CR45-B
CR45-B
    CR
CR45-B 数据手册
Wire Mounted Current Indicator CR45 Series MB45 Bracket The CR45 Series, Wire Mounted Electrical Current Indicators provide an effective method of monitoring electrical current. The indicator is attached directly to a current-carrying wire. When the current exceeds the turn-on point, the LED will illuminate to indicate the presence of current. Applications Monitor Status of Heater Elements Observe Remote Loads Indicate Phase Loss Monitor Motor Operation Two-Wire Passes One-Wire Pass Three-Wire Passes Features Self Powered Red, Green, Blue, White, Yellow and Amber Indicators Easy to Install Supplied with a plastic wire tie Bright Yellow Case for Easy Identification Panel Mounting Bracket available Specifications Panel Mount Load Center PART NUMBERS LED Color Turn On Point (1 pass) CR45-R Red 2.0 AAC CR45-G Green 2.5 AAC CR45-B Blue 2.0 AAC CR45-W White 2.0 AAC CR45-Y Yellow 2.0 AAC CR45-A Amber 2.0 AAC MB45 Regulatory Agencies E471882 Panel Mounting Bracket 7.9mm DIA. (.31") 5.1mm DIA. (.20") 29.5 mm Max (1.16") 3.7mm DIA. (.144" ) 2 PLACES 4.4mm Max (.175") 6.4mm (.25") .19.8mm (.781") 26.4mm (1.04) 1.04” 26.4mm 24.1mm (.95") 11.7mm (.46") TWO #6 SCREWS NOT FURNISHED RUBBER WASHER FURNISHED CR-45 MB45 The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System 39.7mm (1.562") 5.2mm DIA. (.203") Recommended Mounting Hole Pattern 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 77 E-mail: sales@crmagnetics.com E Indicators and Dispalys Part Number 100 AAC Max, 600 VAC Max rating Thermoplastic Case Material 14.2 g / 0.5 oz weight 50 - 1Khz Bandwidth -100C to +850C Operating Temperature Mounting Bracket Non-Magnetic Aluminum Material Weight 0.03 LBS.
CR45-B 价格&库存
很抱歉,暂时无法提供与“CR45-B”相匹配的价格&库存,您可以联系我们找货
CR45-B
  • 1+246.778481+30.87688
