HIF3F-20PA-2.54DS(71) 数据手册
Box type Pin Header to Prevent Mis-insertion
HIF3F Series
■Features
1. Prevent to Reverse Insertion
The pin header to prevent reverse insertion is equipped
with contact protective walls to the HIF3E series.
2. Compatibility
This pin header is compatible with HIF3B series.
■Applications
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Computers, terminal equipment, PPC, various kinds of
electronic equipment, office automation machines, etc.
■Product Specifications
Operating Temperature Range:–55 to +85ç (Note 1)
Operating Moisture Range:40 to 80%
Current rating: 1A
Voltage rating: 200V AC
Rating
Item
Storage Temperature Range:–10 to +60ç(Note 2)
Storage Humidity Range:40 to 70% (Note 2)
Specification
Condition
1. Insulation Resistance 1000M ohms min.
500V DC
2. Withstanding voltage No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance 15m ohms max.
0.1A
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
No electrical discontinuity of 1μs or more
4. Vibration
5. Humidity (Steady state) Insulation resistance: 1000M ohms min.
96 hours at temperature of 40ç and humidity of 90% to 95%
6. Temperature Cycle No damage, cracks, or parts looseness.
(–55ç: 30 minutes ➝15 to 35ç: 5 minutes max.
125ç: 30 minutes ➝15 to 35ç: 5 minutes max.) 5 cycles
7. Durability (Mating/un-mating) Contact resistance15m ohms max.
500 cycles
8. Resistance to
Solder bath: 260ç for 10 seconds
No deformation of components affecting performance.
Soldering heat
Manual soldering: 360ç for 5 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range
and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3: Information contained in this catalog represents general requirements for this Series.Contact us for the drawings and
specifications for a specific part number shown.
■Material
Part
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Contact
Brass
Selective gold plating over nickel underplated
■Ordering Information
HIF3F
1
- * P A - 2.54 DS
2
1 Series Name: HIF3F
2
Number of contacts: 10, 16, 20, 26, 30, 34, 40, 50, 60
3 P: Pin header
4 A: Selective gold plating
B44
3
4
5
6
5 Contact Pitch: 2.54mm
6 Terminal type DS: Right angle type
DSA: Straight type
HIF3F Series●Box type Pin Header to Prevent Mis-insertion
■Straight Pin Header
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
HIF3F-10PA-2.54DSA(71) 615-0061-3-71
10
20.5
17.5
10.16
HIF3F-16PA-2.54DSA(71) 615-0062-6-71
16
28.1
25.1
17.78
HIF3F-20PA-2.54DSA(71) 615-0063-9-71
30.2
22.86
HIF3F-26PA-2.54DSA(71) 615-0064-1-71
26
40.8
37.8
30.48
HIF3F-30PA-2.54DSA(71) 615-0065-4-71
30
45.9
42.9
35.56
HIF3F-34PA-2.54DSA(71) 615-0066-7-71
34
51.0
48.0
40.64
HIF3F-40PA-2.54DSA(71) 615-0067-0-71
40
58.6
55.6
48.26
HIF3F-50PA-2.54DSA(71) 615-0068-2-71
50
71.3
68.3
60.96
HIF3F-60PA-2.54DSA(71) 615-0069-5-71
60
84.0
81.0
73.66
RoHS
YES
Note: The slot size for false-insertion for 50 contact and 60 contact connectors is 26.96.
B45
■Right Angle Pin Header
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
HIF3F-10PA-2.54DS(71)
615-0041-6-71
10
20.5
17.5
10.16
HIF3F-16PA-2.54DS(71)
615-0042-9-71
16
28.1
25.1
17.78
615-0043-1-71
30.2
22.86
HIF3F-26PA-2.54DS(71)
615-0044-4-71
26
40.8
37.8
30.48
HIF3F-30PA-2.54DS(71)
615-0045-7-71
30
45.9
42.9
35.56
HIF3F-34PA-2.54DS(71)
615-0046-0-71
34
51.0
48.0
40.64
HIF3F-40PA-2.54DS(71)
615-0047-2-71
40
58.6
55.6
48.26
HIF3F-50PA-2.54DS(71)
615-0048-5-71
50
71.3
68.3
60.96
HIF3F-60PA-2.54DS(71)
615-0049-8-71
60
84.0
81.0
73.66
B46
RoHS
YES
HIF3F-20PA-2.54DS(71) 价格&库存
很抱歉,暂时无法提供与“HIF3F-20PA-2.54DS(71)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+31.430251+3.89919
- 10+28.5164510+3.53771
- 360+21.98551360+2.72749
- 720+21.35751720+2.64958
- 1080+18.216671080+2.25993
- 5040+16.332175040+2.02614
