APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
OPERATING
HUMIDITY RANGE
Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RATING
5
-40C TO + 85C(NOTE 1)
40% TO 80%(NOTE 3)
250V AC/DC
AWG#22
: 2A
AWG#24-28: 1A
AWG#30
:0.5A
VOLTAGE
CURRENT
APPLICABLE
CONNECTOR
DF11-**DS-2C(##)
STORAGE
TEMPERATURE RANGE
STORAGE
HUMIDITY RANGE
-10C TO +
40% TO 70%(NOTE 2)
VOLTAGE
30V AC
AWG#22
: 2A
AWG#24-28: 1A
AWG#30
:0.5A
UL・CSA
RATING
60C(NOTE 2)
CURRENT
APPLICABLE
CONTACT
DF11-**SC(F)(##)
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
X
X
X
X
X
X
X
X
X
X
X
X
X
CONSTRUCTION
GENERAL EXAMINATION
VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ACCORDING TO DRAWING.
ELECTRIC CHARACTERISTICS
CONTACT RESISTANCE 100mA (DC OR 1000 Hz).
30m MAX.
INSULATION
RESISTANCE
VOLTAGE PROOF
500V DC.
1000M MIN.
650V AC FOR 1 min.
NO FLASHOVER OR BREAKDOWN.
MECHANICAL CHARACTERISTICS
MECHANICAL
OPERATION
VIBRATION
SHOCK
① CONTACT RESISTANCE: 30m MAX.
② NO DAMAGE, CRACK OR LOOSENESS
OF PARTS.
FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE
① NO ELECTRICAL DISCONTINUITY OF 1s.
0.75 mm, AT 2 h, FOR 3 DIRECTIONS.
OF PARTS.
2
490 m/s DURATION OF PULSE 11 ms AT 3 TIMES ① NO ELECTRICAL DISCONTINUITY OF 1s.
FOR 3 DIRECTIONS.
OF PARTS.
30TIMES INSERTIONS AND EXTRACTIONS.
ENVIRONMENTAL CHARACTERISTICS
DAMP HEAT
(STEADY STATE)
RAPID CHANGE OF
TEMPERATURE
RESISTANCE TO
SOLDERING HEAT
SOLDERABILITY
COUNT
EXPOSED AT 40 ± 2 C, 90 TO 95 , 96 h.
② INSULATION RESISTANCE: 500M MIN.
③ NO DAMAGE, CRACK OR LOOSENESS
OF PARTS.
TEMPERATURE -55→ 5 TO 35→+85→ 5 TO 35C ① CONTACT RESISTANCE: 30m MAX.
TIME
30→ 5MAX → 30→ 5MAX min ② INSULATION RESISTANCE: 1000M MIN.
UNDER 5 CYCLES.
OF PARTS.
1)AUTOMATIC SOLDERING (FLOW)
NO DEFORMATION OF CASE OF
EXCESSIVE LOOSENESS OF THE
SOLDER TEMPERATURE : 260℃ FOR
TERMINALS.
IMMERSION,DURATION , 10 sec .
2)MANUAL SOLDERING
SOLDERING IRON TEMPERATURE : 300℃
SOLDERING TIME : 2 sec.
NO STRENGTH ON CONTACT.
SOLDERED AT SOLDER TEMPERATURE,
SOLDER SHALL COVER A MINIMUM OF
230C FOR INSERTION DURATION, 3sec.
95 OF THE SURFACE BEING
IMMERSED.
DESCRIPTION OF REVISIONS
DESIGNED
DIS-H-00004051
TS.MIYAKI
5
1
REMARKS
NOTE1:INCLUDING THE TEMPERATURE RISE BY CURRENT
NOTE2: APPLY TO THE CONDITION OF LONG TERM STORAGE FOR UNUSED PRODUCTS BEFORE MOUNTED ON PCB.
AFTER MOUNTED ON PCB, OPERATION TEMPERATURE AND HUMIDITY RANGE IS APPLIED FOR INTERIM
STORAGE DURING TRANSPORTATION.
NOTE3:NON-CONDENSING.
Unless otherwise specified , refer to IEC 60512.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
CHECKED
DATE
SZ.ONO
18.07.20
APPROVED
KJ.KATAYOSE
05.01.05
CHECKED
TY.OMA
05.01.05
DESIGNED
IO.DENPOUYA
05.01.05
DRAWN
IO.DENPOUYA
05.01.05
ELC4-084377-01
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
DF11-**DP-2DSA(08)
CL543
5
1/1
很抱歉,暂时无法提供与“DF11-8DP-2DSA(08)”相匹配的价格&库存,您可以联系我们找货
