TC25D026000GECN033
TC25D026000GECN033
    TKD(泰晶)
    SMD2520_4P
    无源晶振 -40℃~+85℃
TC25D026000GECN033 数据手册
TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 TCXO SPECIFICATION Customer: Customer P/N: TKD P/N: TC25D026000GECN033 Part Name: SMD TCXO 2520 Product Description: 26.000000MHz Issue Date: 2022/6/23 CUSTOMER’S APPROVAL (PLEASE RETURN A COPY WITH APPOVAL ) TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Approved Checked Designer Sun XiaoMing Zhong YuanHua Zhan Chao 地址:湖北省随州市高新区神农大道 9 号泰晶科技园 Address:TKD Technology Park,No.9,ShenNong Avenue,High-tech Zone,SuiZhou,HuBei Sales Tel:0722-7509016,Fax:0722-7509036,URL:www.sztkd.com Page 1 of 9 TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 2 of 9 Rev. Description of Revision History Date Designer Checked By A New revision 2021/3/11 Zhan Chao Zhong YuanHua B Drawing revisionand other optimizations 2022/5/24 Wang ShuangXi Zhan Chao C Frequency Stability 2022/6/23 Wang ShuangXi Zhan Chao TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 3 of 9 TCXO SPECIFICATION 1.Description : 2520 TCXO 2.Nominal Frequency : 26.000000MHz 3.Electrical Specifications : Item 1 2 3 Parameters Condition Electrical Specifications Min Nominal Frequency Vs.Temperature Frequency (Note1) Stability Vs.Load 4 Vs.Supply Voltage 0.5 ppm @-40℃~-30℃ -1.0 1.0 ppm ±10% -0.1 0.1 ppm Standard Vcc±5% -0.1 0.1 ppm -40 85 -2.0 2.0 ℃ ppm 3.30 Vcc 1.5 mA Frequency Tolerance(Note2) 7 Supply Voltage 8 Current Consumption 9 Output Level 10 Output Waveform 11 Standard Output Load 12 Duty Cycle 40 13 Hysteresis -0.6 14 Harmonics Phase Noise 17 Frequency slope(Note4) 18 Start-up Time 19 Storage Temperature Note1 Note2 Note3 Note4 MHz -0.5 6 16 Units @-30℃~85℃ Operating Temperature Range Aging Max 26.000000 5 15 Typ After 2 times reflow 1.70 2.80 0.8 Vp-p Clipped Sine wave (Note3) 10kΩ // 10pF 50 60 % 0.6 ppm -8.0 dBc 1st year -1.0 1.0 ppm 2nd year -1.5 1.5 ppm 5 years -2.5 2.5 ppm 10 years -5.0 5.0 ppm @1 Hz offset -50 dBc/Hz @10 Hz offset -80 dBc/Hz @100 Hz offset -106 dBc/Hz @1 kHz offset -134 dBc/Hz @10 kHz offset -144 dBc/Hz @100 kHz offset -152 dBc/Hz -0.1 0.1 ppm/℃ -0.35 0.35 ppm/℃ 2.0 ms 90 ℃ @-30℃~85℃ @-40℃~-30℃ To 90% of Vp-p -40 Referenced to the midpoint between minimum and maximum frequency value Refer to nominal frequency DC-cut capacitor of output is not put in TCXO. Please add DC-cut capacitor (above 1nF) in output line 2℃/step,from low to high temperature TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 4 of 9 4.Test Circuit 5.Recommended Reflow Profile Reflow Profile Temperature MIN Preheat Temperature MAX Preheat Time(TSMIN -TSMAX) Temperature Peak Temperature Ramp-up Rate Ramp-Down Rate Time within 5℃ of Peak Temperature Time t(25℃) to Peak Temperature Time TSMIN TSMAX tS TL TP RUP RDOWN tP t(25℃) to Peak tL 150℃ 200℃ 60-180sec 217℃ 260℃ 3℃/sec max 6℃/sec max 10sec 480sec 60-150sec TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 6.Product Dimensions Page 5 of 9 Units:mm Pin Connection Name Connection Pin 1 GND Pin 2 GND Pin 3 Fout Pin 4 Vcc TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 6 of 9 7.Product Identification (Marking) T: TKD Logo 260: Frequency Code A: Frequency Discrimination Code ●: Pin1 Index D: Date Code ####: TCXO Lot Code Date Code 2019 2020 2021 2022 2023 2024 2025 2026 2027 2028 2029 2030 2031 2032 2033 2034 JAN a n A N FEB b p B P MAR c q C Q APR d r D R MAY e s E S JUN f t F T JUL g u G U AUG h v H V SEP j w J W OCT k x K X NOV l y L Y DEC m z M Z Year Month ※This date code will be cycled every four years. TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 8.Structure Diagram No. Components Materials ① Lid Fe-Ni-Co Alloy ② Crystal Blank SiO2 ③ Conductive Adhesive Ag+Silicone resin ④ Base Ceramic+Noble Metal ⑤ Underfill Epoxy ⑥ Bump Au ⑦ IC Si Page 7 of 9 TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 9.Package Information Tape(Carrier)Dimensions The Direction of Packing Reel Dimensions Page 8 of 9 TKD Science and Technology Co.,Ltd 泰 晶 科 技 股 份 有 限 公 司 Page 9 of 9 Handling Instructions 1. Cautions for Handling a) Prevention against electrostatic breakdown Your full attention to static electricity is still requested. b) Direction Before mounting the crystal oscillator on board, Please confirm the direction to make sure the GND terminal and the terminal of power supply are not taken wrongly. 2. Prevention against Vibration and Shock While the product is being transported or mounted onto board, if undue hock and vibration exceeding the specification is put on, there is risk hat the built-in crystal blank is broken. When undue shock and vibration exceeding the specification is put on the product,please be sure to make confirmation of the product’s characteristics. 3. Soldering In order to assure the reliability of the crystal oscillator, please use the product under the recommended conditions. 4. Surface mounting a)This product is surface-mounting device. So, Please pay attention to the following things. b)Extreme deformation of board may make pattern off, the electrode of terminals off and solder broken.Full attention is requested especially when splitting the board with the oscillator mounted where the camber of the board occurs. c)In case that automatic mounter is used, please choose the type with small shock generation and make confirmation of the shock before use. 5. Cleaning Because cleaning will cause change to all characteristics, cleaning is forbidden. 6. Store keeping (method and duration) Long-time storage in the high/low temperature and high humidity leads to deterioration of solderability. So, please keep the product in the temperature of +5~+35 and humidity of 45~70%. Moreover, please keep the product in the circumstance with measures against static electricity. The storage life is 6 months before the pack is opened and please use it within 168 hours after the pack is opened. (Please keep it with desiccator etc. when you exceed 168 hours after the bag is opened. Please use it after confirming the product solderability.)
TC25D026000GECN033 价格&库存
很抱歉,暂时无法提供与“TC25D026000GECN033”相匹配的价格&库存,您可以联系我们找货
