SFH 7250
SFH 7250
    AMSOSRAM(艾迈斯半导体)
SFH 7250 数据手册
2015-12-14 Infrared-Emitter (850 nm) and Si-Phototransistor Version 1.3 SFH 7250 Features: • Available on tape and reel • SMT package with IR emitter (850 nm) and Si-phototransistor • Suitable for SMT assembly • Emitter and detector can be controlled separately Applications Data transmission • • Lock bar • Infrared interface Ordering Information Type: Package: Ordering Code SFH 7250 SMT Multi TOPLED® Q65111A3188 2015-12-14 1 Version 1.3 SFH 7250 Maximum Ratings Parameter Symbol Values Unit Operating and storage temperature range Top; Tstg -40 ... 100 °C Junction temperature Tj 100 °C Electrostatic discharge (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V Emitter 1 Forward current IF 70 mA Surge current (tp ≤ 10 µs, D = 0) IFSM 0.7 A Reverse voltage VR 5 V Ptot 140 mW RthJA 500 K/W RthJS 400 K/W Collector current IC 15 mA Surge current (tp ≤ 10 µs, D = 0) IFSM 0.075 A Collector-emitter voltage VCE 35 V Total Power dissipation Ptot 165 mW RthJA 450 K/W Power consumption Thermal resistance junction - ambient 1) page 15 Thermal resistance junction - solder point Phototransistor Thermal resistance 1) page 15 The stated maximum ratings refer to one chip. Characteristics Parameter Symbol Values Unit Emitter 1 (TA = 25 °C) Peak wavelength (IF = 70 mA, tp = 20 ms) (typ) λpeak 860 nm Centroid wavelength (IF = 70 mA, tp = 20 ms) (typ) λcentroid 850 nm Spectral bandwidth at 50% of Imax (IF = 70 mA, tp = 20 ms) (typ) ∆λ 30 nm Half angle (typ) ϕ ± 60 2015-12-14 2 ° Version 1.3 SFH 7250 Parameter Symbol Values Unit 0.2 x 0.2 mm x mm Dimensions of active chip area (typ) LxW Rise and fall time of Ie ( 10% and 90% of Ie max) (IF = 70 mA, RL = 50 Ω) (typ) tr, tf Forward voltage (IF = 70 mA, tp = 20 ms) 12 ns (typ (max)) VF 1.6 (≤ 2) V Forward voltage (IF = 500 mA, tp = 100 µs) (typ (max)) VF 2.4 (≤ 3) V Reverse current (VR = 5 V) (typ (max)) IR not designed for reverse operation µA Total radiant flux (IF = 70 mA, tp = 20 ms) (typ) Φe 40 mW Min Radiant Intensity (IF = 70 mA, tp = 20 ms) Ie, min 6.3 mW / sr Radiant intensity (IF = 70 mA, tp = 20 ms) Ie, typ 10 mW/sr Typ Radiant Intensity (IF = 500 mA, tp = 100 µs) Ie, typ 60 mW / sr Temperature coefficient of Ie or Φe (IF = 70 mA, tp = 20 ms) (typ) TCI -0.5 %/K Temperature coefficient of VF (IF = 70 mA, tp = 20 ms) (typ) TCV -0.7 mV / K Temperature coefficient of wavelength (IF = 70 mA, tp = 20 ms) (typ) TCλ 0.3 nm / K Wavelength of max. sensitivity (typ) λS max 990 nm Spectral range of sensitivity (S = 10% of Smax) (typ) λ 440 ... 1150 nm Radiant sensitive area (∅ = 240 µm) (typ) A 0.038 mm2 Dimensions of chip area (typ) LxW (typ) 0.45 x 0.45 mm x mm Distance chip front to case surface (typ) H (typ) 0.5 ... 0.7 mm Half angle (typ) ϕ ± 60 ° Capacitance (VCE = 0 V, f = 1 MHz, E = 0) (typ) CCE Phototransistor (TA = 25 °C, λ = 880 nm) 2015-12-14 3 5 pF Version 1.3 SFH 7250 Parameter Symbol Dark current (VCE = 25 V, E = 0) Values (typ (max)) ICE0 Photocurrent (λ = 880 nm, Ee = 0.1 mW/cm2, VCE = 5 V) Unit 1 (≤ 200) nA IPCE ≥ 16 µA 7 µs 150 mV Rise and fall time (IC = 1 mA, VCC = 5 V, RL = 1 kΩ) (typ) tr, tf Collector-emitter saturation voltage (IC = 5 µA, Ee = 0.1 mW/cm2) (typ) VCEsat Grouping (TA = 25 °C) Group Min Radiant Intensity Max Radiant Intensity Typ Radiant Intensity IF = 70 mA, tp = 20 ms IF = 70 mA, tp = 20 ms IF = 500 mA, tp = 100 µs Ie, min Ie, max Ie, typ SFH 7250-Q 6.3 12.5 55 SFH 7250-R 10 20 90 Note: Measured at a solid angle of Ω = 0.01 sr. Relative Spectral Emission 2) page 15 (typ) Irel = f(λ), TA = 25°C Radiant Intensity 2) page 15 Ie / Ie(70 mA) = f(IF), single pulse, tp = 25 µs OHF04132 100 OHF04406 101 I rel % Ie I e (70 mA) 80 100 5 60 10-1 5 40 10-2 20 0 700 5 750 800 850 10-3 0 10 nm 950 λ 2015-12-14 5 10 1 5 10 2 mA IF 4 10 3 Version 1.3 SFH 7250 Forward Current 2) page 15 IF = f(VF), TA = 25 °C Max. Permissible Forward Current IF, max = f(TA) IF OHF03732 80 mA IF 70 OHF03826 100 A 10-1 60 5 50 10-2 40 5 30 10-3 20 5 10 0 0 20 40 60 80 10-4 100 ˚C 120 0 0.5 1 1.5 2 2.5 V 3 VF TA Relative Spectral Sensitivity 2) page 15 Srel = f(λ), TA = 25°C Permissible Pulse Handling Capability IF = f(tp), TA = 25 °C, duty cycle D = parameter IF 0.7 A 0.6 OHF03733 t tP IF D = TP Srel 100 % OHF00207 T 80 0.5 0.4 0.3 0.2 D= 70 0.005 0.01 0.02 0.05 0.1 0.2 0.3 0.5 1 60 50 40 30 20 0.1 10 0 400 500 600 700 800 900 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 tp 2015-12-14 5 nm 1100 λ Version 1.3 SFH 7250 Photocurrent 2) page 15 IPCE = f(Ee), VCE = 5 V, TA = 25°C Photocurrent 2) page 15 IPCE = f(VCE), Ee = Parameter, TA = 25°C mW 1 2 cm Ι PCE Ι PCE 10 OHF01529 10 0 mA OHF00312 10 3 µA 2 0.5 mW cm 2 0.25 mW cm 2 0.1 mW cm 2 10 -1 10 1 10 0 10 -1 10 -3 10 -2 m W/cm 2 10 -2 10 0 0 5 10 15 20 25 Ee Photocurrent 2) page 15 IPCE / IPCE(25°C) = f(TA), VCE = 5 V Ι PCE Ι PCE 25 Dark Current 2) page 15 ICEO = f(VCE), E = 0, TA = 25°C OHF01527 10 1 nA OHF01524 1.6 30 V 35 V CE Ι CEO 1.4 10 0 1.2 1.0 10 -1 0.8 0.6 10 -2 0.4 0.2 0 -25 2015-12-14 0 25 50 10 -3 75 C 100 TA 6 0 5 10 15 20 25 30 V 35 V CE Version 1.3 SFH 7250 Dark Current 2) page 15 ICEO = f(TA), VCE = 5 V, E = 0 Collector-Emitter Capacitance 2) page 15 CCE = f(VCE), f = 1 MHz, E = 0, TA = 25°C OHF01530 10 3 nA OHF01528 5.0 Ι CEO C CE pF 4.0 10 2 3.5 3.0 10 1 2.5 2.0 1.5 10 0 1.0 0.5 10 -1 -25 0 25 50 0 10 -2 75 ˚C 100 TA Power Consumption Ptot = f(TA) OHF00871 200 mW P tot 160 120 80 40 0 2015-12-14 0 20 40 60 80 ˚C 100 TA 7 10 -1 10 0 10 1 V 10 2 V CE Version 1.3 SFH 7250 Emitter Radiation Characteristics / Phototransistor Directional Characteristics 2) page 15 Irel = f(ϕ) / Srel = f(ϕ) 40˚ 30˚ 20˚ 10˚ 0˚ ϕ 50˚ OHL01660 1.0 0.8 0.6 60˚ 0.4 70˚ 0.2 80˚ 0 90˚ 100˚ 1.0 0.8 0.6 0.4 0˚ 20˚ Package Outline Dimensions in mm (inch). 2015-12-14 8 40˚ 60˚ 80˚ 100˚ 120˚ Version 1.3 SFH 7250 Pinning Pin Description 1 Anode Emitter 1 2 Cathode Emitter 1 3 Collector Phototransistor 4 Emitter Phototransistor Package Multi TOPLED Approximate Weight: 34.0 mg Recommended Solder Pad Dimensions in mm (inch). 2015-12-14 9 Version 1.3 SFH 7250 Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 s 300 250 t OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum Ramp-up rate to preheat*) 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2015-12-14 °C 10 s Version 1.3 SFH 7250 Taping 2.9 (0.114) 4 (0.157) 8 (0.315) Cathode/Collector Marking 1.75 (0.069) 2 (0.079) 3.5 (0.138) 4 (0.157) 3.6 (0.142) 1.5 (0.059) OHAY0536 Dimensions in mm (inch). Tape and Reel 8 mm tape with 2000 pcs. on ∅ 180 mm reel, 8000 pcs. on ∅ 330 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 2015-12-14 11 Version 1.3 SFH 7250 Tape dimensions [mm] Tape dim ensions in m m W P0 P1 P2 D0 E F 8 + 0.3 / -0.1 4 ± 0.1 2 ± 0.05 or 4 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 3.5 ± 0.05 Reel dimensions [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 8 60 8.4 + 2 14.4 A W Nmin W1 W2max 330 8 60 8.4 + 2 14.4 Reel dim ensions in m m Barcode-Product-Label (BPL) OSRAM Opto EX AM P BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 (9D) D/C: 1234 ML Temp ST X XXX °C X Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Dry Packing Process and Materials Moisture-sensitive label or print L VE el LE see lab e If ve ati nk, bla cod bar y . H) (R . dit mi hu e ed ag RH % /60 Barcode label ˚C rar ck rel 30 N s VE RS inf pa % ainITI TO of to ak 90 d ntNSUC < ns (pe TIO or d , cte itio U g coSEND an bje ing ˚C nd 5 ˚C su ss CO Ais baRE co ± ce y 40 be TU MI CThIS ˚C < tor ll pro SE _ < urs ). urs Ho de urs Ho co 72 Ho urs te 48 e Ho 24 6 da e tim e th tim or ). 23 tim e at t wi nt˚C or l wi fac Flo tim s at or ca at re. Flo d tha ale el or nth nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic is be or de 24 tin en l 5a6 pro ve Le de , e te co , g: ve l un wh Le ke r se da ure ba ed low ba Le ve mo % ba e al d ure Le ist en ref e e 10 tim ure se for ist ale op se for > , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk g rd -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W Ho un Af Indno uir DE 1. d e 4 8 ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo MO TO OP M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet. Here you will also find the normative 2015-12-14 12 Version 1.3 SFH 7250 references like JEDEC. Transportation Packing and Materials Barcode label : NO 8 01 Y M DE R 18 -1 P -1 + Q P: OU GR 00 C: 99 D/ 21 D) 00 (9 21 20 34 : O 12 14 2 5 H (Q )Q TY S S em R ic AM on du O p ct to or H NO s TC 3G BA (6 P) NO : 12 11 00 LO T T) (1 NO : PR O (X ) Packing Sealing label Dimensions of transportation box in mm Width Length Height 200 ± 5 352 ± 5 195 ± 5 352 ± 5 30 ± 5 33 ± 5 2015-12-14 OD Y DE M R 18 -1 + Q -1 P : UP RO G ) (G 44 TY : 20 (Q )Q T LO T) (1 OS D 5 14 2 110 0 M RA 00 D/ C: 01 Muster O D) u (9 d A M n o : ic S R NO O 12 BA TC H 3G H S 8 NO (6 P) : 12 em 2199 34 ct pto o rs M u L lt S iT Y O T P 67 L 6 E Bi D Bi n1 Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: (X ) PR < 2100 (G ) L el OI M TO OP : E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho co ± 24 6 da e 40 be oc ry tim ˚C e r th ll pr tim cto ). r oo 23 wi nt tim e at l wi fa r Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is ingen be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk g rd M ois in r-p bla in Fl RH g, DM ba Ca bla th po If % kin life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed re ty is qu JE 2. bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT ntNS CT TIO DU U g EcoSE ON A ba IC UR M CThisSTSE 44 M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label 13 OHA02044 Version 1.3 SFH 7250 Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2015-12-14 14 Version 1.3 SFH 7250 Glossary 1) Thermal resistance: junction -ambient, mounted on PC-board (FR4), padsize 16 mm2 each 2) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 2015-12-14 15 Version 1.3 SFH 7250 Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-12-14 16
SFH 7250 价格&库存
很抱歉,暂时无法提供与“SFH 7250”相匹配的价格&库存,您可以联系我们找货
