
FMT-DOC024 VER.G
TXC P/N:
Revise contents
Initial released
OZ26030001
S1
REVISION:
PAGE:
1
Date
Ref.No.
Reviser
4-Aug-17
N/A
Xiaoyan Jiang
TXC CORPORATION
TXC P/N:
OZ26030001
S1
REVISION:
PAGE:
2
■ CRYSTAL ELECTRICAL SPECIFICATIONS
Standard Atmospheric Conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature:
25±10℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measurement Equipment
Electrical characteristics measured by S&A 250B or equivalent.
Crystal Cutting Type
The crystal is using AT CUT (thickness shear mode)
Unit Weight:
0.0135 g / piece(TYP), 40 ± 2 g /3 kpcs( regardless of tape weight )
Parameters
Symbol
Electrical Spec.
Min.
Typ.
1
Nominal Frequency
2
Oscillation Mode
3
Load Capacitance
4
Frequency Tolerance
5
Frequency Stability Over Operating
Temp. Range( Reference 25°C )
-12
6
Operating Temperature
-30
7
Frequency drift after reflow
-2
8
Aging
FL
26.000000
Fundamental
CL
7
Max.
Condition
Units
MHz
±10
pF
ppm
25℃ ± 3℃
10
ppm
-30 to +85°C
105
2
ppm
After two reflows (0.5hr
freq. drift subtract
168hr freq. drift)*
±0.7
ppm
first year at 25℃ ± 3℃
±1.4
ppm
2 year at 25℃ ± 3℃
±2.5
ppm
5 years at 25℃ ± 3℃
±5.0
ppm
10 years at 25℃ ± 3℃
DL
10
50
100
μW
ESR
50
Ω
Spurious Mode Resistance
500
Ω
12
Q Factor
Q
7500
13
Insulation Resistance
500
MΩ
at DC 100V
14
Storage Temperature Range
-40
105
15
Pulling Sensitivity
TS
13.5
16.5
ppm/pF
16
Full Cycle Temperature Hysteresis
-0.5
0.5
ppm
9
Drive Level
10
Equivalent Series Resistance
11
FMT-DOC024 VER.G
±500 KHz
Note 1
TXC CORPORATION
TXC P/N:
OZ26030001
S1
REVISION:
PAGE:
17
5℃ Small Cycle Temperature
Hysteresis
-0.05
0.05
ppm
Note 2
18
Full Cycle Frequency Stability Slope
-50
50
ppb/℃
Note 3
19
5℃ Small Cycle Frequency Stability
Slope
-50
50
ppb/℃
Note 3
Inflection Point
Ti
29
30.5
32
21
Room Temp
To
30.5
S curve 3 order curve fitting
coefficient
(T0=30.5℃)
C1
-0.4
-0.25
-0.1
22
C2
-4.5
e -ppm/℃2
C3
8.7
9.85
11
e5-ppm/℃2
ppm/℃
4
3
Ta=-40℃~85℃ per
1℃
Note 1 Temp.range:-30℃ to 85℃ for each 1℃(Temp.rate:~1.0℃/min)
Test flow:25℃(1)->-30℃->85℃->25℃(2)(25℃(1)freq.drift Subtrace 25℃(2)freq.drift)
Note 2 Temp.range:-30℃ to 85℃ for each 0.5℃(Temp.rate:~1.0℃/min)
Test flow:any 5℃ cycle(ex.25℃(1)->-30℃->25℃(2),25℃(1) freq.drift subtract 25℃(2) freq.drift)
Note 3 Ta=-30℃ to 85℃ for each 1℃(Temp.rate:~1.0℃/min)
(difference from fifth-order curve fit)
■ ELECTRICAL SPECIFICATIONS(DLD)
Electrical Spec.
Parameters
Symbol
Condition
Min.
Typ.
Max.
Units
1
DLD
2.5
Ω
2
FDLD
3.5
ppm
3
DLDH2
1.5
Ω
4
FDLDH
0.7
ppm
FMT-DOC024 VER.G
Drive Level
10nW~100uW Step
Ratio is sqrt 10
TXC CORPORATION
TXC P/N:
OZ26030001
REVISION:
S1
PAGE:
4
■ NTC THERMISTOR ELECTRICAL SPECIFICATION
Parameters
1
Symbol
Resistance (25 ℃)
Electrical Spec.
Min.
Typ.
Note
Units
Max.
100k ± 1%
Ω
2
B-Constant (25-50 ℃)
4250 ± 1%
K
The B constant is
calculated using the
zero-power resistance
values measured at
25℃ and 50℃
3
Size
±1
Note 1 The B constant is calculated using the zero-power resistance values measured at 25℃ and 50℃
■ DIMENSIONS
■ PIN FUNCTION
Symbol
Pin 1
XT1
Function
XTAL Terminal 1
Pin 2
RT2
Thermistor Terminal 2
Pin 3
XT2
XTAL Terminal 2
Pin 4
RT1
Thermistor Terminal 1
Note: Pin 2 is connected to the metal lid and thermistor
Pin 4 is connected to the thermistor only
■ BLOCK DIAGRAM
Note: RT2 shall be connected to GND is recommended
■ SUGGESTED LAYOUT
Unit:mm
FMT-DOC024 VER.G
Unit:mm
TXC CORPORATION
OZ26030001
TXC P/N:
S1
REVISION:
5
PAGE:
■ SUGGESTED REFLOW PROFILE
Note : Total Time: 200 sec. Max., Solder Melting Point: 220°C
■ MARKING
T□□□
TXC Symbol
Pin 1 Index
Frequency
ex:26.000000 MHz=260
Lot Code
Date Code
Production Control Code
DATE CODE
MONTH
JAN
FEB
2005 2009 2013 2017 2021
A
B
C
2006 2010 2014 2018 2022
N
P
2007 2011 2015 2019 2023
a
b
2008 2012 2016 2020 2024
n
p
YEAR
MAY
JUN
JUL
AUG
SEP
OCT
NOV
DEC
D
E
F
G
H
J
K
L
M
Q
R
S
T
U
V
W
X
Y
Z
c
d
e
f
g
h
j
k
l
m
q
r
s
t
u
v
w
x
y
z
MAR APR
Note: This date code will be cycled every four years
FMT-DOC024 VER.G
TXC CORPORATION
TXC P/N:
OZ26030001
REVISION:
S1
■ PACKING :
DIMENSIONS
A
B
C
D
E
F
G
H
1.15
2.70
2.25
4.00
8.00
4.00
1.55
1.75
±0.05 ±0.05 ±0.05 ±0.10 ±0.20 ±0.10 ±0.05 ±0.10 (UNIT:mm)
REMARK :
DIMENSIONS
L
178
±1
FMT-DOC024 VER.G
L1
60.2
±0.5
W
11.5
±0.2
W1
8
+1/-0
Standard Reel Quantity is 3,000 pcs per
(UNIT:mm)
PAGE:
6
TXC CORPORATION
TXC P/N:
OZ26030001
S1
REVISION:
PAGE:
■ STRUCTURE ILLUSTRATION
Crystal Enclosure Seal : Seam Welding
Pin4
Pin3
5
3
Pin1
Pin2
1
2
4
6
Pin3
Pin4
Pin2
Pin1
7
No.
COMPONENTS
1 Lid
MATERIALS
Metal (Fe+Co+Ni)
FINISH/SPECIFICATIONS
2
Base (Package)
Ceramic (Al2O3) + Kovar
Alumina Ceramics
(Fe+Co+Ni) + Ag/Cu
3
4
5
6
7
Crystal Blank
Conductive Adhesive
Electrode
Solder
Thermistor
SiO2
Ag
Noble Metal
Sn
Al2O3, Ag, Ni
FMT-DOC024 VER.G
Silicone Resin
7
TXC CORPORATION
TXC P/N:
OZ26030001
REVISION:
S1
PAGE:
8
■ RELIABILITY SPECIFICATIONS
1. Mechanical Endurance
Test Item
No.
Drop
Test
1.1
1.2 Mechanical Shock
1.3 Vibration
Test Methods
150 cm height, 3 times on concrete floor.
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5 msec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20 G
Sweep time
20 minutes
Reference
JIS C6701
MIL-STD-202
MIL-STD-883
Perpendicular axes each test time 4 Hrs
(Total test time 12 Hrs)
1.4 Gross Leak
Standard sample for automatic gross leak detector
Test pressure: 2 kg / cm2
1.5 Fine Leak
Helium bombing 4.5 kg/ cm2 for 2 Hrs
1.6 Solderability
Temperature
245℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
MIL-STD-883
MIL-STD-883
solvent ( 1 : 4 )
2. Environmental Endurance
No.
2.1
Test Item
Resistance To
Soldering Heat
Test Methods
Pre-heat temperature
125℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5℃
Test time
10 ± 1 sec.
2.2
High Temp. Storage
+ 125 ℃ ± 3 ℃ for 500 ± 12 Hrs
2.3
Low Temp. Storage
- 40℃ ± 3℃ for 500 ± 12 Hrs
Total 100 cycles of the following temperature cycle
2.4
Thermal Shock
2.5
High Temp&Humidity
FMT-DOC024 VER.G
Reference
MIL-STD-202
MIL-STD-883
MIL-STD-883
85℃ ± 3℃, RH 85% , 500 Hrs
JIS C5023
很抱歉,暂时无法提供与“OZ26030001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.41210
- 10+1.10733
- 30+0.97665
- 100+0.81368
- 500+0.74110
- 1000+0.69758
