53112000
53112000
    LAPP(缆普)
53112000 数据手册
SKINTOP® UNCONTROLLED COPY Metallic cable glands Strain relief cable glands SKINTOP® MS-M/MSR-M Nickel-plated brass strain relief with metric thread Complete the installation SKINTOP® DIX bushing page 545 Plugs page 522 SKINDICHT® SM locknuts page 542 SKINTOP® MS/MSR is a superior quality, liquid-tight, metallic cable gland intended for applications where ruggedness and durability are required. These cable glands are suitable for a wide range of applications, from manufacturing machinery to measurement and control equipment, including automation and robotics. SKINTOP® MSR includes reducer bushing. Application advantage •S  uitable for use in areas with high demands on special mechanical and chemical stability • T he heavy duty SKINTOP® design provides great pull-out strength and very reliable strain relief Approvals • Extended temperature range due to the nickel-plated brass body • Generous high-quality neoprene bushing and NBR O-ring provide a liquid-tight and dust-proof hermetic seal * DNV pending for size M75; UL, CSA, DNV & VDE pending for sizes M90 & M110 Technical data Material: - body: - insert: - bushing: - O-ring: nickel-plated brass polyamide CR NBR Locknuts: add SKINDICHT® SM-M, page 542 Part number Standard 53112000 53112010 53112020 53112030 53112040 53112050 53112060 53112070 53112080 53112510 53112512 53112514 Reducer bushing 53112100 53112110 53112120 53112130 53112140 53112150 53112160 53112170 53112511 53112515 Thread Temperature range: - static: -40°C to +100°C - dynamic: -25°C to +100°C Protection: 70 PSI - M12 - M50: IP68, 10 bar - M12 - M63: IP68, 5 bar IP69 NEMA 1, 4X, 6, 12 - M12 - M75: IP68, 1 bar in mm Wrenching flats (SW) in Clamping range (øF) UL status Overall length (C) in Thread length (D) in Pack size M12 x 1.5 M16 x 1.5 M20 x 1.5 M25 x 1.5 M32 x 1.5 M40 x 1.5 M50 x 1.5 M63 x 1.5 M63 x 1.5, plus M75 x 1.5 M90 x 2.0 M110 x 2.0 Recognized Recognized Listed Listed Listed Listed Listed Listed Listed Listed Listed Listed 0.138 - 0.276 0.177 - 0.394 0.276 - 0.512 0.354 - 0.669 0.433 - 0.827 0.748 - 1.103 1.063 - 1.379 1.339 - 1.773 1.733 - 2.167 2.285 - 2.679 2.600 - 3.073 3.388 - 3.861 3.5 - 7 4.5 - 10 7 - 13 9 - 17 11 - 21 19 - 28 27 - 35 34 - 45 44 - 55 58 - 68 66 - 78 86 - 98 0.630 0.788 0.945 1.142 1.418 1.773 2.127 2.639 2.955 3.743 4.531 5.319 1.044 1.260 1.398 1.477 1.662 1.950 2.048 2.415 2.580 4.137 5.358 6.067 0.256 0.276 0.315 0.315 0.354 0.354 0.394 0.591 0.591 0.591 0.788 0.985 100 100 50 25 25 10 5 5 5 1 1 1 M12 x 1.5 M16 x 1.5 M20 x 1.5 M25 x 1.5 M32 x 1.5 M40 x 1.5 M50 x 1.5 M63 x 1.5 M75 x 1.5 M110 x 2.0 Recognized Recognized Listed Listed Listed Listed Listed Listed Listed Listed 0.078 - 0.197 0.078 - 0.276 0.197 - 0.394 0.236 - 0.512 0.276 - 0.591 0.591 - 0.906 0.866 - 1.142 1.103 - 1.536 2.088 - 2.482 2.994 - 3.467 2-5 2-7 5 - 10 6 - 13 7 - 15 15 - 23 22 - 29 28 - 39 53 - 63 76 - 88 0.630 0.788 0.945 1.142 1.418 1.773 2.127 2.639 3.743 5.319 1.044 1.260 1.398 1.477 1.662 1.950 2.048 2.415 4.137 6.067 0.256 0.276 0.315 0.315 0.354 0.354 0.394 0.591 0.591 0.985 100 100 50 25 25 10 5 5 1 1 If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. for current information see:  www.lappusa.com • www.lappcanada.com 515
53112000 价格&库存
很抱歉,暂时无法提供与“53112000”相匹配的价格&库存,您可以联系我们找货
