CR4110-10
CR4110-10
    CR
    模块
CR4110-10 数据手册
True RMS AC Current Transducer The CR4100 Series True RMS Current Transducers and Transmitters are designed for applications where AC current waveforms are not purely sinusoidal. More precise and accurate than other transducers, these devices are ideal in chopped wave and phase fired control systems. DIN RAIL / PANEL MOUNT, TRUE RMS Applications Phase fired controlled heaters Quickly varying motor loads Chopped wave form drivers Harmonic currents CR4110 CR4120 CR4111 Single Element - 0.79” Window 0.1 to 600 AAC Input Range Features 35mm DIN Rail or Panel Mount Available with 0-5 VDC, 0-10 VDC, 4-20 mADC output 24 VDC powered Use with external current transformers Highest precision available Connection diagram printed on case Transducers C Regulatory Agencies CR4150 Recognized to meet UL 61010B-1 Constructed to meet CAN/CSA-C22.2, No. 61010-1-2004 Meets requirement of IEC 61010-1 and BS EN 61010-1 CR4160 Two Element - 0 .26” Window 0.1 to 30 AAC Input Range E199795 Use a 5 Amp Secondary Current Transformer to extend the ranges of all CR Magnetics Current Transducers CR4170 CR4180 Three Element - 0.26” Window 0.1 to 30 AAC Input Range Add suffix for input range PART NUMBERS CR4110(S) CR4111(S) CR4120(S) CR4150 CR4160 CR4170 CR4180 - Single element with 0 - 5 VDC output (split core design) Single element with 0 - 10 VDC output (split core design) Single element with 4 - 20 mADC output (split core design) Two element with 0 - 5 VDC output ** Two element with 4 to 20 mADC output ** Three element with 0 - 5 VDC output ** Three element with 4 - 20 mADC output ** *Two and three element transducers are available only in ranges of 0.1 to 30 AAC The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System All single phase current transducers are available in split core design. Simply put an “S” at the end of the prefix* I.E. CR4110S-10 * Not UL Recognized 5 10 15 20 25 30 40 50 75 100 150 - 0- 5 AAC ** 0-10 AAC ** 0-15 AAC ** 0-20 AAC ** 0-25 AAC ** 0-30 AAC ** 0-40 AAC 0-50 AAC 0-75 AAC 0-100 AAC 0-150 AAC Ranges available up to and including 600 AAC 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 32 E-mail: sales@crmagnetics.com True RMS AC Current Transducer DIN RAIL / PANEL MOUNT, TRUE RMS SPECIFICATIONS Basic Accuracy:............................... 0.5% Linearity:......................................... 10% to 100% FS Calibration:..................................... True RMS Sensing Thermal Drift:.................................. 500 PPM/°C Operating Temperature:................. 0°C to +60°C Installation Category:.................... CAT II Pollution Degree:........................... 2 Insulation Voltage:........................ 2500 VDC Vibration Tested To:........................IEC 60068-2-6,1995 Altitude:......................................... 2000 meter max. Frequency Range:......... 20 Hz - 5 KHz MTBF:............................ Greater than 100 K hours Cleaning:........................ Water-dampened cloth Supply Voltage:.............. 24 VDC ± 10% Output Load:.................. 4-20 mADC - 0 to 300 Ω 0-5 VDC - 2K Ω or Greater DIN RAIL MOUNTING CLIP [25] .98 1 2 3 4 OUTPUT + + 1 2 3 4 + 9 8 7 6 5 - 9 8 7 OUTPUT + 6 5 - SUPPLY SUPPLY [73.1][83.3] 2.88 3.28 CR4110 One Element 0 - 5 VDC Output CR4111 One Element 0 - 10 VDC Output [28.3] 1.12 Top View [3.3] .13 Optional Mounting [36.6] 1.44 End View [20.1] .79 [41.8] 1.65 CR4120 One Element 4 - 20 mADC Output 9 8 7 6 5 + OUTPUT 1 OUTPUT 2 - - + + 1 2 3 4 OUTPUT 2 1 2 9 3 4 7 + - - OUTPUT 1 8 + 6 + - - 5 SUPPLY L1 SUPPLY L2 CR4150 Two Element 0 - 5 VDC Output [50.7] 2.00 [5.6] .22 TYP [6.6] .26 [13.5] .53 [6.6] .260 1 2 3 4 [62] 2.44 [30.8] 1.21 [19.8] [19.8] .78 .78 9 8 7 6 5 [76.7] [64.2] 3.02 2.53 [64] [76.7] 2.52 3.02 [5.6] .22 TYP L1 L2 L3 + OUTPUT 2 + OUTPUT 1 + CR4160 CR4170 CR4180 OUTLINE DRAWING The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System + 1 2 3 4 9 8 7 6 5 SUPPLY CR4170 Three Element 0 - 5 VDC Output CR4150 CR4160 Two Element 4 - 20 mADC Output + OUTPUT 3 [88.7] 3.49 CR4110 CR4120 CR4111 [35] 1.38 L2 L1 [76.6] 3.02 L1 L2 L3 OUTPUT 3 + - OUTPUT 2 + + - OUTPUT 1 - SUPPLY CR4180 Three Element 4 - 20 mADC Output CONNECTION DIAGRAM NOTE: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 33 E-mail: sales@crmagnetics.com C Transducers [26.6] 1.05 Response Time:............. 250 ms max. 0-90% FS Relative Humidity:.......5% to 95%, Non-Condensing Torque Specs.:................ 3.0 inch lbs. (0.4Nm) Weight:.............................0.5 lbs. Supply Current: CR4110/11......................Typical 15mA Max 25mA CR4120...........................Typical 25mA Max 40mA CR4150...........................Typical 25mA Max 75mA CR4160...........................Typical 40mA Max 70mA CR4170...........................Typical 20mA Max 60mA CR4180...........................Typical 55mA Max 110mA CR4110S.........................Typical 15mA Max 25mA CR4120S.........................Typical 25mA Max 40mA
CR4110-10 价格&库存
很抱歉,暂时无法提供与“CR4110-10”相匹配的价格&库存,您可以联系我们找货
