VGA High-Resolution RGB Coaxial Cable (HD15
M/M), Right-Angle Connector, 3 ft. (0.91 m)
MODEL NUMBER: P502-003-RA
Highlights
Supports video resolutions up to
2048 x 1536, including 1080p
Made from mini-coaxial (RGB)
and paired video wire
Foil and braid shielding blocks
hazardous EMI/RFI line noise
Gold-plated connectors and
contacts for maximum
conductivity
Right-angle HD15 connector
easy to connect in tight spaces
System Requirements
Display device with HD15 input
Computer with HD15 output
Package Includes
Allows a high-resolution connection between your VGA-enabled computer and monitor up to 3 ft. apart
with no ghosting.
Features
Allows Connection Between VGA-Enabled Computer and Monitor Up to 3 ft.
● Supports video resolutions up to 2048 x 1536, including 1080p
Right-angle connector allows more room for connecting in tight spaces and moving connected
equipment against a wall
Made from mini-coaxial (RGB) and paired video wire
Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data
Molded gold-plated HD15 male connectors and contacts provide maximum conductivity and minimize
data loss
Integral strain relief protects cable and connectors from stress and cracking
Rugged PVC jacket designed for long life
Specifications
OVERVIEW
UPC Code
037332147042
Product Type
Passive
Technology
Coax; VGA/SVGA
PHYSICAL
Color
Black
Cable Jacket Color
Black
1/2
P502-003-RA VGA Coaxial
High-Resolution Monitor Cable
(M/M), 3 ft.
Cable Length (ft.)
3
Cable Length (m)
0.91
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.50
Shipping Weight (kg)
0.23
CONNECTIONS
Side A - Connector 1
HD15 (MALE) - RIGHT ANGLE
Side B - Connector 1
HD15 (MALE)
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
IP68 Rated
No
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“P502-003-RA”相匹配的价格&库存,您可以联系我们找货
