ICSRC6508-025SFR
ICSRC6508-025SFR
    ICT
    SHIELDCAN_65X0.92MM
    屏蔽罩支架 SHIELDCAN_65X0.92MM
ICSRC6508-025SFR 数据手册
0,7 신신 제제 APPROVED 2011.05.23 P.K.KOH B 인인부 치치 변변 0.8 ⇒ 0.92mm 2011.06.09 P.K.KOH SHIELD CASE THICKNESS 0.3±0.02 => 0.3 + 0.02 -0 2012.03.30 4 ±0.1 0,3 O 2 ±0.05 +0.1 0 TAPING 사양도 (SCALE 3/1) 4 ±0.1 NOTES 1. MATERIAL : SUS301 2. MATERIAL THICKNESS :0.15t 3. FINISHED : Sn(100%) PLATING ON BOTH SIDE ( NI 0.5㎛ Sn 1.27㎛ ) 4. PACKING MATERIALS. - REEL : HIPS 0.3t - COVER TAPE : PS _ Q'TY/REEL : 10,000ea 5. AVAILABLE SHIELD CASE THICKNESS : 0.3+ 0.02 -0 6. CONTACT RESISTANE 300mmΩ MAX 7. STENCLI THICKNESS : 0.12T 0,8 +0.1 0,92 -0.05 0,25 +0.02 -0.05 1,22 SCALE : 15/1 0,8 1,1 1 1,1 0,9 Max RECOMMENDED PCB LAYOUT 6,4 RECOMMENDED STENCIL LAY-OUT 0.1T 1,5 8. Maintain 90˚±3 while engage & disengage shield can & shield clip to prevent deformation & to maintain retention force of shield clip DATA 2011.05.23 0,8 6,7 P.K.KOH 16 7,5 ±0.1 1,4 3,25 6,5 1 A DATE C 1,75 ±0.1 0,5 1,85 0,15 REV REVISION HISTORY DESCRIPTION 1,55 0,8 0,4 APP. CHECK DESG. 2011.05.23 NAME LEE TITLE P.K.KOH UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS TOLERANCES ARE ANGLES ± 0. 3° 0~1 ± 0.05 1 ~ 5 ± 0.1 5 ~ 10 ± 0.15 SIZE DWG NO SHILED CLIP A3 ICSRC6508-025SFR FILE NAME: ICSRC6508-025SFR.dft SCALE: WEIGHT: SHEET 1 OF 1 REV C
ICSRC6508-025SFR 价格&库存
很抱歉,暂时无法提供与“ICSRC6508-025SFR”相匹配的价格&库存,您可以联系我们找货
ICSRC6508-025SFR
  • 5+0.21654
  • 20+0.19624
  • 100+0.17594
  • 500+0.15564
  • 1000+0.14617
  • 2000+0.13940
