Data Stream RS485 Digital Voltage Transducer
DIN RAIL / PANEL MOUNT
The CRD4500 Series Data Stream Digital Transducers are
designed for applications where AC current waveforms are not
purely sinusoidal. The digital technology is used to measure voltage,
current, power frequency and energy in single and three phase
designs. The data is streamed over an RS485 IEEE bus which enables
multiple transducers to communicate thru a single master connection.
These advanced sensors are ideal for entire plant or zone monitoring.
Also, the communication alagorithm can be pre-ordered with ASCII
based control or modified MODBUS based control.
Sensing
True RMS Voltage, Each Phase
CRD4510
Single Element
150 to 300 VAC Input Range
Applications
Features
35mm DIN Rail or Panel Mount
Red LED - Flashes when Power is Connected
Red & Green LED Flash during Communication
24 VDC powered
Use with external current transformers
Highest precision available
Connection diagram printed on case
CRD4550
Two Element
Regulatory Agencies
CRD4570
Three Element
PART NUMBERS
CRD4510
CRD4550
CRD4570
Single Element, AC Voltage RS485 Digital Transducer
Two Element, AC Voltage RS485 Digital Transducer
Three Element, AC RS485 Digital Transducer
150 300 -
0-150 VAC
0-300 VAC
Available up to and including 600 VAC
The Professional
Energy Monitoring
Company
M N TI
ISO 9001:2008 Quality Management System
Note: Add an M at
the end for MODBUS
CRD4510-150-M
3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119
Web: http://www.crmagnetics.com
17
E-mail: sales@crmagnetics.com
Data Stream
Sub-Metering
Motor Loads
Uninterruptible Power Systems
Remote Monitoring
Load Shedding
Energy Management
B
SPECIFICATIONS
B
Basic Accuracy: .......................0.5%
Calibration: ..............................True RMS Sensing
Thermal Drift: ..........................500 PPM/°C
Operating Temperature1: ..........0°C to +60°C
Installation Category: ..............CAT II
Vibration Tested To: .................IEC 60068-2-6,1995
Pollution Degree: ....................2
Insulation Voltage: ..................2500 VDC
Altitude: ..................................2000 meter max
Frequency Range: .................20 Hz - 5 KHz
MTBF: ....................................Greater than 100K hours
Cleaning: ................................Water-dampened cloth
Supply Voltage2: ......................24 VDC ±10%
Torque Specifications: ....................3.0 inch lbs (0.4Nm)
Response Time: .......................250 ms. max. 0-90% FS
Relative Humidity: .............5% to 95%, Non-Condensing
Output Resolution: ..................................................16 bit
Transducer fanout on common bus: ...................64 max.
Baud Rate3: ...............1200, 2400, 4800, 9600,19.2K .bps
A/D Conversion Type: ..................4th order Delta Sigma
Device Address3: ............................................00 to FF
Data Format: .... .....................................................ASCII
Supply Current:..................Typical 30mA
Max 30mA
Weight:.. ..............................................................0.5 lbs.
1) RH 5% to 95%, non-condensing 2) 0.4% max. ripple Vpp
no flow control, 1 stop bit
Data Stream
3) Factory default settings:
address 01, baud rate 9600, no parity,
L2 N
L1
N L1
L2
LINEN
L1
1
2
3
4
9
8
7
6
5
1
2
3
4
485
L3 L2
L2 L1
L3
L1
1
2
3
4
+ 485
485
+ SUPPLY
SUPPLY
LOAD
LOAD
SUPPLY
SUPPLY
LOAD
LOAD
+ 485
485
9
8
7
6
5
N
N
L3 L2
L2 L1
L1
L3
9
8
7
6
5
CRD4550 Dual Element, 3-Wire
CRD4510 Single Element, 2-Wire
1
2
3
4
+ 485
485
SUPPLY
SUPPLY
LOAD
LOAD
SUPPLY
LOAD
9
8
7
6
5
CRD4570 3 Element, 4-Wire
Connection Diagram
CRD485-232
RS485 to RS232 Converter Accessory
Connect PC to RS485 Bus
RED INDICATIOR LED
GREEN INDICATOR LED
RX
[26.6]
1.05
[3.3]
.13
OPTIONAL
MOUNTING
1
2
3
4
DATA STREAM
TRANSDUCER
DIN RAIL
MOUNTING
CLIP
[73.1]
2.88
[83.3]
3.28
TX
DATA +
9
8
7
6
5
DATAGND
CRD485-232
+5VDC
COM
RS232
GND
DB 9, FEMALE
SUPPLY
[25]
.98
ASCII Simplified Programming Commands
[78.7]
3.10
MAX
[76.7]
3.02
[5.6]
.22
TYP
[28.3]
1.12
[88.7]
3.49
[36.6]
1.44
OUTLINE DRAWING
The Professional
Energy Monitoring
Company
M N TI
A simplified data structure is used with only 6 commands required for full control of
the transducer. Commands are : Read Transducer Name, Read Configuration, Set
Configuration, Read Measurements, Read Energy Totalizer and Clear Energy
Totalizer. For illustration, the following commands are used to read data from a
CRD5170 3 Phase, 4 Wire Transducer with a device address of 00.
Command Transducer to Read Data: #00A
Transducers Response: >+[% FS VoltageL1-N]+[% FS CurrentL1]+[% FS
VoltageL2-N]+[% FS CurrentL2]+[% FS VoltageL3-N]+[% FS CurrentL3,][+/- % FS
Power][+/-% FS VARS][+/-Power Factor][Frequency]
Command Transducer to Read Energy Totalizer: #00W
Transducer Responds: 01[+/-KWHr]{\[+/-KVHr][check sum]
Note: This is for illustration purposes only, See Applications Guides (Section I
for complete instructions.
18
很抱歉,暂时无法提供与“CRD4510-300”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2523.551951+327.67067
