ACL391
ACL391
    ACLSTATICIDE
ACL391 数据手册
Model ACL 390 ACL 390 Surface Resistance Meter This durable and lightweight handheld meter measures both Surface Resistivity between two points (Rtt) and Resistance to Ground (Rtg). Test Range is from 103 to 1012 ohms. Meter automatically generates a 10v or 100v test voltage for a 9 volt battery with results shown through a multi-colored LED display. Meter can be used with the built-in parallel stainless steel electrodes or with optional external electrodes. • Meter includes ground cord and case. • Optional 5 pound weigh kit is avaliable. Benefits Features • • • • • • • Lightweight and durable Multi-colored LED display Measures automatically with 10v and 100v Test range 103 - 1012 Ω 10% accuracy Measures surface resistance Measures resistance to ground • • • • • • Long lasting, portable and easy to carry Easy to read, color indicates range Safe and easy to use Measures conductive, dissipative and insulative Reliable Fixed probes built-in with peripheral jacks for optional external probes When purchased with accessory kit, Meter complies with ESDA, ANSI, NFPA, UL, ASTM, Military, and EIA standards 1960 East Devon Ave. • Elk Grove Village, IL 60007 • (847) 981-9212 • Fax: (847) 981-9278 www.aclstaticide.com • info@aclstaticide.com MKB 11/05 ACL 390 Surface Resistance Meter Specifications: Power Supply Test Voltage Range Accuracy Weight Size 9 volt alkaline battery 10 volt / 100 volt 103 - 1012 Ω +/- 10% 8.5 ounces 2.5" x 5" x 1 1/8" Supplied With: Tester Carrying pouch 9v battery (installed) Grounding cord and alligator clip Calibration certificate Optional Weight Kit Available External probes will meet Industry standards for testing RTT and Volume Resistance. Probes are powder coated black and have an attached handle with a durable and conductive rubber base. ACL 391 includes: • Carrying Case with foam lining • Two 5lb, 2.5" RTT, RTG disk probes • Two accordion banana cords 5lb probes with cables 1960 East Devon Ave. • Elk Grove Village, IL 60007 (847) 981-9212 • Fax: (847) 981-9278 www.aclstaticide.com • info@aclstaticide.com MKB 11/05 ISO 9001: 2000 Reg. to: ACL Inc. Cert No. A3656
ACL391 价格&库存
很抱歉,暂时无法提供与“ACL391”相匹配的价格&库存,您可以联系我们找货
