JBXSCFD1G10MSS1
JBXSCFD1G10MSS1
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    ASSY MALE PLUG-DB9 MALE PLUG
JBXSCFD1G10MSS1 数据手册
48Hr s Connection Technologies VICE ER Overmolded Cable assemblies TATION S UO Q Overmolded Cable assemblies Specifications UTO • Shielded metal connector • Extreme sealing: IP68/69K Plating Salt spray Black anodized 96 H Nickel 48 H • 17 layouts • Rapid 1/3 turn connection Temperature Sealing Mechanical -40° C + 50° C IP68/69K mated 500 matings/unmatings * UTS • Plastic connector • Extreme sealing: IP68/69K • 30 layouts • Rapid 1/3 turn plastic connection Plating Salt spray Temperature Sealing Mechanical No plating 500 H -40° C + 50° C IP68/69K mated 250 matings/unmatings * UTL • Plastic connector • Extreme sealing: IP68/69K • Power supply rated by UL • Push Pull locking mechanism with audible «click» Plating Salt spray Temperature Sealing Mechanical No plating 1000 H -40° C + 90° C IP68/69K mated/unmated 500 matings/unmatings * JBX • Metal connector • High density/40 layouts from 2 to 30 positions • IP40 and limited sealed IP68 • Push pull locking mechanism Plating Salt spray Temperature Sealing Mechanical Nickel Chrome 96 H -55° C + 50° C IP40/68 mated 1,000 matings/unmatings * JDX • Metal connector • High density/19 layouts from 2 to 19 positions • Sealing: IP68 • Positive latching and breakaway feature Plating Salt spray Temperature Sealing Mechanical Nickel Chrome 96 H -40° C + 85° C IP68 mated/unmated 2,500 matings/unmatings * * Contact us for more information on mating receptacle offering Overmolded Cable assemblies UTO * Connector • Shielded metal connector • Extreme sealing: IP68/69K • 17 layouts • Rapid 1/3 turn connection * Contact us for more information on mating receptacle offering Construction • Polyurethane Jacket (Black) • 16 AWG conductors • Multi-conductor 8 • 300V • Shielded • Flammability rating UL 1581 Sec.1080 (VW-1) Plating Salt spray Black anodized* 96 H Nickel 48 H Applications • Machining Centers (Oil Resistant) • Assembly Automation Equipment • Geophysical Equipment • Solar (UV Stable) • Outdoor Displays Temperature Sealing Mechanical -40° C + 50° C IP68/69K mated 500 matings/unmatings * Custom black anodized version available on demand Description Series Nbr contacts Size Wire size Description Length (FT) Part number UTO 8 12 16 AWG D/E assembly 1 male plug & 1 female plug 3 UT06V1208PS03FT00 UTO 8 12 16 AWG D/E assembly 1 male plug & 1 female plug 6 UT06V1208PS06FT00 UTO 8 12 16 AWG D/E assembly 1 male plug & 1 female plug 12 UT06V1208PS12FT00 UTO 8 12 16 AWG S/E assembly 1 female plug 3 UT06V1208S03FT00 UTO 8 12 16 AWG S/E assembly 1 female plug 6 UT06V1208S06FT00 UTO 8 12 16 AWG S/E assembly 1 female plug 12 UT06V1208S12FT00 UTO 8 12 16 AWG S/E assembly 1 male plug 3 UT06V1208P03FT00 UTO 8 12 16 AWG S/E assembly 1 male plug 6 UT06V1208P06FT00 UTO 8 12 16 AWG S/E assembly 1 male plug 12 UT06V1208P12FT00 Overmolded Cable assemblies UTS * Connector • Plastic connector • Extreme sealing: IP68/69K • 30 layouts • Rapid 1/3 turn plastic connection * Contact us for more information on mating receptacle offering Construction • PVC Jacket (Black) • 16 AWG conductors • Multi-conductor 4, 8 or 12 • 300V • Unshielded • Flammability rating UL 1685 (UL1581 Sec.1160) Applications • Industrial Controls • Electronics • Controlled Environment Equipment • LED Lighting Plating Salt spray Temperature Sealing Mechanical No plating 500 H -40° C + 50° C IP68/69K mated 250 matings/unmatings Description Series Nbr contacts Size Wire size Description Length* (FT) Part number UTS 4 10 16 AWG D/E assembly 1 male plug & 1 female plug 3 UTS6V1004PS03FT00 UTS 8 12 16 AWG D/E assembly 1 male plug & 1 female plug 3 UTS6V1208PS03FT00 UTS 12 14 16 AWG D/E assembly 1 male plug & 1 female plug 3 UTS6V1412PS03FT00 UTS 4 10 16 AWG S/E assembly 1 female plug 3 UTS6V1004S03FT00 UTS 8 12 16 AWG S/E assembly 1 female plug 3 UTS6V1208S03FT00 UTS 12 14 16 AWG S/E assembly 1 female plug 3 UTS6V1412S03FT00 UTS 4 10 16 AWG S/E assembly 1 male plug 3 UTS6V1004P03FT00 UTS 8 12 16 AWG S/E assembly 1 male plug 3 UTS6V1208P03FT00 UTS 12 14 16 AWG S/E assembly 1 male plug 3 UTS6V1412P03FT00 * Other lengths available: 3, 6, 12 feet only: e.g. UTS6V1004PS06FT00 for a 6 feet version Overmolded Cable assemblies UTL * Connector • Plastic connector • Extreme sealing: IP68/69K • Power supply rated by UL • Push pull locking mechanism 14 AWG wire • SJOOW: 300V, 90°C • UL listed & CSA certified for indoor & outdoor use • UL-62/CSA C22.2-49; MSHA approved; RoHS compliant • Resistant to: oil, uv, water * Contact us for more information on mating receptacle offering 16 & 18 AWG wires • SOOW: 600V, 90°C • Passes MSHA flame-test p-136-MSHA • Resistant to: oil, uv (UL-62), solvents, water, ozone, aging and abrasion Applications • Industrial Controls • Electronics • Controlled Environment Equipment • LED Lighting • Solar (UV Stable) • Outdoor Displays Plating Salt spray Temperature Sealing Mechanical No plating 1000 H -40° C + 90° C IP68/69K mated/unmated 500 matings/unmatings Description Series Nbr contacts Size Wire size Description Length* (FT) Part number UTL 4 10 14 AWG D/E assembly 1 male plug & 1 female plug 3 UTLMKT63G1PS3FT UTL 4 10 16 AWG D/E assembly 1 male plug & 1 female plug 3 UTLMK63G1PS03FT00 UTL 4 10 18 AWG D/E assembly 1 male plug & 1 female plug 3 UTLMK63G1PS03FT01 UTL 4 10 14 AWG S/E assembly 1 female plug 3 UTLMKT63G1S3FT UTL 4 10 16 AWG S/E assembly 1 female plug 3 UTLMK63G1S03FT00 UTL 4 10 18 AWG S/E assembly 1 female plug 3 UTLMK63G1S03FT01 UTL 4 10 14 AWG S/E assembly 1 male plug 3 UTLMKT63G1P3FT UTL 4 10 16 AWG S/E assembly 1 male plug 3 UTLMK63G1P03FT00 UTL 4 10 18 AWG S/E assembly 1 male plug 3 UTLMK63G1P03FT01 UTL 4 10 14 AWG D/E assembly 1 male plug & 1 female inline receptacle 3 UTLMKT613G1SP3FT UTL 4 10 16 AWG D/E assembly 1 male plug & 1 female inline receptacle 3 UTLMK613G1SP03FT00 UTL 4 10 18 AWG D/E assembly 1 male plug & 1 female inline receptacle 3 UTLMK613G1SP03FT01 * Other lengths available: 3, 6, 12 feet only: e.g. UTLMKT63G1PS6FT for a 6 feet version 14 AWG jumper or UTLMK63G1PS06FT01 for a 6 feet version 18 AWG jumper Overmolded Cable assemblies JBX/JDX * JBX • • • • Metal connector High density/40 layouts from 2 to 30 positions IP40 Push pull locking mechanism JBX to USB: JBXSCFD0G04MSS1 • USB 2.0 Type A Male Cable • Jacket Rating: Standard • For JBX Size 0, 4 conductor receptacles to USB device • Shielded * Contact us for more information on mating receptacle offering JBX to DB9: JBXSCFD1G10MSS1 • Low Profile DB9 Male Cable • Jacket Rating: CMG Rated • For JBX Size 1, 10 conductor receptacles to RS-232/Serial communications • Shielded JBX to RJ45: JBXSCFD1G08MSS1 • Conductor: 4-pair • Jacket: PVC/Jacket Rating: Standard • Wired: TSB 568B (AT&T 258A) • Shielded (w/drain wire) • Certification: TIA/EIA • For JBX Size 1, 8 conductor receptacles to RJ45 Male Plating Salt spray Temperature Sealing Mechanical Nickel Chrome 96 H -55° C + 50° C IP40 1,000 matings/unmatings JDX • • • • * Metal connector High density/19 layouts from 2 to 19 positions Sealing: IP68 Positive latching and breakaway feature * Contact us for more information on mating receptacle offering JDX to JDX: JDXCFDFD2T19MSN • JDX FD Cable • Multi conductor cable • Connector: JDXFD2T19MSN • Jacket: PUR • • • • Woven braid shielding @ 85% coverage Jacket Rating: Standard For JDX Size 2, 19 conductor receptacles Shielded Plating Salt spray Temperature Sealing Mechanical Nickel Chrome 96 H -40° C + 85° C IP68 mated/unmated 2,500 matings/unmatings Description Series Nbr contacts Size JBX 10 1 JBX 8 1 JBX 4 0 JDX 19 2 Wire size Description 28 AWG D/E assemby JBX male plug to DB9 male plug (DB9M) 24 AWG D/E shielded assembly JBX male plug to RJ45 male plug (Cat5E) 28 AWG D/E assembly JBX male plug to USB male plug (USB 2.0) 28 / 32 D/E assembly JDX male plug on each end AWG Length* (FT) Part number 10 JBXSCFD1G10MSS1 5 JBXSCFD1G08MSS1 5 JBXSCFD0G04MSS1 5 JDXCFDFD2T19MSN Overmolded Cable assemblies 48 Hrs Quotation Service • 48 hour Quick-turn quotation & aggressive delivery service on Standard Cable offering for your immediate prototype and cable assembly needs. • Fast response when a more customized solution is needed – see our Custom Cable Assembly Capabilities. • We can support both prototype and/or production order volumes. • Harsh environment and sealed applications are our specialty. • Our standard cable assemblies offer a reliable and technical solution for a broad scope of markets & applications. • Competitive pricing without sacrificing our dedication to exceptional Quality. • Contact us via: sales@souriau.com Custom Cable Assembly Capabilities Our success is attributed to our personalized service and collaborative approach to helping our customers with more complex and sophisticated interconnect design, engineering and manufacturing needs for bringing challenging and innovative products to market. Whether your design requires exceptional sealed and overmolded plugs, integrated surge protection, current limiting signal conditioning or custom SOURIAU connectors and layouts…… we are the connection technology provider for you. • We strive to provide 48-hr response on Custom Cable Assembly Solutions with SOURIAU connectors and commercially available cable. (Response time for Quotes & Delivery may vary depending upon complexity of design, customer needs or ITAR requirements.) Choose SOURIAU as your solution provider for your “outside the box”, rugged and harsh environment interconnect needs. For pricing support on customized needs: contact us via: pricing@souriau.com SOURIAU standard layout UTO & UTS Size 10, 4 Pos Size 12, 8 Pos Size 14, 12 Pos UTL Size 10, 3 Pos + ground JBX Size 0, 4 Pos Size 1, 8 Pos JDX Size 1, 10 Pos Size 2, 19 Pos Wenatchee WA York PA Morocco China Dominican Republic India Manufacturing presence Sales presence SOURIAU capabilities Manufacturing locations SOURIAU has established global manufacturing locations, testing capabilities, sales and engineering offices to service our domestic and international customers with a local presence. SOURIAU products can be purchased through a vast network of authorized distribution partners. Quality assurance • Cable assemblies are manufactured & inspected to the requirements of IPC/WHMA-A-620 and SOURIAU personnel are trained annually by certified IPC instructors. • Our quality system is based on the requirements of 15O9001/AS9100 and First Article Inspection reports are created in accordance with AS9102. • SOURIAU has its own independent test center recognized by many national standard laboratories and can qualify programs to UL, CSA, VDE and EN. • SOURIAU is a world leader in signal integrity and can provide certification testing for all major protocols including: CAT 5, 5E, RS-485. • Testing capability includes full certification reports with NEXT, FEXT, impedance, and attenuation to 40 GHz. • Crosstalk for mixed power and signal assemblies can be provided to meet your system needs. Measurement capabilities include both time and frequency domains to meet a broad spectrum of applications. Wiring Class 3 for Harsh Environments is our focus, but Class (1, 2, or 3) can be selected based on your application. • Class 1 - General Electronic Products (applications or requirements for assembly function) • Class 2 - Dedicated Service Electronic Products (for continued performance and extended life requirements where uninterrupted service is desired) • Class 3 - High Performance Electronic Products (for applications where downtime is not tolerated and the environment is harsh). www.souriau-industrial.com technicalsupport@souriau.com US phone: 717 767 6705 INDCABLE01US © Copyright SOURIAU 05/2013- All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. Overmolded Cable assemblies
JBXSCFD1G10MSS1
1. 物料型号: - UTO系列:塑料连接器,极端密封性达到IP68/69K,适用于250次插拔。 - UTS系列:塑料连接器,极端密封性达到IP68/69K,30种布局,快速1/3转连接。 - UTL系列:塑料连接器,极端密封性达到IP68/69K,电源供应符合UL标准,推拉锁定机制。 - JBX系列:金属连接器,高密度布局,从2到30个位置,IP40。 - JDX系列:金属连接器,高密度布局,从2到19个位置,密封性达到IP68。
2. 器件简介: - 这些电缆组件设计用于极端环境,具有高密封性和机械耐久性,适用于工业控制、电子设备、恶劣环境设备、LED照明和户外显示屏等应用。
3. 引脚分配: - 文档中列出了不同系列的电缆组件的引脚数量和布局,例如UTO系列有8个引脚,UTS系列有4、8或12个引脚,JBX系列有10个引脚,JDX系列有19个引脚。
4. 参数特性: - 包括温度范围(如-40°C至+50°C或-40°C至+90°C)、耐盐雾时间(如96小时或500小时)、机械寿命(如250次或500次插拔)。
5. 功能详解: - 描述了连接器的功能特性,如快速连接、推拉锁定机制、屏蔽金属连接器、电源供应额定值等。
6. 应用信息: - 适用于机床中心(耐油)、组装自动化设备、地球物理设备、太阳能(耐紫外线)、户外显示屏等。
7. 封装信息: - 包括电缆的外皮材料(如聚氯乙烯或聚氨酯)、导线规格(如16AWG或14AWG)、屏蔽情况(如屏蔽或非屏蔽)、耐燃等级(如UL 1581 Sec.1080 VW-1)。
JBXSCFD1G10MSS1 价格&库存
很抱歉,暂时无法提供与“JBXSCFD1G10MSS1”相匹配的价格&库存,您可以联系我们找货
