X322524576MOB4SI
X322524576MOB4SI
    YXC(扬兴科技)
    SMD3225_4P
    无源晶振 50Ω 12pF ±10ppm -40℃~+85℃ 24.576MHz SMD3225_4P
X322524576MOB4SI 数据手册
CRYSTAL UNIT YSX321SL Applications Features ‧SmartWearable ‧Dimensions:3.20 x 2.50 x 0.70 mm. ‧High precision and high frequency stability. IOT Communication. ‧Standard Frequency: 8~64MHz ‧Extremely good for reducing EMI effect. Specifications Standard Frequency 8~64 MHz Vibration Mode AT Fundamental Load Capacitance 10pF,20pF,or specify Frequency Tolerance (at 25 ) ±10ppm,±20ppm,or specify Frequency Versus Temperature Characteristics Operating Temperature ±20ppm,or specify -20~+70℃,-40~+85℃,or specify -55~+125℃ or specify Storage Temperature Shunt Capacitance 7 pF Max. Level of Drive 1~200μWMax.(100uW typical) Aging (at 25 ℃ ) ±3ppm/year Max. Equivalent Series Resistance(ESR) 8 ~ 11.2892MHz 12 ~ 16 MHz 17 ~ 64 MHz Fundamental 150 Ω Max. 80 Ω Max. 50 Ω Max. Dimensions and Patterns [unit:mm] Package Size – Dimensions (Unit: mm) www.yxc.hk 第1页共2页 CRYSTAL UNIT YSX321SL Reflow Soldering Profile Temperature Pre Heating Temperature Tp1 ~ Tp2 = + 170 °C Heating Temperature TMlt = + 220 °C Peek Temperature TMax. = + 260 °C +260℃ TMax. +220℃ Tmlt Point of measuring In case of Solder ability Terminal. In case of Resistance to soldering heat Surface. Tp2 Tp1 35s 100s t(time) Taping Specification(Unit: mm) Size A B C D E F G H SMD-3225 180±2.0 8.0±0.3 3.50±0.1 2.50±0.1 4.0±0.1 1.40±0.1 61.0±1.0 8.0±1.0 3000 pcs per reel www.yxc.hk 第2页共2页
X322524576MOB4SI 价格&库存
很抱歉,暂时无法提供与“X322524576MOB4SI”相匹配的价格&库存,您可以联系我们找货
X322524576MOB4SI
  • 10+0.45371
  • 100+0.37120
  • 300+0.32994
库存:1211
X322524576MOB4SI
  • 20+0.61600
  • 100+0.46070
  • 800+0.35720
  • 3000+0.25880
  • 15000+0.23300
库存:108
X322524576MOB4SI
  • 1+0.35850
库存:579
X322524576MOB4SI
  • 1+0.28616
  • 100+0.26656
  • 300+0.24696
  • 500+0.22736
  • 2000+0.21756
  • 5000+0.21168
库存:62
