CRYSTAL UNIT
YSX531SL
Applications
Features
‧Industrial Control
Consumers.
‧Dimensions:5.00 x 3.20 x 0.90 mm.
‧High precision and high frequency stability.
‧Standard Frequency: 8 to 54MHz
‧Extremely good for reducing EMI effect.
Specifications
8 to 54 MHz
Standard Frequency
Vibration Mode
AT Fundamental
10pF, 20pF, or specify
Load Capacitance
Frequency Tolerance (at 25 ℃ )
±10ppm, ±20ppm, or specify
Frequency Versus Temperature Characteristics
±20ppm, or specify
-20~+70℃,-40~+85℃,or specify
Operating Temperature
Storage Temperature
-55~+125℃ or specify
Shunt Capacitance
5 pF Max.
1~200μWMax. (100uW typical)
Level of Drive
Aging (at 25 ℃ )
±3ppm/year Max.
Equivalent Series Resistance(ESR)
Fundamental
8 ~ 12 MHz
12 ~ 25 MHz
25 ~ 54 MHz
60~80 Ω Max.
40~60 Ω Max.
30~40 Ω Max.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
0.4
5 .0± 0. 15
G ND
3
Marking
To p V i e w
GN D
2
1
S i de Vi e w
2
To p Vi e w C r y s t a l C o n n e c t io n
0 .9± 0. 15
1
3
4
3 . 2 ±0. 1 5
4
2 .0
1 .7
2 .0
2. 6
1.0 1.2
2
4
Bo t t o m V i e w
1.2
1.4
1
To p V i e w Su gg e s t e d L a y o ut
3
www.yxcxtal.com
CRYSTAL UNIT
YSX531SL
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-5032
180±2.0
12.0±0.3
5.40±0.1
3.60±0.1
8.00±0.3
1.45±0.1
61.0±1.0
12.0±1.0
1000 pcs per reel
www.yxcxtal.com
很抱歉,暂时无法提供与“X50328MSB4SI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.00912
- 30+0.97202
- 100+0.93492
- 500+0.86072
- 1000+0.82362
- 2000+0.80136
- 国内价格
- 5+2.07550
- 50+1.61930
- 150+1.39540
- 1000+1.07800
- 2000+1.02360
- 5000+0.99080
- 国内价格
- 5+1.91913
- 50+1.49764
- 200+1.29184
- 400+1.27246
- 1000+0.99803
- 国内价格
- 5+2.11497
- 50+1.65046
- 150+1.42366
- 1000+1.09988
- 2000+1.04436
- 5000+1.01099
- 国内价格
- 50+0.76357
- 500+0.74580
- 国内价格
- 1+0.84520
- 50+0.81140
- 100+0.80020
- 国内价格
- 1+1.08120
- 50+0.83028
- 1000+0.76500
- 国内价格
- 10+3.42190
- 100+2.04120
- 500+1.42890
- 1000+1.02060
- 2000+0.96960
- 10000+0.89820
