VGA High-Resolution RGB Coaxial Cable (HD15
M/F)), 25 ft. (7.62 m)
MODEL NUMBER: P500-025
Highlights
Supports video resolutions up to
2048 x 1536, including 1080p
Made from mini-coax (RGB) and
paired video wire
Foil and braid shielding blocks
hazardous EMI/RFI line noise
Gold-plated connectors and
contacts for maximum
conductivity
Integral strain relief protects
against cable stress and
cracking
System Requirements
Display device with HD15 input
Package Includes
Extend the high-resolution connection between your VGA-enabled computer and monitor up to 25 ft. with
no ghosting. Recommended for easy access to VGA ports that are hidden or hard to reach.
Description
The P500-025 VGA Coax High-Resolution Monitor Extension Cable (M/F) extends the connection
between your VGA-enabled computer and monitor up to 25-ft. (7.62 m). It's recommended for easier
access to VGA ports that are hidden under a desk or inside a cabinet or otherwise difficult to reach.
Constructed from mini-coax (RGB) and paired video wire, it supports video resolutions up to 2048 x 1536,
including 1080p, with no ghosting.
Foil and braid shielding delivers reliable, error-free signal quality and protection from EMI/RFI line noise
that can distort or destroy data. Molded gold-plated HD15 connectors with gold-plated contacts provide
maximum conductivity and minimize data loss. Integral strain relief gives the cable extra flexibility, reduces
stress, and helps the cable and connectors move freely without cracking.
Features
Extends Connection Between VGA-Enabled Computer and Monitor Up to 25-ft. (7.62 m)
● Supports video resolutions up to 2048 x 1536, including 1080p
Made from mini-coax (RGB) and paired video wire
Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data
Molded gold-plated HD15 connectors and contacts provide maximum conductivity and minimize data
loss
Integral strain relief protects cable and connectors from stress and cracking
Rugged PVC jacket designed for long life
Specifications
OVERVIEW
UPC Code
037332125170
Product Type
Passive
1/2
P500-025 VGA Coax HighResolution Monitor Extension
Cable (M/F), 25-ft. (7.62 m)
Technology
Coax; VGA/SVGA
PHYSICAL
Color
Black
Cable Jacket Color
Black
Cable Length (ft.)
25
Cable Length (m)
7.62
Shipping Dimensions (hwd / in.)
12.00 x 10.00 x 1.00
Shipping Dimensions (hwd / cm)
30.48 x 25.40 x 2.54
Shipping Weight (lbs.)
2.20
Shipping Weight (kg)
1.00
CONNECTIONS
Side A - Connector 1
HD15 (MALE)
Side B - Connector 1
HD15 (FEMALE)
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Certifications
IEC/EN 62040
Product Compliance
RoHS; CE (Europe)
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“P500-025”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+209.5611410+27.12191
