UartSBee V5
UartSBee V5
    SEEEDSTUDIO
UartSBee V5 数据手册
        UartSBee V5   SKU 103100001  FTDI Cable compatible 3.3V and 5V dual mode Built‐in reset button for BEE modules Bit‐Bang mode ready (8  Serial I/Os or as SPI) Can program Mesh Bee         UartSBee v5' is FTDI cable compatible USB to Serial adapter equipped with BEE socket(20pin 2.0mm). The integrated FT232RL can be used for programming or communicating with MCUs. On the other hand, you might connect your PC to various wireless applications via a Bee compatible module. UartSBee provides breakouts for the bit‐bang mode pins of FT232RL as well.This Bit‐bang mode pins (8 I/O pins) can be used as a replacement for applications involving PC parallel port which is scares now a day. UartSBee v5 is the Mesh Bee programmer version based on UartSBee v4. Feature FTDI Cable compatible. USB 2.0 compatible Serial Interface. 3.3V and 5V compatible I/Os. 3.3V and 5V dual power outputs. Reset button for BEE modules. Bit‐Bang mode ready (8 Serial I/Os or as SPI). LEDs for UART and BEE operations.              Can program Mesh Bee UartBee V5 has added a button(SW3) that switch on the FT232's UART as the Tx1/Rx1 of Bee socket or the program interface of Mesh Bee module. Specification Microprocessor :FT232RL PCB size :3.1cm x 4.1cm Indicators :POWER,Green LED. LEDs for Txd and Rxd Power supply :3.3V and 5V DC Interface :MicroUSB, 2.54mm pitch pin header Adapter socket :XBee compatible 2.0mm pitch female pin header Connectivity :USB Communication Protocol :UART, Bit Bang I/O, SPI ROHS :YES Application Resources Eagle file for UartSBee v5 How to program Mesh Bee Technical details Dimensions  140mm x85mm x11mm  Weight  G.W 9g  Battery  Exclude  Part List UartSBee V5  1  ECCN/HTS ECCN  EAR99  HSCODE  8517709000  USHSCODE  8517700000  UPC  841454102182    https://www.seeedstudio.com/UartSBee‐V5.html/5‐23‐19
UartSBee V5 价格&库存
很抱歉,暂时无法提供与“UartSBee V5”相匹配的价格&库存,您可以联系我们找货
