Wire Mounted Current Indicator
CR45 Series
MB45 Bracket
The CR45 Series, Wire Mounted Electrical Current Indicators
provide an effective method of monitoring electrical current.
The indicator is attached directly to a current-carrying wire.
When the current exceeds the turn-on point, the LED will illuminate to indicate the presence of current.
Applications
Monitor Status of Heater Elements
Observe Remote Loads
Indicate Phase Loss
Monitor Motor Operation
Two-Wire Passes
One-Wire Pass
Three-Wire Passes
Features
Self Powered
Red, Green, Blue, White, Yellow and Amber Indicators
Easy to Install
Supplied with a plastic wire tie
Bright Yellow Case for Easy Identification
Panel Mounting Bracket available
Specifications
Panel Mount
Load Center
PART NUMBERS
LED Color
Turn On Point (1 pass)
CR45-R
Red
2.0 AAC
CR45-G
Green
2.5 AAC
CR45-B
Blue
2.0 AAC
CR45-W
White
2.0 AAC
CR45-Y
Yellow
2.0 AAC
CR45-A
Amber
2.0 AAC
MB45
Regulatory Agencies
E471882
7.9mm DIA.
(.31")
5.1mm DIA.
(.20")
29.5 mm Max
(1.16")
3.7mm DIA.
(.144" )
2 PLACES
4.4mm Max
(.175")
6.4mm
(.25")
.19.8mm
(.781")
26.4mm
(1.04)
1.04” 26.4mm
24.1mm
(.95")
11.7mm
(.46")
TWO #6 SCREWS
NOT FURNISHED
RUBBER
WASHER
FURNISHED
CR-45
MB45
The Professional
Energy Monitoring
Company
M N TI
ISO 9001:2008 Quality Management System
39.7mm
(1.562")
5.2mm DIA.
(.203")
Recommended
Mounting Hole Pattern
3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119
Web: http://www.crmagnetics.com
77
E-mail: sales@crmagnetics.com
E
Indicators and Dispalys
Part Number
100 AAC Max, 600 VAC Max rating
Thermoplastic Case Material
14.2 g / 0.5 oz weight
50 - 1Khz Bandwidth
-100C to +850C Operating Temperature
Mounting Bracket Non-Magnetic Aluminum Material
Weight 0.03 LBS.
很抱歉,暂时无法提供与“CR45-R”相匹配的价格&库存,您可以联系我们找货
