AFSI000909081R0M05
AFSI000909081R0M05
    CHILISIN(奇力新)
    IND_9.3X9MM_SM
    功率电感 IND_9.3X9MM_SM 1µH ±20% 34A 9.30 x 9.00mm 8.10mm
AFSI000909081R0M05 数据手册
Automotive SMD Power Chokes – AFSI Series AEC-Q200 RoHS Compliant Halogen Free REACH Compliant ■ Part Numbering A Grade FSI Series Name 00 Control Code 090908 Dimensions Code (mm) 090908 9.3x9x8.1 121109 12x11x8.8 1R0 Inductance (uH) R47 0.47 4R7 4.7 100 10 Downloaded From Oneyac.com M 05 Tolerance Internal Code M ±20% Automotive SMD Power Chokes – AFSI Series AEC-Q200 AFSI00090908 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. AFSI00090908R68M05 AFSI000909081R0M05 AFSI000909081R5M05 AFSI000909082R2M05 AFSI000909083R3M05 AFSI000909084R7M05 AFSI000909086R8M05 AFSI000909088R2M05 AFSI00090908100M05 Inductance (uH) Test Freq. RDC(mΩ) Typ(Max) Isat (A)Typ. Irms (A)Typ. Tolerance (±%) Marking 0.68 1 1.5 2.2 3.3 4.7 6.8 8.2 10 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 1.3(2) 1.7(2.5) 2.5(3.5) 2.9(3.8) 5.6(6.5) 7(8.5) 12(13) 13.3(15) 13.8(15.5) 38 31 28 24 19 17.5 14 12 11 36 34 28 25 17.5 15 12 11 10 20 20 20 20 20 20 20 20 20 CR68 C1R0 C1R5 C2R2 C3R3 C4R7 C6R8 C8R2 C100 Note: When ordering, please specify tolerance code. Tolerance: M=±20% 1. Customized Specifications are welcome 2. Operating temperature range -50℃~155℃(Including self - temperature rise) 3. Isat for Inductance drop 30% from its value without current 4. Irms for a 40℃ temprature rise from 25℃ ambient with current 5. Measure Equipment: L: WK4237 RDC: CHEN HWA502 Isat: WK3260B/ 3265 Irms: WK3260B/ 3265 Downloaded From Oneyac.com Automotive SMD Power Chokes – AFSI Series AEC-Q200 AFSI00090908 Type ■ Characteristics Graph Inductance vs. DC Current 10 8 100 6 L(uH) 8R2 6R8 4 4R7 3R3 2 2R2 1R5 1R0 R68 0 0 5 10 15 20 25 30 35 40 DC Current(A) Temperature Change vs. DC Current 50 100 4R7 8R2 6R8 40 2R2 1R5 1R0 R68 △T(℃) 3R3 30 20 10 0 0 5 10 15 20 25 DC Current(A) Downloaded From Oneyac.com 30 35 40 Automotive SMD Power Chokes – AFSI Series AEC-Q200 AFSI00121109 Type ■ Dimensions ■ Recommended Land Pattern unit:mm unit:mm ■ Electrical Characteristics Part No. AFSI00121109R47M05 AFSI001211091R0M05 AFSI001211091R5M05 AFSI001211092R2M05 AFSI001211093R3M05 AFSI001211094R7M05 AFSI001211095R6M05 AFSI001211096R8M05 AFSI001211098R2M05 AFSI00121109100M05 AFSI00121109150M05 Inductance (uH) Test Freq. RDC(mΩ) Typ(Max) Isat (A)Typ. Irms (A)Typ. Tolerance (±%) Marking 0.47 1 1.5 2.2 3.3 4.7 5.6 6.8 8.2 10 15 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 100kHz,1V 1.1(1.5) 1.5(2.0) 2.0(2.5) 2.4(2.8) 3.3(3.8) 5.7(6.2) 6.4(7.0) 6.8(7.8) 8.2(9.0) 11.3(12) 14.3(15) 65 45 36 30 26 23 21 19 18 17.5 13.5 50 40 33 30 26 20 18 17 16 13 11 20 20 20 20 20 20 20 20 20 20 20 CR47 C1R0 C1R5 C2R2 C3R3 C4R7 C5R6 C6R8 C8R2 C100 C150 Note: When ordering, please specify tolerance code. Tolerance: M=±20% 1. Customized Specifications are welcome 2. Operating temperature range -50℃~155℃(Including self - temperature rise) 3. Isat for Inductance drop 30% from its value without current 4. Irms for a 40℃ temprature rise from 25℃ ambient with current 5. Measure Equipment: L: WK4237 RDC: CHEN HWA502 Isat: WK3260B/ 3265 Irms: WK3260B/ 3265 Downloaded From Oneyac.com Automotive SMD Power Chokes – AFSI Series AEC-Q200 AFSI00121109 Type ■ Characteristics Graph Inductance vs. DC Current 15 12 150 L(uH) 9 100 6 8R2 6R8 5R6 4R7 3 3R3 2R2 1R5 1R0 R47 0 0 10 20 30 40 50 60 70 DC Current(A) Temperature Change vs. DC Current 50 8R2 6R8 5R6 150 4R7 100 △T(℃) 40 3R3 2R2 1R5 1R0 R47 30 20 10 0 0 10 20 30 DC Current(A) Downloaded From Oneyac.com 40 50 60 Automotive SMD Power Chokes – AFSI Series AEC-Q200 ■ Packaging Tape Dimensions Reel Dimensions Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A0 B0 K0 K1 D F W T P A B C D PCS / REEL AFSI00090908 9.2 9 8.8 7.6 1.5 11.5 24 0.4 16 330 100 13 24.3 300 AFSI00121109 12.2 11 9 8.07 1.5 11.5 24 0.5 20 330 100 13 24.3 240 Downloaded From Oneyac.com 单击下面可查看定价,库存,交付和生命周期等信息 >>CHILISIN(奇力新) Downloaded From Oneyac.com
AFSI000909081R0M05 价格&库存
很抱歉,暂时无法提供与“AFSI000909081R0M05”相匹配的价格&库存,您可以联系我们找货
