TC20A026000GECN003
TC20A026000GECN003
    TKD(泰晶)
    SMD2016_4P
    有源晶振 26MHz 1.8V ±2ppm SMD2016_4P
TC20A026000GECN003 数据手册
TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 1 of 10 TCXO SPECIFICATION Customer: Customer P/N: TKD P/N: TC20A026000GECN003 Part Name: SMD TCXO 2016 Product Description: 26.000000MHz Issue Date: 2022/7/13 CUSTOMER’S APPROVAL (PLEASE RETURN A COPY WITH APPOVAL ) TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Approved Checked Designer Zhong YuanHua Zhan Chao Wang ShuangXi 地址:湖北省随州市高新区神农大道 9 号泰晶科技园 Address:TKD Technology Park,No.9,ShenNong Avenue,High-tech Zone,SuiZhou,HuBei Sales Tel:0722-7509016,Fax:0722-7509036,URL:www.sztkd.com TKD SCIENCE AND TECHNOLOGY CO.,LTD 泰 晶 科 技 股 份 有 限 公 司 Page 2 of 10 Rev. Description of Revision History Date Designer Checked By A New revision 2020/12/21 Zhan Chao Zhong YuanHua B Dimension tolerance and other optimizations 2021/9/8 Wang ShuangXi Zhong YuanHua C Drawing revision and other optimizations 2022/7/13 Wang ShuangXi Zhan Chao TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 3 of 10 TCXO SPECIFICATION 1.Description : 2016 TCXO 2.Nominal Frequency : 26.000000MHz 3.Electrical Specifications : Item 1 Parameters Condition 3 4 5 6 Frequency Tolerance After 2 times reflow 7 8 9 10 11 12 13 14 Supply Voltage Current Consumption Output Level Output Waveform Standard Output Load Duty Cycle Hystersis Harmonics @-40℃~-30℃ ±10% Standard Vcc±5% (Note2) 2 Years 5 Years Phase Noise @1 Hz offset @5 Hz offset @10 Hz offset @100 Hz offset @1 kHz offset @10 kHz offset @100 kHz offset Typical value at 25℃±5℃ @-20℃~65℃ 17 Frequency Slope(Note3) @-30℃~85℃ @-40℃~-30℃ 18 Note1 Note2 Note3 UNITS -0.5 -3.0 -0.1 -0.1 -40 0.5 3.0 0.1 0.1 85 MHz ppm ppm ppm ppm ℃ -2.0 2.0 ppm 3.08 2.0 Vcc mA Vp-p 1.80 0.8 10 Years 16 MAX 1.68 1 Year Aging TYP 26.000000 @-30℃~85℃ 15 MIN Nominal Frequency Vs.Temperature Frequenc (Note1) y Vs.Load Stability Vs.Supply Voltage Operating Temperature Range 2 Electrical Specifications Storage Temperature Refer to frequency at 25±2℃ Refer to nominal frequency Temperature variation 2°C/step,from low to high Clipped Sine wave 10kΩ // 10pF 40 50 60 -0.5 0.5 -8.0 -1.0 1.0 -1.5 1.5 -2.5 2.5 -5.0 5.0 -50 -73 -80 -106 -134 -145 -150 -0.05 0.05 -0.1 0.1 -0.35 0.35 -40 85 % ppm dBc ppm ppm ppm ppm dBc/Hz dBc/Hz dBc/Hz dBc/Hz dBc/Hz dBc/Hz dBc/Hz ppm/℃ ppm/℃ ppm/℃ ℃ TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 4 of 10 4.Test Circuit 5.Recommended Reflow Profile Reflow Profile Temperature MIN Preheat Temperature MAX Preheat Time(TSMIN -TSMAX) Temperature Peak Temperature Ramp-up Rate Ramp-Down Rate Time within 5℃ of Peak Temperature Time t[25℃] to Peak Temperature Time TSMIN TSMAX tS TL TP RUP RDOWN tP t[25℃] to Peak tL 150℃ 200℃ 60-180sec 217℃ 260℃ 3℃/sec max 6℃/sec max 10sec 480sec 60-150sec TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 6.Product Dimensions Page 5 of 10 Units:mm Pin Connection Name Connection Pin 1 GND Pin 2 GND Pin 3 Fout Pin 4 Vcc TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 6 of 10 7.Product Identification (Marking) T: TKD Logo 260: Frequency Code A: Frequency Discrimination Code ●: Pin1 Index D: Date Code ####: TCXO Lot Code Date Code 2019 2020 2021 2022 2023 2024 2025 2026 2027 2028 2029 2030 2031 2032 2033 2034 JAN a n A N FEB b p B P MAR c q C Q APR d r D R MAY e s E S JUN f t F T JUL g u G U AUG h v H V SEP j w J W OCT k x K X NOV l y L Y DEC m z M Z Year Month ※ This date code will be cycled every four years. TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 8.Structure Diagram No. Components Materials ① Lid Fe-Ni-Co Alloy ② Crystal Blank SiO2 ③ Conductive Adhesive Ag+Silicone resin ④ Base Ceramic+Noble Metal ⑤ Underfill Epoxy ⑥ Bump Au ⑦ IC Si Page 7 of 10 TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 9.Package Information Tape(Carrier)Dimensions The Direction of Packing Reel Dimensions Page 9 of 10 TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 10 of 10 Handling Instructions 1. Cautions for Handling a) Prevention against electrostatic breakdown Your full attention to static electricity is still requested. b) Direction Before mounting the crystal oscillator on board, Please confirm the direction to make sure the GND terminal and the terminal of power supply are not taken wrongly. 2. Prevention against Vibration and Shock While the product is being transported or mounted onto board, if undue hock and vibration exceeding the specification is put on, there is risk hat the built-in crystal blank is broken. When undue shock and vibration exceeding the specification is put on the product,please be sure to make confirmation of the product’s characteristics. 3. Soldering In order to assure the reliability of the crystal oscillator, please use the product under the recommended conditions. 4. Surface mounting a)This product is surface-mounting device. So, Please pay attention to the following things. b)Extreme deformation of board may make pattern off, the electrode of terminals off and solder broken.Full attention is requested especially when splitting the board with the oscillator mounted where the camber of the board occurs. c)In case that automatic mounter is used, please choose the type with small shock generation and make confirmation of the shock before use. 5. Cleaning Because cleaning will cause change to all characteristics, cleaning is forbidden. 6. Store keeping (method and duration) Long-time storage in the high/low temperature and high humidity leads to deterioration of solderability. So, please keep the product in the temperature of +5~+35 and humidity of 45~70%. Moreover, please keep the product in the circumstance with measures against static electricity. The storage life is 6 months before the pack is opened and please use it within 168 hours after the pack is opened. (Please keep it with desiccator etc. when you exceed 168 hours after the bag is opened. Please use it after confirming the product solderability.)
TC20A026000GECN003 价格&库存
很抱歉,暂时无法提供与“TC20A026000GECN003”相匹配的价格&库存,您可以联系我们找货
