CR4420-100
CR4420-100
    CR
    Module
CR4420-100 数据手册
Average RMS AC Current Transducer DIN RAIL / PANEL MOUNT, AVERAGE RMS The CR4400 Series, Current Transducers and Transmitters are designed to produce a DC output signal that is proportional to the average RMS input AC current. Designed for multi-point current sensing, these devices provide excellent features in a value package . Applications Multi-point current sensing and control panels Monitor motor faults Monitor heating elements Monitor lighting elements CR4410 CR4411 CR4420 Single Element - .79" Window 0.5 to 600 AAC Input Range Features Low cost DIN rail or panel mount Available with 0-5 VDC, 0-10VDC or 4-20 mADC output High Accuracy Interfaces with most commercially available instrumentation Connection diagram printed on case Transducers C Regulatory Agencies Recognized to meet UL 61010B-1 Constructed to meet CAN/CSA-C22.2, No. 61010-1-2004 Meets requirement of IEC 61010-1 and BS EN 61010-1 CR4450 CR4460 Two Element - .26" Window 0.5 to 30 AAC Input Range E199795 CR4470 CR4480 Three Element - .26" Window 0.5 to 30 AAC Input Range Use a 5 Amp Secondary Current Transformer to extend the ranges of all CR Magnetics Current Transducers All single phase current transducers are available in split core design. Simply put an “S” at the end of the prefix* I.E. CR4410S-10 * Not UL Recognized Add suffix for input range PART NUMBERS CR4410(S) CR4411(S) CR4420(S) CR4450 CR4460 CR4470 CR4480 - Single element with 0 - 5 VDC output (split core design) Single element with 0 - 10 VDC output (split core design)* Single element with 4 - 20 mADC output (split core design) Two element with 0 - 5 VDC output * Two element with 4 to 20 mADC output * Three element with 0 - 5 VDC output * Three element with 4 - 20 mADC output * Two and three element transducers are available only in ranges of 0.5 to 30 AAC The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 5 10 15 20 25 30 40 50 75 100 150 - 0-5 AAC 0-10 AAC 0-15 AAC 0-20 AAC 0-25 AAC 0-30 AAC 0-40 AAC 0-50 AAC 0-75 AAC 0-100 AAC 0-150 AAC Ranges available up to and including 600 AAC 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 38 E-mail: sales@crmagnetics.com Average RMS AC Current Transducer DIN RAIL / PANEL MOUNT, AVERAGE RMS SPECIFICATIONS Basic Accuracy:..................... 0.5% Linearity:................................ 10% to 100% FS Thermal Drift:......................... 500 PPM/°C Operating Temperature:......... 0°C to +60°C Installation Category:............ CAT II Vibration Tested To:............... IEC 60068-2-6,1995 Pollution Degree:.................... 2 Response Time:..................... 250 ms max., 0-90% FS MTBF:.................................... Greater than 100 K hours Altitude:.................................. 2000 meter max. Calibration:............... Average Sensing, RMS Calibrated Insulation Voltage:................. 2500 VDC Power Source:....................... 24 VDC Frequency Range:................. 50Hz - 400Hz Output Load:.......................... 4-20 mADC - 0 to 300 Ω 0-5 VDC - 2K Ω or Greater 1 2 3 4 [25] .98 9 8 7 6 5 + + 1 2 3 4 + OUTPUT - - 9 8 7 OUTPUT + 6 5 - CR4410 One Element 0 - 5 VDC Output CR4411 One Element 0 - 10 VDC Output [28.3] 1.12 [3.3] .13 Top View Optional Mounting [36.6] 1.44 End View 9 8 7 6 5 [20.1] .79 [41.8] 1.65 CR4420 One Element 4 - 20 mADC Output L1 + OUTPUT 1 9 8 7 6 5 [62] 2.44 [30.8] 1.21 [19.8] [19.8] .78 .78 + - 5 SUPPLY L1 L2 L3 + OUTPUT 2 + OUTPUT 1 + L2 CR4460 Two Element 4 - 20 mADC Output + 1 2 3 4 9 8 7 6 5 SUPPLY CR4470 Three Element 0 - 5 VDC Output [76.7] [64.2] 3.02 2.53 [64] [76.7] 2.52 3.02 OUTPUT 1 7 L1 CR4410 CR4411 CR4420 [5.6] .22 TYP 8 SUPPLY L2 1 2 3 4 [6.6] .260 3 4 + + OUTPUT 3 [88.7] 3.49 [6.6] .26 9 - [76.6] 3.02 [13.5] .53 2 6 + [50.7] 2.00 [35] 1.38 OUTPUT 2 1 OUTPUT 2 - CR4450 Two Element 0 - 5 VDC Output [5.6] .22 TYP - + + 1 2 3 4 SUPPLY SUPPLY [73.1][83.3] 2.88 3.28 L1 OUTPUT 3 + - OUTPUT 2 + + L3 OUTPUT 1 - SUPPLY CR4480 L 2 Three Element 4 - 20 mADC Output *Request CR Magnetics Low & Medium Voltage Current Transformers Catalog. CONNECTION DIAGRAM CR4450 CR4460 CR4470 CR4480 OUTLINE DRAWING NOTE: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker shall be marked as the disconnecting device for the equipment. The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 39 C E-mail: sales@crmagnetics.com - Transducers DIN RAIL MOUNTING CLIP [26.6] 1.05 Cleaning:............................... Water-dampened cloth Relative Humidity:.................5% to 95%, Non-Condensing Supply Voltage:....................24 VDC ±10% Supply Current: CR4410/11...........................Typical 20mA Max 40mA CR4420................................Typical 25mA Max 45mA CR4450................................Typical 20mA Max 75mA CR4460................................Typical 40mA Max 90mA CR4470................................Typical 25mA Max 110mA CR4480................................Typical 55mA Max 120mA CR4410S..............................Typical ---mA Max -----mA CR4420S..............................Typical ---mA Max -----mA Torque Specs.:................ 3.0 inch lbs. (0.4Nm) Weight:.............................0.5 lbs.
CR4420-100
1. 物料型号:CR4410(S)、CR4411(S)、CR4420(S)、CR4450、CR4460、CR4470、CR4480。 2. 器件简介:CR4400系列电流变送器设计用于产生与平均RMS输入交流电流成比例的直流输出信号,适用于多点电流检测。 3. 引脚分配:文档中提供了不同型号的电流变送器的连接图,包括单元素、双元素和三元素变送器。 4. 参数特性:包括基本精度、线性度、热漂移、工作温度、安装类别、振动测试、污染等级、响应时间、MTBF、海拔高度、校准方式、绝缘电压、电源、频率范围、输出负载等。 5. 功能详解:CR4400系列电流变送器适用于多点电流检测和控制面板、监测电机故障、加热元件和照明元件。 6. 应用信息:适用于多点电流检测和控制面板,监测电机故障、加热元件和照明元件。 7. 封装信息:提供了DIN导轨或面板安装选项,以及不同元素和输出类型的变送器。
CR4420-100 价格&库存
很抱歉,暂时无法提供与“CR4420-100”相匹配的价格&库存,您可以联系我们找货
CR4420-100
  • 1+1283.737441+160.41546
