VGA Monitor Y Splitter Cable (HD15 M/2xF), 1 ft.
(0.31 m)
Highlights
Splits the VGA/XVGA signal
providing simultaneous display
of the same image on two
monitors
HD15 Male splits to 2 HD15
Female
MODEL NUMBER: P516-001
System Requirements
PC/MAC with 15-pin Female
VGA CPU port
Package Includes
Description
Tripp Lite's 1-ft. (0.31 m) VGA/XVGA Monitor "Y" Splitter cable provides an inexpensive alternative for
splitting the video signal from your PCs VGA port to two monitors (up to 800 x 600) that use standard 15pin plugs. Perfect for laptops to display on a separate, larger monitor. Use for short distance applications
only. For higher resolution monitors, use P516-001-HR. For applications that require longer distances and
highest resolution, see Tripp Lite B114-002-R, powered 2-Port Splitter, or, B114-004-R, powered 4-Port
Splitter.
Features
HD15 Male to 2 x HD15 Female w/Hex Nuts
Molded, double-shielded construction for maximum EMI/RFI protection
Two monitors display the image from one PC
Inexpensive solution for presentations
Specifications
OVERVIEW
UPC Code
037332123602
Product Type
Passive
Technology
VGA/SVGA
Host Connector
HD15 (MALE)
PHYSICAL
Color
Black
Cable Jacket Color
Black
1/2
Splitter Cable
Cable Length (ft.)
1
Cable Length (m)
0.30
Shipping Dimensions (hwd / in.)
0.25 x 6.30 x 7.50
Shipping Dimensions (hwd / cm)
0.64 x 16.00 x 19.05
Shipping Weight (lbs.)
0.30
Shipping Weight (kg)
0.14
CONNECTIONS
Side A - Connector 1
HD15 (MALE)
Side B - Connector 1
(2) HD15 (FEMALE)
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“P516-001”相匹配的价格&库存,您可以联系我们找货
