BJ376HS
BJ376HS
    CINCH
BJ376HS 数据手册
PY 5/8 HEX NUT O 1/2-28 UNEF-2A O .687 C 4 ED 7/16 WRENCH FLATS INTERFACE PER MIL-STD-348 FIGURE 202-2 .840 TR O LL .15 C NOTES: UNLESS OTHERWISE SPECIFIED. O N 1.09 .221 .218 O .510 .505 2. MAX PANEL THICKNESS: .160 N 1. FINISH: PASSIVATED STAINLESS STEEL. U 3. CONCENTRIC TWINAX/TRIAX BULKHEAD MOUNT RECEPTACLE. 3RD ANGLE PROJECTION RoHS 4. DIMPLE INDICATES CENTER CONTACT TAB. 5. LEAKAGE RATE: 1 X 10^-8 ATM CC/SEC MAXIMUM OF INERT GAS (HELIUM) IAW MIL-STD-1344, REV A, METHOD 1008, TEMP. RANGE -45.6vC TO +71vC. RECOMMENDED PANEL CUTOUT This PROPRIETARY Document is property of Emerson Network Power Connectivity Solutions. It is confidential in nature, non-transferable, and issued with the clear understanding that it is not traced or copied without permission and is returnable upon demand. INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. Trompeter Title: BJ376HS 2002/95/EC UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX u.03 .XXX u.005 ANGLES u1v Model No. Size A BJ376HS DO NOT SCALE Date: 1/31/2013 DRAWING Sheet 1 of 1
BJ376HS 价格&库存
很抱歉,暂时无法提供与“BJ376HS”相匹配的价格&库存,您可以联系我们找货
