P501-050
P501-050
    TRIPPLITE
    CABLERGBCOAXHD15M/F50'
P501-050 数据手册
VGA Coax Monitor Easy Pull Extension Cable, High Resolution Cable with RGB Coax (HD15 M/F), 50 ft. (15.24 m) MODEL NUMBER: P501-050 Highlights ● Two-piece design runs through conduit or other tight areas ● Threaded circular DIN connector provides secure reattachment ● 75ohm mini-coax (RGB) and paired video wire construction delivers outstanding signal quality ● Superior-molded cables with foil and braid shielding for maximum EMI/RFI protection Package Includes Features ● Two-piece design runs through conduit or other tight areas ● Threaded circular DIN connector provides secure reattachment ● Superior molded cables with foil and braid shielding for maximum EMI/RFI protection ● RGB 75-ohm coax construction for maximum video resolution ● HD15 male to HD15 female molded connectors ● Supports resolutions up to 1600 x 1200 Specifications OVERVIEW UPC Code 037332134639 Product Type Passive Technology Coax; VGA/SVGA PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 50 Cable Length (m) 15.24 Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 0.50 1/2 ● 50 ft. Male/Female Easy Pull SVGA/VGA Monitor Extension Cable w/ Connectors ● Wallplate with HD15 cutout Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 1.27 Shipping Weight (lbs.) 3.90 Shipping Weight (kg) 1.77 CONNECTIONS Side A - Connector 1 HD15 (MALE) Side B - Connector 1 HD15 (FEMALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P501-050 价格&库存
很抱歉,暂时无法提供与“P501-050”相匹配的价格&库存,您可以联系我们找货
