UF224S36
UF224S36
    CUIDEVICES
    KIT CONVERTER DC-DC 36V SGL OUT
UF224S36 数据手册
Additional Resources: Product Page rev. page 1 of 3 date 04/2010 U N features · Designed for easy application of board-mount DC-DC Converters - Provides a PCB to mount the converter - Includes screw terminals for input and output connections - Includes all mounting hardware - Can be DIN rail mounted with (Optional) mounting adapter - Includes following features: o Input fuse o Input transient protection o Input reversal protection o Meet EN55022 class B conducted emissions* o Output trimming capable with (Optional) trim potentiometer - must be purchased seperately and installed onboard. ED DESCRIPTION: Converter Kit PART NUMBER: UF224 TI *tested at 25°C Description Input Voltage 9-18VDC Voltage Protection Threshold 20V D IS C - Model Number UF224S18 O N The UF224 kit is a value added item designed to facilitate easy application of 2"X2" sized board mount DC-DC converters. It includes all components needed to use the converter, removing the need to procure PCB, metal frame, mounting hardware, filtering and protection components. For basic operations, only the converter needs to be selected and procured separately. For additional output adjustment, a seperate trim potentiometer can be purchased and installed onboard. UF224S kits are designed for single-output converters. Input Fuse 3 5A Applicable V-INFINITY DC-DC Converters¹ VCD30-D12-SXX Applicable V-INFINITY DC-DC Converters² VCQ15-Q24-SXX PTK15-Q24-SXX VCQ15-Q48-SXX PTK15-Q48-SXX UF224S36 9-36VDC 39V 3A VCD30-D24-SXX VCQ15-Q24-SXX PTK25-D24-SXX PTK15-Q24-SXX UF224S75 9-75VDC 82V 1A VCD30-D48-XXX VCQ15-Q48-SXX PTK25-D24-SXX PTK15-Q48-SXX Notes: 1. The acceptable input voltage is the range suitable for the U-frame Kit only. It is OK to use a converter with a wider input range as long as the input voltage applied does not exceed the kit’s acceptable input voltage range. 2. These converters actually have input ranges that exceed the respective U-frame kit's input range but are still acceptable for use as long as the Kit's Acceptable Input Voltage range is not exceeded. 3.Use 5mm X 20mm fast blow type fuse. 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 www.v-infinity.com Additional Resources: Product Page rev. 2 of 3 date 04/2010 PIN ASSIGNMENTS +Vout: -Vout: N.C.: + Input - Input Remote control to turn output On/Off Output fine tuning + Output - Output No connection U Environment Conditions ED DESCRIPTION: Converter Kit PART NUMBER: UF224 +Vin: -Vin: On/Off: Trim: page Operating temperature range Storage temp range Humidity -25 ~ 70°C -25 ~ 85°C 10 ~ 90% RH, non-condensing N Parts List D IS C O N TI 1. PCB assembly - partially completed 2. U-frame 3. 4x M3 machine screws 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 www.v-infinity.com Additional Resources: Product Page rev. page 3 of 3 date 04/2010 DESCRIPTION: Converter Kit PART NUMBER: UF224 5. 6. 7. 8. Select appropriate converter and UF224 kit according to the model configurations table. Locate the partially completed assembly Remove the 4x M3 screws and take out PCB If output trimming is needed, install a top-mount 5KΩ trim pot. Available from Digikey, part # 3306F502-ND or 307UC502E-ND. Insert and solder converter. Trim off excess leads as needed. For DIN rail applications, secure the DIN rail adapter Kit (optional, model # VDRP-03). Skip this step for non-DIN rail mounting applications. Secure PCB assembly to the U-frame with the 4x M3 screws. Connect input wires and output leads. U 1. 2. 3. 4. ED Assembly Instructions: N Application Notes: 1. Input voltage TI It is important to ensure the input voltage measured at the converter input pins is within the range for that converter. Make sure wire losses and voltage ripples are accounted for. One possible problem is driving the converter with a linear unregulated power supply. For example, if the average voltage measured by a DMM is 9V, with a voltage ripple of 3Vpp, the actual input can swing from 7.5V to 10.5V. This will be outside the range of a 9-18V converter and it may not function properly. On the other end, make sure the actual input voltage does not exceed the highest voltage allowed by either the U-frame kit or the converter. 2. Lead wires 3. Input current N Make sure the input and output wires are of adequate AWG size to minimize voltage drop, and ensure the voltage across the input terminals is above the converter's rated minimum voltage at all times. It is recommended to have the wire pairs twisted, respectively for the input pair and the output pair, so as to minimize noise pickup. IS C O The input voltage source must be able to provide enough current to the converter, or it may not start up or operate properly. A typical symptom is not starting or unusually low output voltage. In general, it is recommended to be able to provide at least: η *Vmin) Ipeak = 150%*Pout/(η where Pout is the maximum output power, Vmin is the minimum input voltage and η is the converter's efficiency. As an example, for PTK15-Q24-S5 to operate with 10~36V input, 15W output and an efficiency of 78%, the minimum source current is recommended to be: Ipeak = 150% * 15 / (78% * 10) = 2.88A. 4. Input fuse For various protection functions, a fast-acting input fuse has been installed with the following current ratings: UF224S18 UF224S36 5.0A 3.0A UF224S72 1.0A D However, if the input range is well defined, the standard fuse may be replaced with a smaller fuse. The fuse should be chosen to allow for the maximum current at the lowest input voltage, as shown in this equation: η*Vmin) Ipeak = 150%*Pout/(η As an example, consider a 15W converter with 75% efficiency. If the actual input voltage range is 16~28V, the maximum input current is Ipeak = 150%*15/(75% * 16) = 1.875A. The preinstalled fuse can be replaced with a 2A fuse in this situation. 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 www.v-infinity.com Additional Resources: Product Page rev. page 4 of 3 date 04/2010 DESCRIPTION: Converter Kit PART NUMBER: UF224 ED 5. Input OVP To suppress voltage transients of short durations, the kit includes a Zener diode. For converter inputs of up to 18V, the Zener diode used has a rated breakdown voltage of 20V. For converter inputs of up to 36V, the Zener diode has a rated voltage of 39V. For inputs up to 72V, the Zener voltage rated is 82V. Notice, however, that these Zener diodes can only dissipate a small amount of power. It is necessary to ensure the input voltage does not exceed the maximum rated converter input. Otherwise the converter and the Zener diode may suffer permanent damage. U 6. Input reversal N If the input voltage is reversed for any reason, the built-in protection circuits in the UF224 kit will limit the reverse voltage to one diode drop or no more than 1V. The input fuse will open and thus remove power from the converter. Check the wiring and make corrections as needed. The input fuse will need to be replaced. Make sure the new fuse is of the same type and rating. 7. Output trimming (optional) 8. Output OCP and short-circuit TI The UF224 Kit provides the space and pads for a trimming potentiometer. To adjust the output voltage, install a 5KΩ potentiometer, (Digikey part # 3306F-502-ND or 307UC502E-ND or equivalent). The potentiometer is not needed if no trimming function is desired. Please note that only converters listed in the Model Configurations table can achieve output trimming. 9. Output OVP N Output overload and short circuit protections are provided by the converter itself only. Please see the converter datasheet for reference. Output over-voltage protection is provided by the converter itself only. Refer to converter datasheet. 10. Output On/Off control 11. Isolation O The converter output can be enabled or disabled through the On/Off pin. Refer to converter data sheet. IS C The input and output of the converter are electrically isolated. The isolation voltage rating is the same as that of the converter. Refer to converter data sheet. 12. Input filtering and EMI interference The UF224 kit has built-in components for input filtering, leading to reduced current ripple and the associated EMI interference. The kits are designed to meet EN55022 class B conducted standards. If the entire system powered by this converter kit needs to pass an EMI standard, it is recommended to have entire system tested against that standard. 13. Output filtering D The UF224 kit has a small output capacitor to help reduce ripple and noise. All specifications typical at nominal line, full load and 25°C unless otherwise noted. V-Infinity reserves the right to make changes to its products or to discontinue any product or service without notice, and to advise customers to verify the most up-to-date product information before placing orders. V-Infinity assumes no liability or responsibility for customer's applications using V-Infinity products other than repair or replacing (at V-I's option) V-Infinity products not meeting V-I's published specifications. Nothing will be covered outside of standard product warranty. 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 www.v-infinity.com
UF224S36
物料型号: UF224
器件简介: - 这是一个为板载DC-DC转换器设计的转换套件,旨在方便用户轻松应用。 - 包括一个PCB以安装转换器,输入输出端子连接,以及所有安装硬件。 - 可以选配DIN导轨安装适配器。
引脚分配: - +Vin: 输入正极 - +Vout: 输出正极 - -Vin: 输入负极 - -Vout: 输出负极 - On/Off: 远程控制使输出开启或关闭 - N.C.: 无连接 - Trim: 输出微调
参数特性: - 工作温度范围:-25 ~ 70°C - 存储温度范围:-25 ~ 85°C - 湿度:10 ~ 90% RH,无冷凝
功能详解: - 包括输入熔断器、输入瞬态保护、输入反接保护。 - 输出可调(需另购可调电位器并安装在板上)。 - 符合EN55022 B级传导发射标准。
应用信息: - 需要选择适当的转换器和UF224套件。 - 输出电压调整需要安装一个5KΩ的电位器。 - 对于DIN导轨应用,需要安装DIN导轨适配器套件。
封装信息: - 包括PCB组件、U框架、4个M3机器螺丝等。
注意事项: - 输入电压必须确保在转换器输入引脚的范围内。 - 确保输入和输出电线的尺寸足够大,以最小化电压降。 - 输入电流必须足够,以确保转换器能够启动和正常运行。 - 输入熔断器的额定值应选择允许在最低输入电压下的最大电流。 - 套件包括Zener二极管以抑制短时间的电压瞬态。 - 如果输入电压反接,UF224套件中的内置保护电路将限制反向电压。
UF224S36 价格&库存
很抱歉,暂时无法提供与“UF224S36”相匹配的价格&库存,您可以联系我们找货
