SC Type Fixed Attenuators (for single mode)
SC
HSC-AT11 Series
SC duplex adapter
Simplified SC receptacle SC plug
Simplified SC plug
HSC-AT11 Series
d
e
u
HSC-AT11 Series
Figure 1
n
i
t
n
Figure 2
■Features
d
e
2. For high input power : 250mW max
Harsh
Environment
o
c
is
1. SC Type : IEC 61754-4 (JIS C 5973)
MU
3. Ensure mating with simplified SC plug / receptacle. (figure 1).
t
d
b
o
4. Enables adjacently connection with horizontal duplex adapter. (figure 2)
5. AdPC, UPC and APC (Angled PC) polishing types are available.
e
l
u
6. Wide attenuation lineup. Both wavelength 1310nm & 1550nm are available.
d
e
h
Sc
■Applications
Attenuators
Power level adjustment of optical fiber communication networks.
Terminators
Oct.1.2021 Copyright 2021
Oct.1.2022
2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
FC
HSC-AT11 Series
SC plug
POF / PCF
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
79
HSC-AT11 Series●SC Type Fixed Attenuators(for single mode)
■Product Specifications
SC
●AdPC (Advanced PC) Polishing type: Return Loss ≥ 40dB
Ratings
Operating temperature range
-40°C to +75°C
Storage temperature range
-40°C to +85°C
Max. Input Power
250mW
Fiber type
SM
Mechanical Characteristics
Environment
MU
Oct.1.2022
Harsh
FC
Optical
Characteristics
Item
Test Method
Attenuation
See the attenuation table on the next page
Measurement at a point within wavelength of 1310±30
nm and a point within wavelength of 1550±30 nm.
Return Loss
≥40dB
Engagement and
Separation forces
Engagement and separation forces at 50mm/s.
Engagement force ≦ 19.6N
Separation force ≦ 19.6N
Gauge retention force
Zirconia gauge at φ2.499 ±0.0005mm.
2.0N to 3.9N
Durability
500 times
Flex test
8.82N load, 100 cycles
Telcordia GR-910-CORE
Twist test
13.23N load, 10 cycles
Side test
12.25 N load, 90° angle
Vibration
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 3
hours in each of the 3 axis.
Impact test
Acceleration of 981 m/s2, 6 ms duration,half sine shock
pulse, 3 cycles in each of the 3 axis.
Attenuators
Environmental
Characteristics
Heat/humidity cycles
Sc
Dray heat
Salt mist
Temperature : -40℃ to +80℃, 100 cycles
Terminators
1)Attenuation and return loss shall be satisfied
before and after the test.
2)N o b r e a k a g e , c r a c k o r l o o s e n e s s o n
components.
500 hours at 85℃.
500 hours at -40℃.
48 hours in a 5% concentration of salt mist
■Materials
POF / PCF
o
c
is
d
e
b
o
t
d
e
l
u
n
i
t
n
d
e
u
components.
Humidity : 90% to 96%
Temperature : -10℃ to 65℃
Time : 480 hours(20 Cycles)
d
e
h
Heat cycles
Cold
80
Requirments
Part
Material
Body
Zinc alloy
Ferrule
Zirconia
Split sleeve
Zirconia
No significant corrosion.
Y7
SC
HZg^VaCd#
FC
Attenuation
Attenuation
Tolerance
HSC-AT11K-A00
820-6001-6
0dB
+0.4dB
HSC-AT11K-A01
820-6002-9
1dB
±0.5dB
HSC-AT11K-A02
820-6003-1
2dB
±0.5dB
HSC-AT11K-A03
820-6004-4
3dB
±0.6dB
HSC-AT11K-A04
820-6005-7
4dB
±0.6dB
HSC-AT11K-A05
820-6006-0
5dB
±0.6dB
HSC-AT11K-A06
820-6007-2
6dB
±0.6dB
HSC-AT11K-A07
820-6013-5
7dB
±0.7dB
HSC-AT11K-A08
820-6014-8
8dB
±0.8dB
HSC-AT11K-A09
820-6015-0
9dB
±0.9dB
HSC-AT11K-A10
820-6008-5
10dB
±1.0dB
HSC-AT11K-A11
820-6016-3
11dB
HSC-AT11K-A12
820-6017-6
12dB
HSC-AT11K-A13
820-6018-9
HSC-AT11K-A14
820-6019-1
HSC-AT11K-A15
820-6009-8
ch
820-6020-0
HSC-AT11K-A20
820-6010-7
HSC-AT11K-A25
820-6011-0
HSC-AT11K-A30
820-6012-2
S
15dB
≥40dB
n
i
t
n
o
c
is
1310nm
1550nm
Zirconia
SM
d
e
u
mauve
±1.2dB
±1.3dB
±1.4dB
Attenuators
ed
HSC-AT11K-A16
14dB
±1.1dB
Wavelength Split Sleeve Fiber type Label color
d
e
b
o
t
d
e
l
u
13dB
Return
Loss
Harsh
Environment
CL No.
Part Number
MU
±1.5dB
16dB
±1.5dB
20dB
±1.5dB
25dB
±1.5dB
30dB
±2.5dB
Terminators
Oct.1.2022
POF / PCF
81
SC
●UPC Polishing type : Return Loss ≥ 50dB
●APC Polishing type : Return Loss ≥ 60dB
Ratings
-40°C to +75°C
-40°C to +85°C
Max. Input Power
250mW
Fiber type
SMF
Item
Test Method (Telcordia GR-910-CORE)
Specifications
UPC
Attenuation
Return Loss
Input power
Uncontrolled Operating
Environment
Environmental characteristics
Environment
Non-Operating
Environment
Humidity/Condensation
Cycling Test
Attenuators
Water Immersion
Mechanical characteristics
Terminators
Input power : 250mW(LD)
Wavelength : 1470nm
Time : 100 hours
Temperature : -5 to 50 ℃
Time : 182.5 hours
Humidity : 15 to 90 %
Temparature : -40 to 75 ℃
Cycles : 21 cycles ( 8h/cycle)
Low-Temperture Exposure and Thermal Shock
Temperature
: 23 → −40 → −40 → 23
Time
: 2.1h 72h 4min
High-Temperture Exposure and Thermal Shock
Temperature
: 23 → 70 → 70 → 23
Time
: 1.6h 72h 5min
High Relative Humidity Exposure
Temperature
: 23 → 40 → 40 → 23
Time
: 0.6h 96h 0.6h
Humidity
: 90 to 95 %
Temperature
: -10 to 65 ℃
Humidity
: 90 to 100 %
Cycles
: 14 cycles(12h/cycle)
Temperature
: 43 ℃
Time
: 168 h
Water
: PH 5.5
Frequency range : 10 to 55 Hz
Amplitude
: 1.52mm
Time
: 2 hours in each 3 axis
d
e
h
Vibration Test
Sc
Side Pull Load
e
l
u
t
d
Angle : 90 °
Load : 12.25 N
POF / PCF
n
i
t
n
d
e
u
1)After test, change in attenuation (fluctuation)
and return loss shall be as follows.
attenuation : ≤0.5dB
return loss ≥50dB
o
c
is
d
e
b
o
2)No distortion, package cracks, hardening or
softening of materials, and also no damage to
the attenuation element.
1)During, after test, change in attenuation
(fluctuation) and return loss shall be as follows.
return loss ≥50dB
Cable Retention
Load : 19.6N
Durability
200 times
return loss ≥50dB
Impact Test
Drop the tested components from 1.8 m hight to the
concrete floor.
8 times in each 3 axis
Note) APC polishing type isn’t compatible with UPC polishing type.
82
APC
Measurement at a point within wavelength of 1310±30 nm See the attenuation table on the next page
≥50dB
≥60dB
Controlled Operating
Environment
MU
Oct.1.2022
Harsh
FC
Optical
characteristics
Polishing type
Y7
HZg^VaCd#
SC
FC
(APC Polishing type)
6
;ZggjaZZcY[VXZ\ZdbZign
n
i
t
n
UPC Polishing type: Return Loss ≥ 50dB
Part Number
820-9500-2
820-9501-5
820-9502-8
820-9503-0
820-9504-3
820-9505-6
820-9506-9
820-9507-1
820-9508-4
820-9509-7
820-9510-6
820-9511-9
820-9512-1
820-9513-4
820-9514-7
820-9515-0
820-9516-2
820-9517-5
820-9518-8
820-9519-0
0dB
1dB
2dB
3dB
4dB
5dB
6dB
7dB
8dB
9dB
10dB
11dB
12dB
13dB
14dB
15dB
16dB
20dB
25dB
30dB
Sc
d
e
h
Attenuation
Tolerance
+0.4dB
±0.5dB
±0.5dB
±0.6dB
±0.6dB
±0.6dB
±0.6dB
±0.7dB
±0.8dB
±0.9dB
±1.0dB
±1.1dB
±1.2dB
±1.3dB
±1.4dB
±1.5dB
±1.5dB
±1.5dB
±1.5dB
±2.5dB
o
c
is
d
e
b
o
t
d
e
l
u
Return
Loss
≥50dB
1310nm
1550nm
Zirconia
SM
Dark blue
Attenuators
Attenuation
Harsh
Environment
HSC-AT11U-A00
HSC-AT11U-A01
HSC-AT11U-A02
HSC-AT11U-A03
HSC-AT11U-A04
HSC-AT11U-A05
HSC-AT11U-A06
HSC-AT11U-A07
HSC-AT11U-A08
HSC-AT11U-A09
HSC-AT11U-A10
HSC-AT11U-A11
HSC-AT11U-A12
HSC-AT11U-A13
HSC-AT11U-A14
HSC-AT11U-A15
HSC-AT11U-A16
HSC-AT11U-A20
HSC-AT11U-A25
HSC-AT11U-A30
CL No.
d
e
u
MU
APC Polishing type: Return Loss ≥ 60dB
CL No.
Attenuation
HSC-AT11CS-A01
HSC-AT11CS-A02
HSC-AT11CS-A03
HSC-AT11CS-A04
HSC-AT11CS-A05
HSC-AT11CS-A06
HSC-AT11CS-A07
HSC-AT11CS-A08
HSC-AT11CS-A09
HSC-AT11CS-A10
HSC-AT11CS-A11
HSC-AT11CS-A12
HSC-AT11CS-A13
HSC-AT11CS-A14
HSC-AT11CS-A15
HSC-AT11CS-A16
HSC-AT11CS-A20
HSC-AT11CS-A25
HSC-AT11CS-A30
820-9001-2
820-9002-5
820-9003-8
820-9004-0
820-9005-3
820-9006-6
820-9007-9
820-9008-1
820-9009-4
820-9010-3
820-9011-6
820-9012-9
820-9013-1
820-9014-4
820-9015-7
820-9016-0
820-9017-2
820-9018-5
820-9019-8
1dB
2dB
3dB
4dB
5dB
6dB
7dB
8dB
9dB
10dB
11dB
12dB
13dB
14dB
15dB
16dB
20dB
25dB
30dB
Attenuation
Tolerance
+0.8dB
±0.8dB
±0.8dB
±0.8dB
±0.8dB
±0.8dB
±0.8dB
±0.8dB
±0.9dB
±1.0dB
±1.1dB
±1.2dB
±1.3dB
±1.4dB
±1.5dB
±1.5dB
±1.5dB
±1.5dB
±2.5dB
Return
Loss
≥60dB
1310nm
1550nm
Zirconia
SM
Green
POF / PCF
Part Number
Terminators
Oct.1.2022
6
83
很抱歉,暂时无法提供与“HSC-AT11CS-A10”相匹配的价格&库存,您可以联系我们找货
