P502-010-RA
P502-010-RA
    TRIPPLITE
    P502-010-RA
P502-010-RA 数据手册
VGA High-Resolution RGB Coaxial Cable (HD15 M/M), Right-Angle Connector, 10 ft. (3.05 m) MODEL NUMBER: P502-010-RA Highlights ● Supports video resolutions up to 2048 x 1536, including 1080p ● Made from mini-coaxial (RGB) and paired video wire ● Foil and braid shielding blocks hazardous EMI/RFI line noise ● Gold-plated connectors and contacts for maximum conductivity ● Right-angle HD15 connector easy to connect in tight spaces System Requirements ● Display device with HD15 input ● Computer with HD15 output Package Includes ● Allows a high-resolution connection between your VGA-enabled computer and monitor up to 10 ft. apart with no ghosting. Description The P502-010-RA VGA Coaxial High-Resolution Monitor Cable (M/M) allows you to connect your VGAenabled computer and monitor up to 10-ft. (3.05 m) apart. Constructed from mini-coaxial (RGB) and paired video wire, it supports video resolutions up to 2048 x 1536, including 1080p, with no ghosting. One HD15 connector is fixed at a 90-degree angle to allow more room for the cable and allow equipment to be pushed flush against a wall. Foil and braid shielding delivers reliable, error-free signal quality and protection from EMI/RFI line noise that can distort or destroy data. Molded gold-plated HD15 male connectors with gold-plated contacts provide maximum conductivity and minimize data loss. Integral strain relief gives the cable extra flexibility, reduces stress, and helps the cable and connectors move freely without cracking. Features Allows Connection Between VGA-Enabled Computer and Monitor Up to 10-ft. (3.05 m) ● Supports video resolutions up to 2048 x 1536, including 1080p ● Right-angle connector allows more room for connecting in tight spaces and moving connected equipment against a wall ● Made from mini-coaxial (RGB) and paired video wire ● Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data ● Molded gold-plated HD15 male connectors and contacts provide maximum conductivity and minimize data loss ● Integral strain relief protects cable and connectors from stress and cracking ● Rugged PVC jacket designed for long life Specifications OVERVIEW UPC Code 037332147066 1/2 P502-010-RA VGA Coaxial High-Resolution Monitor Cable (M/M), 10-ft. (3.05 m) Product Type Passive Technology Coax; VGA/SVGA PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 12.00 x 10.00 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 25.40 x 1.27 Shipping Weight (lbs.) 0.50 Shipping Weight (kg) 0.23 CONNECTIONS Side A - Connector 1 HD15 (MALE) - RIGHT ANGLE Side B - Connector 1 HD15 (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P502-010-RA 价格&库存
很抱歉,暂时无法提供与“P502-010-RA”相匹配的价格&库存,您可以联系我们找货
