CR3110-3000
CR3110-3000
    CR
CR3110-3000 数据手册
Split Core Current Transformer CR3100 Series The CR3100 Series Split Core Current Transformer is designed to provide a low cost method to monitoring electrical current. A unique hinge and locking snap allows attachment without interrupting the current-carrying wire. High secondary turn will develop signals up to 10.0 VAC across a burden resistor. CR3110-3000 Current Transformers CR3109-1500 F Applications Portable Instruments Sub-Metering Monitor Motor Loads Features Small Size Low Cost High Secondary Turns Secure Locking Hinge CR3111-3000 CR3113-2000 Specifications Maximum Continuous Primary Current Insulation Voltage Storage Temp. Operating Temp. PART NUMBERS CR3109 CR3110 CR3111 CR3113 - 1500 3000 3000 2000 30 AMP 75 AMP 100 AMP 150 AMP 4 X Ir 3500 Vac/1min -45°C thru +85°C -40°C thru +65 °C Regulatory Agencies SPLIT CORE CURRENT TRANSFORMERS Part Number CR3109-1500 CR3110-3000 CR3111-3000 CR3113-2000 Imax 30 75 100 150 Vmax RMS 5 15 19 16 DCR Ω 187 440 390 58 Te (typ.) 1510 3100 3150 2125 Frequency 20 - 1 KHz 20 - 1 KHz 20 - 1 KHz 20 - 1 KHz CR3110-3000 ONLY Ir = Maximum Input Current to be linearly sensed Vmax = Maximum Voltage (Saturation) CT will develop Te = Effective turns ratio including losses (All Specifications tested at 60 Hz) I DCR R OUTLINE DRAWING A B D E VL = Vmax C - I x DCR Te V= V IxR Te For best linearity, choose R such that V < 0.8 VL F VL Part Number CR3109-1500 CR3110-3000 CR3111-3000 CR3113-2000 The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System A B C D E F 0.76 (19.2) 1.00 (25.5) 1.24 (31.4) 2.68 (68.7) 0.19 (4.90) 0.40 (10.2) 0.62 (15.7) 0.98 (24.9) 1.24 (31.5) 1.57 (40.0) 1.77 (45.0) 2.56 (65.0) 6.10 (1.55) 5.91 (150) 6.10 (155) 118 (3000) 0.82 (20.8) 1.04 (26.5) 1.22 (31.0) 0.72 (18.4) 0.20 (5.08) 0.24 (6.10) 0.20 (5.08) 0.20 (5.08) I 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 102 E-mail: sales@crmagnetics.com
CR3110-3000
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一种光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光电耦合器,具有较高的输入电流驱动能力和高速响应特性。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚Vcc。
4. 参数特性:主要参数包括Vf(正向电压)小于1.2V,Ic(集电极电流)最大100mA,Ctr(电流传输比)最小100%。
5. 功能详解:EL817通过光电效应实现电信号隔离,适用于开关电源、测量设备等。
6. 应用信息:广泛应用于工业控制系统、医疗设备、通信设备等领域。
7. 封装信息:采用DIP-6封装形式。
CR3110-3000 价格&库存
很抱歉,暂时无法提供与“CR3110-3000”相匹配的价格&库存,您可以联系我们找货
CR3110-3000
  • 1+185.925981+23.31348
  • 10+167.4781910+21.00029
  • 25+160.5748025+20.13467
  • 50+155.5191750+19.50074
  • 100+150.60324100+18.88432
  • 250+144.31919250+18.09636
  • 500+139.72396500+17.52016
库存:2252
