CR5410-50
CR5410-50
    CR
    Module
CR5410-50 数据手册
AC/DC Hall Effect Current Transducer DIN RAIL / PANEL MOUNT, TRACING OUTPUT The CR5400 Series, AC/DC Hall Effect Current Transducers, are designed to provide a bipolar output that proportionally reflects (traces) the waveform of the input current. These devices are specifically targeted to be used in applications where multi-mode current sensing is required. Applications Inverter and multi-frequency drives Multi-mode ground paths carrying both AC and DC signals Feed back loop building block CR5410 C Features CR5411 Output isolated from input Non-contact current sensing 35mm DIN Rail or Panel Mount Connection diagram printed on case Single Element - .79” Window 20 TO 600 AAC/DC Input Range Regulatory Agencies Transducers Constructed to meet UL 61010B-1 Constructed to meet CAN/CSA-C22.2, No. 61010-1-2004 Meets requirement of IEC 61010-1 and BS EN 61010-1 E199795 All single phase current transducers are available in split core design. Simply put an “S” at the end of the prefix* I.E. CR5410S-30 Add suffix for input range PART NUMBERS CR5410(S) CR5411(S) - Single Element with ± 5 VAC/DC output (split core design) Single Element with ± 10 VAC/DC output (split core design) NOTE: AC/DC Split Core Transducers Available in 20 Amps and Higher 20 30 50 75 100 150 300 - ±20 AAC/ADC ±30 AAC/ADC ±50 AAC/ADC ±75 AAC/ADC ±100 AAC/ADC ±150 AAC/ADC ±300 AAC/ADC Ranges available up to and including 600 AAC/ADC The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 50 E-mail: sales@crmagnetics.com AC/DC Hall Effect Current Transducer DIN RAIL / PANEL MOUNT, TRACING OUTPUT SPECIFICATIONS Basic Accuracy:....................... Linearity:................................... Thermal Drift:........................... Operating Temperature:........... Installation Category:............... Vibration Tested To:................. Pollution Degree:..................... Altitude:................................... Insulation Voltage:................... Cleaning:................................. MTBF:..................................... Supply Voltage:....................... 1.0 % 10% to 100% FS 500 PPM/°C 0°C to +50°C CAT II IEC 60068-2-6,1995 2 2000 meter max. 2500 VDC Water-dampened cloth Greater than 100K hours 24 VDC ±10% Frequency Range:.........DC to 4 KHz Output:........................... ±5 Vac/DC or ±10 Vac/DC Output Load:................... 2 K Ω or greater Relative Humidity:......... 5% to 95%, Non-Condensing Supply Current: CR5410:........................ Typical 35mA Max 40mA CR5410S:..................... Typical 30mA Max 35mA Torque Specs.:.............. 3.0 inch lbs. (0.4Nm) Weight:.......................... 0.5 lbs. C + [3.3] .13 Optional Mounting DIN RAIL MOUNTING CLIP [73.1] 2.88 [83.3] 3.28 + OUTPUT + SUPPLY - [20.1] .79 [41.8] 1.65 9 8 7 6 5 CR5410 ±5 VAC/VDC Output CR5411 ±10 VAC/VDC Output [76.6] 3.02 [50.7] 2.00 [5.6] .22 TYP CONNECTION DIAGRAM [88.7] 3.49 [25] .98 [28.3] 1.12 [36.6] 1.44 CRPS24VDC - 120 OUTLINE DRAWING CRPS24VDC - 240 Power Supply NOTE: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 51 E-mail: sales@crmagnetics.com Transducers 1 2 3 4 [26.6] 1.05
CR5410-50 价格&库存
很抱歉,暂时无法提供与“CR5410-50”相匹配的价格&库存,您可以联系我们找货
