Couplers
500 Watt High Performance
Directional Couplers - N • TNC Types
500 MHz to 18.0 GHz Frequency Range
Low VSWR - High Directivity
500 Watt High Power Capability
Individually Calibrated
Midwest Microwave's series of High Power
Directional Couplers are useable for system
or testing where flat frequency response over
extended bandwidths is required. They possess high directivity and will withstand high
input power under extreme environmental
conditions. Standard units have stainless
Note: Case Style 7 has two mounting holes.
steel Type N female connectors but are also
available with TNC connectors.
ELECTRICAL SPECIFICATIONS
Frequency
R an g e
(GH z )
.5-1.0
1.0-2.0
2.0-4.0
4.0-10.0
7.0-12.4
C oupling
(dB )
(Incl Freq
Sensitivity)
Frequency
Sensitivity
(dB )
Insertion
L o ss
(dB ) max
D irectivity
(dB ) min
VSWR
max
C PL-5044-10-N N N -79
10 + 1.0
+ 0.75
0.20
30
1.15
200
50
10
1
C PL-5044-20-N N N -79
20 + 1.0
+ 0.75
0.20
30
1.15
500
500
10
2
C PL-5044-30-N N N -79
30 + 1.0
+ 0.75
0.20
30
1.15
500
500
10
3
C PL-5045-10-N N N -79
10 + 1.0
+ 0.75
0.20
30
1.15
200
50
10
3
C PL-5045-20-N N N -79
20 + 1.0
+ 0.75
0.20
30
1.15
500
500
10
4
C PL-5045-30-N N N -79
30 + 1.0
+ 0.75
0.20
30
1.15
500
500
10
3
C PL-5046-10-N N N -79
10 + 1.0
+ 0.75
0.20
25
1.15
200
50
10
3
C PL-5046-20-N N N -79
20 + 1.0
+ 0.75
0.20
27
1.15
500
500
10
4
C PL-5046-30-N N N -79
30 + 1.0
+ 0.75
0.20
27
1.15
500
500
10
5
C PL-5047-10-N N N -79
10 + 1.0
+ 0.75
0.25
20*
1.20
200
50
10
5
C PL-5047-20-N N N -79
20 + 1.0
+ 0.75
0.25
20*
1.20
500
500
10
6
C PL-5047-30-N N N -79
30 + 1.0
+ 0.75
0.25
20*
1.20
500
500
10
7
C PL-5048-10-N N N -79
10 + .75
+ 0.75
0.25
15
1.25
200
50
10
7
C PL-5048-20-N N N -79
20 + .75
+ 0.75
0.25
15
1.25
500
500
10
7
C PL-5048-30-N N N -79
30 + .75
+ 0.75
0.25
15
1.25
500
500
10
C ase
Style
Model
N umber
1
C ASE
STYLE
MECHANICAL SPECIFICATIONS -
Pow er (In)
Avg Avg Avg
In
R ef P eak
(W) (W) (kW)
* Directivity is 17 dB from 8.0 - 10.0 GHz.
INCHES (mm)
WEIGH T
Lbs
Kg
A
B
C
D
E
F
6.25 (158.8)
3.00 (76.2)
0.51 (13.0)
2.13 (54.0)
0.87 (22.1)
1.687 (42.9)
1.2
3
6.25 (158.8)
3.00 (76.2)
0.51 (13.0)
2.13 (54.0)
0.69 (17.5)
1.687 (42.9)
1.2
0.52
4.10 (104.1)
1.09 (27.7)
0.50 (12.7)
2.13 (54.0)
0.87 (22.1)
1.687 (42.9)
1.0
0.45
5
4.10 (104.1)
1.09 (27.7)
0.50 (12.7)
2.13 (54.0)
0.69 (17.5)
1.687 (42.9)
1.0
0.45
5.10 (129.5)
2.00 (50.8)
0.66 (16.8)
2.13 (54.0)
0.57 (14.5)
1.687 (42.9)
1.1
0.50
5.10 (129.5)
2.00 (50.8)
0.57 (14.5)
2.13 (54.0)
0.69 (17.5)
1.687 (42.9)
1.1
0.50
2.50 (63.5)
1.13 (28.7)
0.60 (15.2)
1.50 (38.1)
0.60 (15.2)
1.093 (27.8)
0.8
0.40
1
2
4
6
7
0.52
Note: TNC or Type N output connectors are available by substituting "TNC" or "NNN" for "SMA" in the Model Number.
97
很抱歉,暂时无法提供与“CPL-5048-30-NNN-79”相匹配的价格&库存,您可以联系我们找货
