VGA High-Resolution RGB Coaxial Cable,
Plenum Rated (HD15 M/M)), 50 ft.
MODEL NUMBER: P502-050-P
Highlights
Supports video resolutions up to
2048 x 1536, including 1080p
Made from mini-coaxial (RGB)
and paired video wire
Foil and braid shielding blocks
hazardous EMI/RFI line noise
Gold-plated connectors and
contacts for maximum
conductivity
Plenum-rated jacket
recommended for ceilings, walls
and ducts
System Requirements
Display device with HD15 input
Computer with HD15 output
Package Includes
Allows a high-resolution connection between your VGA-enabled computer and monitor up to 50 ft. apart
with no ghosting.
Description
The P502-050-P VGA Coaxial High-Resolution Plenum-Rated Monitor Cable (M/M) allows you to connect
your VGA-enabled computer and monitor up to 50 feet apart. Constructed from mini-coaxial (RGB) and
paired video wire, it supports video resolutions up to 2048 x 1536, including 1080p, with no ghosting. The
plenum-rated jacket is ideal for running the cable through ceilings, walls and ducts.
Foil and braid shielding delivers reliable, error-free signal quality and protection from EMI/RFI line noise
that can distort or destroy data. Molded gold-plated HD15 male connectors with gold-plated contacts
provide maximum conductivity and minimize data loss. Integral strain relief gives the cable extra flexibility,
reduces stress, and helps the cable and connectors move freely without cracking.
Features
Allows Connection Between VGA-Enabled Computer and Monitor Up to 50 ft.
● Supports video resolutions up to 2048 x 1536, including 1080p
Made from mini-coaxial (RGB) and paired video wire
Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data
Molded gold-plated HD15 male connectors and contacts provide maximum conductivity and minimize
data loss
Integral strain relief protects cable and connectors from stress and cracking
Plenum-rated jacket recommended for connecting through ceilings, walls and ducts
Specifications
1/2
P502-050-P VGA Coaxial HighResolution Plenum-Rated
Monitor Cable (M/M), 50 ft.
OVERVIEW
UPC Code
037332130679
Technology
Coax; VGA/SVGA
PHYSICAL
Color
Black
Cable Length (ft.)
50
Cable Length (m)
15.24
Shipping Dimensions (hwd / in.)
17.00 x 14.00 x 1.00
Shipping Dimensions (hwd / cm)
43.18 x 35.56 x 2.54
Shipping Weight (lbs.)
4.10
Shipping Weight (kg)
1.86
CONNECTIONS
Side A - Connector 1
HD15 (MALE)
Side B - Connector 1
HD15 (MALE)
Latching or Gripping Connector
No
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“P502-050-P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1847.524871+240.12253
