A1-26PA-2.54DSA(71)
A1-26PA-2.54DSA(71)
    HRS(广濑)
A1-26PA-2.54DSA(71) 数据手册
2.54mm Pitch High Density Connector A1 and A2 Series ■Features 1. High Density Mounting Connectors are aligned in the longitudinal direction on the 2.54 mm mesh board, so that no idle space can occur. 2. Variation in Number of Contacts The A1 series contains 16 types of 6 to 64 contacts, while the A2 series contains 20 types of 1 to 20 contacts, 3. Compatibility Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The A1 series is compatible with HIF3B series cable side and HIF3H receptacle for wide applications. ■Product Specifications Rating Current rating: 3A Operating Temperature Range: Voltage rating: 200V AC Operating Moisture Range: Item -55 to +85ç (Note 1) Storage Temperature Range: -10 to +60ç (Note 2) 40 to 80% Storage Humidity Range: Specification 1. Insulation Resistance 1000M ohms min. 40 to 70% (Note 2) Condition 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute 3. Contact Resistance 15m ohms max. 0.1A 4. Vibration No electrical discontinuity of 1μs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5.Humidity (Steady state) Insulation resistance 1000M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% 6. Temperature Cycle No damage, cracks, or parts looseness. 7. Operating Life Contact resistance: 15m ohms max. 8. Resistance to Soldering heat No deformation of components affecting performance. (-65ç: 30 minutes ➝15 to 35ç: 5 minutes max.➝ 125ç: 30 minutes➝ 15 to 35ç: 5 minutes max.) 5 cycles 500 cycles Solder bath: 260ç for 10 seconds Manual soldering: 350ç for 3 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Applications Computers, VTR, and other various kinds of electronic equipment ■Material Part Pin header C2 Material Finish Remarks Insulator PBT Black UL94V-0 Contact Brass Crimping socket Polyamid Crimping contact Phosphor bronze Contact area : gold plated DIP area : tin plated Black Contact area ––––––– UL94V-0 : gold plated Termination area : nickel plated ––––––– A1 and A2 Series●2.54mm Pitch High Density Connector ■ Ordering Information K Pin Header A 1 - 6 P A - 2.54 DS q w e r t y u q Series Name: A w Series No.:1 (double row) e Number of contacts: A1...6, 8, 10, 12, 14, 16, 20, 24, 26, 2 (single row) 34, 40, 50, 60, 64 A2...1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 13, 14, 15, 16, 17, 18, 19, 20 r P: Pin header t A: Selective gold plated y Contact pitch : 2.54mm u Contact type: DS : Right angle type DSA : Straight type K Crimping Socket A 1 - 12 D - 2.54 C q w e r t y q Series Name : A w Series No. : 1 (double row) e Number of contacts: A1 : 8, 10, 12 r Contact alignment : A1 : D (double row) t Contact pitch : 2.54mm y Connection type: C : crimping q Series Name : A w Series No. : 1 e Applicable cable size 2 (single row) A2 : 5, 6 A2 : S (single row) K Crimping Contact A 1 - 2630 - SCFC q w e r 2226: AWG#22~ AWG#26 2630: AWG#26~ AWG#30 r Packaging type SCFC : Reel SCC : Bag C3 A1 and A2 Series●2.54mm Pitch High Density Connector ■ A1 (Double Row)- Right Angle Type 2.54±0.05 Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BPCB mounting pattern B±0.1 2.54±0.05 Ø0.8 +0.1 0 Unit: mm Part Number C4 CL No. Number of Contacts A B RoHS Unit: mm Part Number CL No. Number of Contacts A B RoHS A1-06PA-2.54DS(71) 619-0001-7-71 6 07.62 05.08 A1-26PA-2.54DS(71) 619-0009-9-71 26 33.02 30.48 A1-08PA-2.54DS(71) 619-0016-4-71 8 10.16 07.62 A1-30PA-2.54DS(71) 619-0010-8-71 30 38.10 35.56 A1-10PA-2.54DS(71) 619-0002-0-71 10 12.70 10.16 A1-34PA-2.54DS(71) 619-0011-0-71 34 43.18 40.64 A1-12PA-2.54DS(71) 619-0003-2-71 12 15.24 12.70 A1-40PA-2.54DS(71) 619-0012-3-71 40 50.80 48.26 YES A1-14PA-2.54DS(71) 619-0004-5-71 14 17.78 15.24 A1-50PA-2.54DS(71) 619-0013-6-71 50 63.50 60.96 A1-16PA-2.54DS(71) 619-0005-8-71 16 20.32 17.78 A1-60PA-2.54DS(71) 619-0014-9-71 60 76.20 73.66 A1-18PA-2.54DS(71) 619-0006-0-71 18 22.86 20.32 A1-64PA-2.54DS(71) 619-0015-1-71 64 81.28 78.74 A1-20PA-2.54DS(71) 619-0007-3-71 20 25.40 22.86 Note: Right side and left side rib is added for 34pos, or more. YES A1 and A2 Series●2.54mm Pitch High Density Connector BPCB mounting pattern 2.54±0.05 Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ A1 (Double Row)- Straight Type B±0.1 2.54±0.05 Ø0.8 +0.1 0 Unit: mm Part Number CL No. Number of Contacts A B A1-06PA-2.54DSA(71) 619-0021-4-71 6 07.32 05.08 A1-08PA-2.54DSA(71) 619-0037-4-71 8 09.86 07.62 A1-10PA-2.54DSA(71) 619-0022-7-71 10 12.40 10.16 A1-12PA-2.54DSA(71) 619-0023-0-71 12 14.94 12.70 A1-14PA-2.54DSA(71) 619-0024-2-71 14 17.48 15.24 A1-16PA-2.54DSA(71) 619-0025-5-71 16 20.02 17.78 A1-18PA-2.54DSA(71) 619-0026-8-71 18 22.56 20.32 A1-20PA-2.54DSA(71) 619-0027-0-71 20 25.10 22.86 A1-24PA-2.54DSA(71) 619-0028-3-71 24 30.18 27.94 A1-26PA-2.54DSA(71) 619-0029-6-71 26 32.72 30.48 A1-30PA-2.54DSA(71) 619-0030-5-71 30 37.80 35.56 A1-34PA-2.54DSA(71) 619-0031-8-71 34 42.88 40.64 A1-40PA-2.54DSA(71) 619-0032-0-71 40 50.50 48.26 A1-50PA-2.54DSA(71) 619-0033-3-71 50 63.20 60.96 A1-60PA-2.54DSA(71) 619-0034-6-71 60 75.90 73.66 A1-64PA-2.54DSA(71) 619-0035-9-71 64 80.98 78.74 RoHS YES C5 A1 and A2 Series●2.54mm Pitch High Density Connector ■ A2 (Single Row)-DIP Type K Straight type Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BPCB mounting pattern K Right angle type B±0.1 2.54±0.05 Ø0.8 +0.1 0 K Straight type Part Number C6 Unit: mm CL No. Number of Contacts A B – A2-01PA-2.54DSA(71) 620-0051-5-71 1 02.24 A2-02PA-2.54DSA(71) 620-0052-8-71 2 04.78 02.54 A2-03PA-2.54DSA(71) 620-0053-0-71 3 A2-04PA-2.54DSA(71) 620-0054-3-71 4 A2-05PA-2.54DSA(71) 620-0055-6-71 5 A2-06PA-2.54DSA(71) 620-0056-9-71 6 A2-07PA-2.54DSA(71) 620-0057-1-71 7 A2-08PA-2.54DSA(71) 620-0058-4-71 8 A2-09PA-2.54DSA(71) 620-0059-7-71 RoHS K Right angle type Part Number CL No. Unit: mm Number of Contacts A B – A2-01PA-2.54DS(71) 620-0001-7-71 1 02.24 A2-02PA-2.54DS(71) 620-0002-0-71 2 04.78 02.54 07.32 05.08 A2-03PA-2.54DS(71) 620-0003-2-71 3 07.32 05.08 09.86 07.62 A2-04PA-2.54DS(71) 620-0004-5-71 4 09.86 07.62 12.40 10.16 A2-05PA-2.54DS(71) 620-0005-8-71 5 12.40 10.16 14.94 12.70 A2-06PA-2.54DS(71) 620-0006-0-71 6 14.94 12.70 17.48 15.24 A2-07PA-2.54DS(71) 620-0007-3-71 7 17.48 15.24 20.02 17.78 A2-08PA-2.54DS(71) 620-0008-6-71 8 20.02 17.78 9 22.56 20.30 A2-09PA-2.54DS(71) 620-0009-9-71 9 22.56 20.30 A2-10PA-2.54DSA(71) 620-0060-6-71 10 25.10 22.86 A2-10PA-2.54DS(71) 620-0010-8-71 10 25.10 22.86 A2-11PA-2.54DSA(71) 620-0061-9-71 11 27.64 25.40 A2-11PA-2.54DS(71) 620-0011-0-71 11 27.64 25.40 A2-12PA-2.54DSA(71) 620-0062-1-71 12 30.18 27.94 A2-12PA-2.54DS(71) 620-0012-3-71 12 30.18 27.94 A2-13PA-2.54DSA(71) 620-0063-4-71 13 32.72 30.48 A2-13PA-2.54DS(71) 620-0013-6-71 13 32.72 30.48 A2-14PA-2.54DSA(71) 620-0064-7-71 14 35.26 33.02 A2-14PA-2.54DS(71) 620-0014-9-71 14 35.26 33.02 A2-15PA-2.54DSA(71) 620-0065-0-71 15 37.80 35.56 A2-15PA-2.54DS(71) 620-0015-1-71 15 37.80 35.56 A2-16PA-2.54DSA(71) 620-0066-2-71 16 40.34 38.10 A2-16PA-2.54DS(71) 620-0016-4-71 16 40.34 38.10 A2-17PA-2.54DSA(71) 620-0067-5-71 17 42.88 40.64 A2-17PA-2.54DS(71) 620-0017-7-71 17 42.88 40.64 A2-18PA-2.54DSA(71) 620-0068-8-71 18 45.42 43.18 A2-18PA-2.54DS(71) 620-0018-0-71 18 45.42 43.18 A2-19PA-2.54DSA(71) 620-0069-0-71 19 47.96 45.72 A2-19PA-2.54DS(71) 620-0019-2-71 19 47.96 45.72 A2-20PA-2.54DSA(71) 620-0070-0-71 20 50.50 48.26 A2-20PA-2.54DS(71) 620-0020-1-71 20 50.50 48.26 YES RoHS YES A1 and A2 Series●2.54mm Pitch High Density Connector ■ Crimping Socket K Double Row Type Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A1-*D-2.54C Part Number CL No. A B A1-08D-2.54C 619-0093-5 10.16 07.62 RoHS A1-10D-2.54C 619-0091-0 12.70 10.16 A1-12D-2.54C 619-0092-2 15.24 12.70 YES K Single Row Type A2-*S-2.54C Part Number CL No. A B A2-5S-2.54C 620-0101-1 12.70 10.16 A2-6S-2.54C 620-0102-4 15.24 12.70 RoHS YES C7 A1 and A2 Series●2.54mm Pitch High Density Connector ■ Crimping Contact SCFC contact Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part Number CL No. A1-2226SCFC 619-0211-0 A1-2226SCC 619-0214-8 A1-2630SCFC 619-0212-2 A1-2630SCC 619-0215-0 Gold plated area Gold plated area SCC contact Applicable Cable Packaging Type AWG#22 to #26 AWG#26 to #30 Quantity A B C D E F RoHS Reel 10,000 11.5 0.8 1.8 1.80 2.3 2.6 Bag 100 11.5 0.8 1.8 1.80 2.3 2.6 Reel 10,000 11.5 0.8 1.4 1.35 2.0 2.1 Bag 100 11.5 0.8 1.4 1.35 2.0 2.1 YES ■ Polarizing Key HIF3-GPIN(A) Part Number CL No. Material Remarks HIF3-GPIN(A) 562-0126-6 Poly acetal (white) 5 pieces set Packaging RoHS 4 sets YES ■ Crimping Tools Part Number Manual crimping tool Crimper unit Applicator C8 CL No. Applicable Contact Applicable Cable HIF3-TB2226HC 550-0154-1 A1-2226SCC AWG#22 to #26 HIF3-TB2630HC 550-0155-4 A1-2630SCC AWG#26 to #30 ––––––––– ––––––––– AP105-A1-2226S 901-4008-4 A1-2226SCFC ––––––––– AP105-A1-2630S 901-4009-7 A1-2630SCFC ––––––––– CM-105 901-0005-4 A1 and A2 Series●2.54mm Pitch High Density Connector Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Short Pin ■ Performance Item Rating Value Part Number CL No. RoHS Contact Resistance 30m ohms max. at 0.1A DC HIF3GA-2.54SP 562-0403-4 YES Insulation Resistance 1000M ohms min. at 500V DC Current rating 3A C9
A1-26PA-2.54DSA(71) 价格&库存
很抱歉,暂时无法提供与“A1-26PA-2.54DSA(71)”相匹配的价格&库存,您可以联系我们找货
