Preliminary Datasheet
LP3983S
300mA,Ultra-low noise, Small Package
Ultra-Fast CMOS LDO Regulator
General Description
Features
The LP3983S is designed for portable RF and wireless
Ultra-Low-Noise for RF Application
applications with demanding performance and space
2V- 6V Input Voltage Range
requirements. The LP3983S performance is optimized
Low Dropout : 210mV @ 300mA
300mA Output Current, 550mA Peak Current
High PSRR: -70dB at 217Hz
< 0.1uA Standby Current When Shutdown
Available in SOT23-5 Package
Current Limiting and Thermal Shutdown
for battery-powered systems to deliver ultra low noise
and low quiescent current. A noise bypass pin is
available for further reduction of output noise.
Regulator ground current increases only slightly in
dropout, further prolonging the battery life. The
Protection
LP3983S also works with low-ESR ceramic capacitors,
reducing the amount of board space necessary for
power applications, critical in hand-held wireless
devices. The LP3983S consumes less than 0.01µA in
shutdown mode and has fast turn-on time less than
50µs. The other features include ultra low dropout
voltage,
high
output
accuracy,
current
limiting
Applications
Portable Media Players/MP3 players
Cellular and Smart mobile phone
LCD
DSC Sensor
Wireless Card
protection, and high ripple rejection ratio. It is available
in SOT23-5 packages.
Typical Application Circuit
Vin
Vout
1
Order Information
LP3983S □ □ □
VIN
2.2uF
OUT
5
22pF
(Option)
FB Voltage
Chip Enable
3
EN
08: 0.8V
ADJ
GND
R1
4
2
R2
F: Pb-Free
Package Type
Marking Information
B5: SOT23-5
Device
Marking
Package
Shipping
LP3983SAB5F-08
LPS
SOT23-5
3K/REEL
Output Type
A:Adjustable
1FYWX
Marking indication:
Y:Production year W:Production week X:Production batch
LP3983S-07
May.-2018
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 8
2.2uF
LP3983S
Functional Pin Description
Package Type
Pin Configurations
EN
GND
3
2
VIN
1
(MARKING)
SOT23-5
4
5
ADJ
VOUT
SOT23-5
Pin Description
Pin
Name
1
VIN
Power Input Voltage.
2
GND
Ground.
3
EN
4
ADJ
5
VOUT
LP3983S-07
May.-2018
Description
Chip Enable (Active High). There is an integrated pull low 1MΩ resistor connected
to GND when the control signal is floating.
Adjustable pin.
Output Voltage. Vout=VFB ×(1+R1/R2)
Page 2 of 8
LP3983S
Function Diagram
Absolute Maximum Ratings
Supply Input Voltage -------------------------------------------------------------------------------------------------------- 7V
EN Pin Voltage -------------------------------------------------------------------------------------------- -0.3V to Vin+0.3V
Power Dissipation, PD @ TA = 25°C
Maximum Power Dissipation ( PD,TA=25°C) --------------------------------------------------------------------- 0.5W
Package Thermal Resistance
Thermal Resistance (JA) ------------------------------------------------------------------------------------------- 195℃/W
Thermal Resistance (JC) --------------------------------------------------------------------------------------------- 60℃/W
Maximum Junction Temperature ----------------------------------------------------------------------------------- 150°C
Maximum Soldering Temperature (at leads, 10 sec) --------------------------------------------------------
260°C
Storage Temperature Range --------------------------------------------------------------------------- −65°C to 165°C
ESD Susceptibility
HBM (Human Body Mode) ------------------------------------------------------------------------------------------------ 2kV
MM(Machine-Mode) ------------------------------------------------------------------------------------------------------ 200V
Recommended Operating Conditions
Supply Input Voltage ------------------------------------------------------------------------------------------------ 2V to 6V
Operation Junction Temperature Range ------------------------------------------------------------ −40°C to 125°C
Operation Ambient Temperature Range -------------------------------------------------------------- −40°C to 85°C
LP3983S-07
May.-2018
Page 3 of 8
LP3983S
Electrical Characteristics
(VIN = VOUT + 1V, CIN = COUT =2.2µF, CFB = 22pF, TA = 25° C, unless otherwise specified)
Parameter
Symbol
Test Conditions
Min
Output Loading Current
ILOAD
VEN=VIN,VIN>2.5V
300
Current Limit
ILIM
RLOAD = 1Ω
VFB
IOUT=1mA
Quiescent Current
IQ
Dropout Voltage
VDROP
Line Regulation
ΔVLINE
Load Regulation
ΔVLOAD
1mA < IOUT < 300mA
Standby Current
ISTBY
VEN = GND, Shutdown
0.1
EN Input Bias Current
IIBSD
VEN = GND or VIN
5
VIL
VIN=3V to 5.5V, Shutdown
VIH
VIN=3V to 5.5V, Start-Up
Adjustable voltage
reference
Logic-Low
EN
Voltage
Threshold
Logic-High
Voltage
Power Supply
f = 217Hz
Rejection Rate
f = 1kHz
Thermal Shutdown
Temperature
LP3983S-07
May.-2018
mA
550
0.784
Units
mA
0.816
V
VEN ≥ 1.2V, IOUT = 0mA
100
130
μA
IOUT = 200mA, VOUT > 2.8V
140
180
mV
IOUT = 300mA, VOUT > 2.8V
210
270
mV
0.2
2
1
μA
VIN = (VOUT + 1V) to 5.5V,
IOUT = 1mA
COUT=1µF
PSRR
Max
0.8
10Hz to 100kHz, IOUT=200mA
Output Noise Voltage
Typ
IOUT = 100mA
TSD
uA
0.4
VIN+
1.4
0.3
V
V
300
uVRMS
−70
dB
−58
dB
150
°C
Page 4 of 8
LP3983S
Typical Operating Characteristics
LP3983S-07
May.-2018
Page 5 of 8
LP3983S
Applications Information
Like
any
low-dropout
regulator,
the
external
Start-up Function Enable Function
capacitors used with the LP3983S must be carefully
selected for regulator stability and performance.
Using a capacitor whose value is >1µF on the
LP3983S input and the amount of capacitance can
be increased without limit. The input capacitor must
be located a distance of not more than 0.5 inch from
the input pin of the IC and returned to a clean analog
ground. Any good quality ceramic or tantalum can be
used for this capacitor. The capacitor with larger
value and lower ESR (equivalent series resistance)
provides better PSRR and line-transient response.
The output capacitor must meet both requirements
for minimum amount of capacitance and ESR in all
LDOs application.
The
LP3983S
is designed
specifically to work with low ESR ceramic output
capacitor
in
space-saving
and
performance
consideration. Using a ceramic capacitor whose
value is at least 1µF with ESR is > 25mΩ on the
LP3983S output ensures stability. The LP3983S still
works well with output capacitor of other types due to
the wide stable ESR range. Output capacitor of
The
LP3983S
features
an
LDO
regulator
enable/disable function. To assure the LDO regulator
will switch on, the EN turn on control level must be
greater than 1.4 volts. The LDO regulator will go into
the shutdown mode when the voltage on the EN pin
falls below 0.4 volts. For to protecting the system, the
LP3983S have a quick-discharge function. If the
enable function is not needed in a specific
application, it may be tied to VIN to keep the LDO
regulator in a continuously on state.
Feedback Capacitor
larger capacitance can reduce noise and improve
For adjustable version, connecting a 22pF between
load transient response, stability, and PSRR. The
output pin and FB pin significantly reduces output
output capacitor should be located not more than 0.5
voltage ripple, it is critical that the capacitor
inch from the VOUT pin of the LP3983S and returned
connection should be direct and PCB traces should
to a clean analog ground.
be as short as possible.
The output voltage of
LDO could be set by the
formula below:
Vout=VFB ×(1+R1/R2)
Considering the practical application, we may add a
small capacitor with R1 in parallel which could be
22pF or 47pF.
LP3983S-07
May.-2018
Page 6 of 8
LP3983S
Thermal Considerations
Thermal protection limits power dissipation in
LP3983S. When the operation junction temperature
exceeds 150°C, the OTP circuit starts the thermal
shutdown function turn the pass element off. The
pass element turns on again after the junction
temperature cools by 25°C. For continue operation,
do not exceed absolute maximum operation junction
temperature 125°C.
The maximum power dissipation depends on the
thermal resistance of IC package, PCB layout, the
surroundings airflow and
difference
between
junction
to
temperature
ambient.
and the θJA is the junction to ambient thermal
resistance. For recommended operating conditions
specification of LP3983S, where TJ(MAX) is the
maximum junction temperature of the die (125°C)
and TA is the maximum ambient temperature. The
dependent) for SOT23-5 package is 195°C/W.
PD = (VIN−VOUT) x IOUT + VIN x IQ
of
temperature 125°C, TA is the ambient temperature
junction to ambient thermal resistance (θ JA is layout
The power dissipation definition in device is:
rate
Where TJ(MAX) is the maximum operation junction
The
PD(MAX) = (125°C−25°C) /195 = 500mW
operating ambient temperature for fixed TJ(MAX) and
thermal resistance θJA.
maximum power dissipation can be calculated by
following formula:
PD(MAX) = ( TJ(MAX) − TA ) /θJA
LP3983S-07
May.-2018
Page 7 of 8
LP3983S
Packaging Information
SOT23-5
LP3983S-07
May.-2018
Page 8 of 8
很抱歉,暂时无法提供与“LP3983SAB5F-08”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.20999
- 50+0.19199
- 500+0.17399
- 1000+0.15599
- 2500+0.14759
- 5000+0.14039
