SC
FC Type Fixed Attenuators
■Features
1. FC Type :Comply with IEC 61754-13 (JIS C
5970)
2. Maximum input power for SM :250mW
FC
3. Polishing Type : AdPC(SM), PC(GI)
Notice:
Plug key width: 2.1mm
Jack key width: 2.2mm
■Applications
MU
Nov.1.2022
Oct.1.2021 Copyright
Copyright 2021
2022 HIROSE
HIROSE ELECTRIC
ELECTRIC
CO.,
CO., LTD.
LTD. All
All Rights
Rights Reserved.
Reserved.
Harsh
4. Dual wavelength (SM): 1310nm and 1550nm
n
i
t
n
d
e
u
Environment
Power level adjustment of optical fiber communication networks.
Max. Input Power
ed
Mechanical
Characteristis
Optical
Characteristis
Attenuators
Terminators
h
c
S
Attenuation
Return Loss
e
l
u
-25°C to +70°C
Storage temperature range
Single mode : 250mW
Multi mode : 10mW
Test Method
Wavelength 1310±30nm
Wavelength 1550±30nm
Adapter gauge holding force
Zirconia gauge of 2.499 ±0.0005 mm diameter.
Durability
(cycles, mating/unmating)
500 times
Vibration
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm,
2
acceleration of 98.1m/s , 3 hours in each of the 3 axis.
Shock
Environmental
Characteristis
b
o
t
d
Operating temperature range
Item
POF / PCF
d
e
■Product Specification (For Single mode /For Multi mode)
Ratings
86
o
c
is
Acceleration of 981 m/s2, 6 ms duration, sine halfwave waveform, 3 cycles in each of the 3 axis.
Composite temperrature
-Humidity cyclic test
Humidity : 90% to 96%
Temperature : -10℃ to 65℃ ,
Time : 240 hours(10 Cycles)
Change of temperature
Temperature : -25℃ to +70℃ , 100 cycles,
Dry heat
500 hours at +85°C
Cold
500 hours at -25°C
Salt mist
48 hours in a 5% concentration of salt mist
-25°C to +85°C
Single mode :SM
Fiber type
Multi mode:GI-50/125
Specifications
For Single mode
See the attenuation
table on the next page
≧ 40dB(AdPC)
2 to 3.9N
For Multi mode
Attenuation ±1.5dB
≧ 22dB(PC)
2 to 5.9N
1) Meets Attenuation/Return Loss
requirements.
2) No visible dislocation of clamp or cable.
No significant corrosion.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
■Materials
For Single mode
For Multi mode
Coupling
Copper alloy
Body
Stainless steel
Ferrule
SC
Material
Part
Zirconia
Split sleeve
Zirconia
Phosphor Bronze
FC
■FC Type Fixed Attenuator
Ø10
FC-
n
i
t
n
(HRFC-AT11K~)30
(HRFC-AT1S~)27.8
CL No.
Attenuation
CL820-8001-7-60
1dB
HRFC-AT11K-A02(60)
CL820-8002-0-60
2dB
HRFC-AT11K-A03(60)
CL820-8003-2-60
3dB
HRFC-AT11K-A04(60)
CL820-8004-5-60
4dB
HRFC-AT11K-A05(60)
CL820-8005-8-60
5dB
HRFC-AT11K-A06(60)
CL820-8006-0-60
6dB
HRFC-AT11K-A07(60)
CL820-8007-3-60
7dB
HRFC-AT11K-A08(60)
CL820-8008-6-60
8dB
HRFC-AT11K-A09(60)
CL820-8009-9-60
9dB
CL820-8010-8-60
10dB
CL820-8011-0-60
15dB
CL820-8012-3-60
20dB
CL820-8013-6-60
25dB
ed
HRFC-AT11K-A10(60)
HRFC-AT11K-A15(60)
ch
HRFC-AT11K-A20(60)
S
HRFC-AT11K-A25(60)
Attenuation Tolerance
d
e
± 0.5dB
b
o
± 0.6dB
t
d
e
l
u
Return Loss
≥40dB
± 10%
Wavelength
Split sleeve
Fiber type
Label color
Zirconia
SM
Mauve
Split sleeve
Fiber type
Label color
GI-50/125
Yellow
1310nm
1550nm
Attenuators
Part Number
HRFC-AT11K-A01(60)
Harsh
Environment
o
c
is
For Single mode(AdPC Polishing type,Maximum input power :250mW)
d
e
u
MU
± 1.5dB
For Multi mode(PC Polishing type, Maximum input power 10mW)
Part Number
CL No.
Attenuation
HRFC-AT1S-B05A(60)
820-0063-0-60
5dB
HRFC-AT1S-B10A(60)
820-0064-3-60
10dB
HRFC-AT1S-B15A(60)
820-0065-6-60
15dB
HRFC-AT1S-B20A(60)
820-0066-9-60
20dB
Return Loss
Wavelength
± 1.5dB
≥22dB
1310nm
Phosphor
Bronze
Terminators
Nov.1.2022
Copyright 2021
2022 HIROSE
HIROSE ELECTRIC
ELECTRIC CO.,
CO., LTD.
LTD. All
All Rights
Rights Reserved.
Reserved.
M8×0.75
POF / PCF
87
很抱歉,暂时无法提供与“HRFC-AT1S-B10A(60)”相匹配的价格&库存,您可以联系我们找货
