AC/DC Hall Effect Current Transducer
DIN RAIL / PANEL MOUNT, TRACING OUTPUT
The CR5400 Series, AC/DC Hall Effect Current Transducers,
are designed to provide a bipolar output that proportionally
reflects (traces) the waveform of the input current. These
devices are specifically targeted to be used in applications
where multi-mode current sensing is required.
Applications
Inverter and multi-frequency drives
Multi-mode ground paths carrying both AC and DC signals
Feed back loop building block
CR5410
C
Features
CR5411
Output isolated from input
Non-contact current sensing
35mm DIN Rail or Panel Mount
Connection diagram printed on case
Single Element - .79” Window
20 TO 600 AAC/DC Input Range
Regulatory Agencies
Transducers
Constructed to meet UL 61010B-1
Constructed to meet CAN/CSA-C22.2, No. 61010-1-2004
Meets requirement of IEC 61010-1 and BS EN 61010-1
E199795
All single phase current transducers are
available in split core design. Simply put an
“S” at the end of the prefix*
I.E. CR5410S-30
Add suffix for input range
PART NUMBERS
CR5410(S)
CR5411(S)
Single Element with ± 5 VAC/DC output (split core design)
Single Element with ± 10 VAC/DC output (split core design)
NOTE: AC/DC Split Core Transducers Available in 20 Amps and Higher
50
75
100
150
300
±20 AAC/ADC
±30 AAC/ADC
±50 AAC/ADC
±75 AAC/ADC
±100 AAC/ADC
±150 AAC/ADC
±300 AAC/ADC
Ranges available up to and
including 600 AAC/ADC
The Professional
Energy Monitoring
Company
M N TI
ISO 9001:2008 Quality Management System
3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119
Web: http://www.crmagnetics.com
50
E-mail: sales@crmagnetics.com
SPECIFICATIONS
Basic Accuracy:.......................
Linearity:...................................
Thermal Drift:...........................
Operating Temperature:...........
Installation Category:...............
Vibration Tested To:.................
Pollution Degree:.....................
Altitude:...................................
Insulation Voltage:...................
Cleaning:.................................
MTBF:.....................................
Supply Voltage:.......................
1.0 %
10% to 100% FS
500 PPM/°C
0°C to +50°C
CAT II
IEC 60068-2-6,1995
2
2000 meter max.
2500 VDC
Water-dampened cloth
Greater than 100K hours
24 VDC ±10%
Frequency Range:.........DC to 4 KHz
Output:........................... ±5 Vac/DC or ±10 Vac/DC
Output Load:................... 2 K Ω or greater
Relative Humidity:......... 5% to 95%, Non-Condensing
Supply Current:
CR5410:........................ Typical 35mA
Max 40mA
CR5410S:..................... Typical 30mA
Max 35mA
Torque Specs.:.............. 3.0 inch lbs. (0.4Nm)
Weight:.......................... 0.5 lbs.
C
[3.3]
.13
Optional
Mounting
DIN RAIL
MOUNTING
CLIP
[73.1]
2.88
[83.3]
3.28
OUTPUT
SUPPLY
[20.1]
.79
[41.8]
1.65
9
8
7
6
5
CR5410 ±5 VAC/VDC Output
CR5411 ±10 VAC/VDC Output
[76.6]
3.02
[50.7]
2.00
[5.6]
.22
TYP
CONNECTION DIAGRAM
[88.7]
3.49
[25]
.98
[28.3]
1.12
[36.6]
1.44
CRPS24VDC - 120
OUTLINE DRAWING
CRPS24VDC - 240
Power Supply
NOTE: The building installation must have a switch or circuit-breaker that is in close proximity and within easy reach of the operator. The switch or circuit breaker
shall be marked as the disconnecting device for the equipment.
The Professional
Energy Monitoring
Company
M N TI
51
Transducers
1
2
3
4
[26.6]
1.05
很抱歉,暂时无法提供与“CR5410-75”相匹配的价格&库存,您可以联系我们找货
