CRYSTAL UNIT
YSX321SL
Applications
Features
‧SmartWearable
‧Dimensions:3.20 x 2.50 x 0.70 mm.
‧High precision and high frequency stability.
IOT Communication.
‧Standard Frequency: 8~64MHz
‧Extremely good for reducing EMI effect.
Specifications
Standard Frequency
8~64 MHz
Vibration Mode
AT Fundamental
Load Capacitance
10pF,20pF,or specify
Frequency Tolerance (at 25 )
±10ppm,±20ppm,or specify
Frequency Versus Temperature Characteristics
Operating Temperature
±20ppm,or specify
-20~+70℃,-40~+85℃,or specify
-55~+125℃ or specify
Storage Temperature
Shunt Capacitance
7 pF Max.
Level of Drive
1~200μWMax.(100uW typical)
Aging (at 25 ℃ )
±3ppm/year Max.
Equivalent Series Resistance(ESR)
8 ~ 11.2892MHz
12 ~ 16 MHz
17 ~ 64 MHz
Fundamental
150 Ω Max.
80 Ω Max.
50 Ω Max.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
www.yxc.hk
第1页共2页
CRYSTAL UNIT
YSX321SL
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-3225
180±2.0
8.0±0.3
3.50±0.1
2.50±0.1
4.0±0.1
1.40±0.1
61.0±1.0
8.0±1.0
3000 pcs per reel
www.yxc.hk
第2页共2页
很抱歉,暂时无法提供与“X32252712MMB4SI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.62920
- 200+0.40560
- 1500+0.35256
- 3000+0.31096
- 国内价格
- 100+0.21902
- 500+0.21305
- 国内价格
- 1+0.29930
- 100+0.27880
- 300+0.25830
- 500+0.23780
- 2000+0.22755
- 5000+0.22140
- 国内价格
- 5+0.72933
- 50+0.57694
- 150+0.50069
- 500+0.44345
- 国内价格
- 5+0.47840
- 50+0.38730
- 150+0.32530
- 500+0.29920
- 1000+0.28050
- 3000+0.26400
- 6000+0.25170
