HY1210D/U/V
N-Channel Enhancement Mode MOSFET
Feature
Pin Description
100V/26A
RDS(ON) = 32mΩ(typ.)@VGS = 10V
RDS(ON) = 34mΩ(typ.)@VGS = 4.5V
100% Avalanche Tested
Reliable and Rugged
Halogen Free and Green Devices Available
G
D
S
(RoHS Compliant)
G
G
TO-252-2L
D
D
S
S
TO-251-3L
TO-251-3S
Applications
Power Management for Inverter Systems
N-Channel MOSFET
Ordering and Marking Information
Package Code
D
U
HY1210
HY1210
YYXXXJWW G
YYXXXJWW G
V
D: TO-252-2L
HY1210
U: TO-251-3L
V: TO-251-3S
Date Code
YYXXX WW
YYXXXJWW G
Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green”
to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous
material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr
-oduct and/or to this document at any time without notice.
www.hymexa.com
1
V1.1
HY1210D/U/V
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (Tc=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
100
V
VGSS
Gate-Source Voltage
±20
V
Maximum Junction Temperture
150
°C
-55 to 150
°C
Tc=25°C
26
A
Tc=25°C
100
A
Tc=25°C
26
A
Tc=100°C
17
A
Tc=25°C
50
W
Tc=100°C
W
TJ
TSTG
Storage Temperture Range
IS
Drain Current-Continuous
Mounted on Large Heat Sink
Note:
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RJC
Thermal Resistance, Junction-to-Case
2.5
°C/W
RJA
Thermal Resistance, Junction-to-Ambient **
110
°C/W
EAS
Single Pulsed-Avalanche Energy ***
108
mJ
L=0.3mH
Repetitive rating ; pulse width limited by max junction temperature.
Surface mounted on a square inches Cu board.
Limited by TJmax , starting TJ=25°C, L = 0.3mH, VD= 80V, VGS =10V.
Electrical Characteristics(Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HY1210
Unit
Min
Typ
Max
VGS=0V,IDS=250uA
100
V
VDS=100V, VGS=0V
1
uA
30
uA
3.0
V
±100
nA
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Drain-to-Source LeakageCurrent
VGS(th)
IGSS
RDS(ON)*
TJ=85°C
Gate Threshold Voltage
VDS=VGS, IDS=250uA
1.0
2.0
Gate-Source Leakage Current
VGS=±20V,VDS=0V
VGS=10V,IDS=10A
32
36
mΩ
VGS=4.5V,IDS=10A
34
38
mΩ
ISD=10A,VGS=0V
0.8
1.3
V
21
ns
52
nC
Drain-Source On-state Resistance
Diode Characteristics
VSD*
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
www.hymexa.com
ISD=13A,dISD/dt=100A/us
2
V1.1
HY1210D/U/V
Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted)
Symbol
Parameter
Test Conditions
HY110
Min
Typ
Max
Unit
Dynamic Characteristics
Ciss
Input Capacitance
VGS=0V,VDS=0V,F=1
MHz
VGS=0V,
Coss
Output Capacitance
VDS=25V,
38
Crss
Reverse Transfer Capacitance
Frequency=1.0MHz
5.8
td(ON)
Turn-on Delay Time
11
RG
Tr
td(OFF)
Tf
Gate Resistance
1.7
2543
Turn-on Rise Time
VDD=50V,RG=3Ω,
8
Turn-off Delay Time
IDS=13A,VGS=10V
24
13
72
8
14
Turn-off Fall Time
Gate Charge
Ω
pF
ns
Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS =80V, VGS=10V,
ID=13A,
nC
Note: *Pulse test; pulse width ≤ 300us,duty cycle ≤ 2%
www.hymexa.com
3
V1.1
HY1210D/U/V
Typical Operating Characteristics
Figure 2: Drain Current
ID-Drain Current(A)
Power Dissipation (w)
Figure 1: Power Dissipation
Tc-Case Temperature(℃)
Thermal
Zθjc
ID-Drain Current(A)
Impedance
Figure 4: Thermal Transient Impedance
Normalized Transient
Figure 3: Safe Operation Area
Maximum Effective Transient Thermal
Impedance, Junction-to-Case
VDS-Drain-Source Voltage(V)
Figure 6: Drain-Source On Resistance
ID-Drain Current(A)
RDS(ON)-ON-Resistance(mΩ)
Figure 5: Output Characteristics
VDS-Drain-Source Voltage (V)
www.hymexa.com
ID-Drain Current(A)
4
V1.1
HY1210D/U/V
Typical Operating Characteristics(Cont.)
Figure 8: Source-Drain Diode Forward
IS-Source Current (A)
Normalized On-Resistance
Figure 7: On-Resistance vs. Temperature
Tj-Junction Temperature (℃)
VSD-Source-Drain Voltage(V)
Figure 10: Gate Charge Characteristics
C-Capacitance(pF)
VGS-Gate-Source Voltage (V)
Figure 9: Capacitance Characteristics
www.hymexa.com
QG-Gate Charge (nC)
5
V1.1
HY1210D/U/V
Avalanche Test Circuit and Waveforms
Switching Time Test Circuit and Waveforms
Gate Charge Test Circuit and Waveforms
www.hymexa.com
6
V1.1
HY1210D/U/V
Device Per Unit
Package Type
Unit
Quantity
TO-252-2L
TO-252-2L
TO-251-3L
TO-251-3S
Tube
75
Reel
Tube
Tube
2500
75
75
Package Information
TO-252-2L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A1
0.00
0.20
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
7
2.286BSC
H
9.40
10.10
10.50
L
1.38
1.50
1.75
L1
2.90REF
L2
0.51BSC
L3
0.88
1.28
L4
1.00
L5
1.65
1.80
1.95
θ
0°
8°
V1.1
HY1210D/U/V
TO-251-3L
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b2
0.00
0.04
0.10
b2'
0.00
0.04
0.10
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
2.286BSC
H
16.22
16.52
16.82
L1
9.15
9.40
9.65
L3
0.88
1.02
1.28
L5
1.65
1.80
1.95
8
V1.1
HY1210D/U/V
TO-251-3S
COMMON DIMENSIONS
SYMBOL
mm
MIN
NOM
MAX
A
2.20
2.30
2.40
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
6.60
6.80
E1
4.63
e
www.hymexa.com
2.286BSC
H
10.00
11.22
11.44
L1
3.90
4.10
4.30
L3
0.88
1.02
1.28
L5
1.65
1.80
1.95
9
V1.1
HY1210D/U/V
Classification Profile
Classification Reflow Profiles
Profile Feature
Preheat & Soak
Temperature min (Tsmin)
Temperature max (Tsmax)
Time (Tsmin to Tsmax) (ts)
Average ramp-up rate
(Tsmaxto TP)
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body Temperature
(Tp)*
Time (tP)** within 5°C of the specified
classification temperature (Tc)
Average ramp-down rate (Tpto Tsmax)
Time 25°C to peak temperature
Sn-Pb Eutectic Assembly
Pb-Free Assembly
100 °C
150 °C
150 °C
200 °C
60-120 seconds
60-120 seconds
3 °C/second max.
3°C/second max.
183 °C
217 °C
60-150 seconds
60-150 seconds
See Classification Temp in table 1
SeeClassification Tempin table 2
20** seconds
30** seconds
6 °C/second max.
6 °C/second max.
6 minutes max.
8 minutes max.
*Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
www.hymexa.com
10
V1.1
HY1210D/U/V
Table 1.SnPb Eutectic Process – Classification Temperatures (Tc)
Package
Volume mm³
Volume mm³
Thickness
很抱歉,暂时无法提供与“HY1210D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.01978
- 50+1.68178
- 500+1.35612
- 1000+1.33578
- 国内价格
- 5+2.22588
- 50+1.85339
- 150+1.69366
- 500+1.49451
- 2500+1.40584
