CR2550-R
CR2550-R
    CR
CR2550-R 数据手册
Low Cost Remote Current Indicator The CR2550 Series Remote Current Indicators are designed as a low cost method for providing a visual indication of electrical current flow. The current-carrying wire is routed through the window opening in the current sensing transformer. Attached to the transformer is a high efficiency, bipolar LED that illuminates when the current is above the turnon point. The indicator is available as standard with an 11 inch long lead and a red, green, blue, white, amber or yellow LED indicator. CR2550 Series Applications PART NUMBERS Monitor Status of Heater Elements Observe Remote Loads Indicate Phase Loss Monitor Motor Operation Part Number LED Color Turn On Point (1 pass) CR2550-R Red 0.75 AAC CR2550-G Green 1.5 AAC CR2550-B Blue 1.0 AAC CR2550-W White 0.75 AAC CR2550-Y Yellow 1.0 AAC Self Powered Red, Green, Blue, White, Yellow and Amber Indicators Low fixed trip point Low Cost for high Volume OEM Applications CR2550-A Amber 1.5 AAC Specifications Features Typical Installation Regulatory Agencies -Available in Custom Lengths Contact Factory for details E471882 11.0(279.4) 0.87 (22.0) 0.35 (9) Dia. 1.09 (27.8) The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 79 E-mail: sales@crmagnetics.com E Indicators and Dispalys 20 AAC Max, 600 VAC Max rating Thermoplastic Case Material 14.2 g / 0.5 oz weight 50 - 400 Hz Bandwidth -300C to +600C Operating Temperature -550C to +850C Storage Temperature T-13/4, Bipolar, Red/Red or Green/Green Diffused, Indicator is supplied with LED attached to current sensing transformer. Supplied with both one-piece press in lens and two-piece mounting clip. Weight 0.03 LBS.
CR2550-R 价格&库存
很抱歉,暂时无法提供与“CR2550-R”相匹配的价格&库存,您可以联系我们找货
