109P0612M6D01
109P0612M6D01
    OTHER
109P0612M6D01 数据手册
DC Fan 60×60×20 mm San Ace 60 9P type ■ General Specifications ・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) ・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) ・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 547. ・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) ・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) ・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet ・ Storage temperature ……………………… -30 to +70˚C (Non-condensing) ・ Lead wire ……………………………………… Red Black or Blue Yellow Sensor ・ Mass ……………………………………………… 90 g ■ Specifications The models listed below have ribs and pulse sensors. Rated voltage Operating voltage range Rated current Rated input Model no. [V] 109P0612W601 109P0612H601 109P0612M601 109P0624W601 109P0624H601 109P0624M601 109P0648H601 12 Max. static pressure [W] [min-1] [m³/min] [CFM] [Pa] 6 to 16 0.13 0.13 0.09 0.07 0.07 0.05 0.07 1.56 1.56 1.08 1.68 1.68 1.2 3.36 4200 4200 3200 4200 4200 3200 5600 0.42 0.42 0.3 0.42 0.42 0.3 0.55 14.8 14.8 10.6 14.8 14.8 10.6 19.4 31.8 31.8 18.8 31.8 31.8 18.8 52.9 12 to 30 20.4 to 27.6 48 Max. airflow [A] 10.2 to 13.8 24 Rated speed [V] 43 to 53 SPL [inchH²O] Operating temperature Expected life [dB (A)] [˚C] 31 31 25 31 31 25 41 -20 to +70 0.128 0.128 0.076 0.128 0.128 0.076 0.212 [h] 60000/60˚C 40000/60˚C The following sensor and control options are available for selection. Available for all models. Without sensor Lock sensor ■ Airflow - Static Pressure Characteristics 109P0612W601 109P0612H601 With pulse sensor Operating voltage range 0.10 16 V 40 12 V 30 20 0.05 0 6V 10 0 0.2 0 68 5 0.4 10 15 Airflow 風量 0.6 (m3/min) 20 (CFM) 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 (inch H2O) (Pa) 50 0.12 13.8 V 40 Static静圧 pressure 0.15 50 Static静圧 pressure Static静圧 pressure 60 With pulse sensor Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 0.20 109P0612M601 With pulse sensor Operating voltage range 12 V 30 10.2 V 20 10 30 0.10 0.08 13.8 V 20 12 V 0.06 0.04 10.2 V 10 0.02 0 0.2 0 5 0.4 10 15 Airflow 風量 0.6 (m3/min) 20 (CFM) 0 0 0.1 0 0.2 5 0.3 10 Airflow 風量 0.4 15 0.5 (m3/min) (CFM) 109P0624H601 With pulse sensor Operating voltage range Operating voltage range 0.10 30 V 40 24 V 30 20 0.05 12 V 10 0 0 0.2 0 109P0648H601 5 0.4 10 0.6 (m3/min) 15 Airflow 風量 20 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 (inch H2O) (Pa) 50 0.12 27.6 V 40 Static静圧 pressure 0.15 50 Static静圧 pressure Static静圧 pressure 60 24 V 30 20.4 V 20 10 30 0.10 0.08 27.6 V 20 24 V 0.06 0.04 20.4 V 10 0.02 0 0.2 0 (CFM) With pulse sensor Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 0.20 109P0624M601 With pulse sensor DC Fan 60 mm sq. 109P0624W601 DC ■ Airflow - Static Pressure Characteristics 5 0.4 10 15 Airflow 風量 0.6 (m3/min) 20 (CFM) 0 0 0.1 0 0.2 5 0.3 10 Airflow 風量 0.4 15 0.5 (m3/min) (CFM) With pulse sensor Operating voltage range (inch H2O) (Pa) 70 Static静圧 pressure 0.25 0.20 0.15 0.10 60 53 V 50 48 V 40 43 V 30 20 0.05 10 0 0 0.2 0 5 0.4 10 Airflow 風量 0.6 (m3/min) 15 20 (CFM) ■ Dimensions (unit: mm) 0 20 -1 +1 60 0 4-ø4.3±0.3 Mounting 取付用穴 hole 50±0.3 (3) (5) 50±0.3 +1 60 0 Lead wire リー ド線 AWG24 UL 1007 +50 300 0 (10) Rotating direction 回転方向 Airflow direction 風吹出方向 69 ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 58 4-ø4.5 50±0.3 3 58 50±0.3 ø6 ■ Options Finger guards page: p. 532 Model no.: 109-139E, 109-139H Resin filter kits Model no.: 109-1003G page: p. 540 Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI), 109-1003F30 (30PPI), 109-1003F40 (40PPI) 70 Resin finger guards page: p. 539
109P0612M6D01 价格&库存
很抱歉,暂时无法提供与“109P0612M6D01”相匹配的价格&库存,您可以联系我们找货
