S045-59I
S045-59I
    TRIPPLITE
    S045-59I
S045-59I 数据手册
SCSI/Fibre Channel - SCSI Ribbon Cable MODEL NUMBER: S045-59I Highlights ● Premium cabling ● Ribbon cables connect up to 7 internal SCSI drives to your internal SCSI controller ● SCSI 160 Cables include active terminators which compensate for fluctuations in the host adapter Description Tripp Lite's 59 inch internal Ultra2 LVD SCSI ribbon cable is used to connect up to 5 SCSI devices to a SCSI host controller card. Ultra SCSI 2 LVD (low voltage differential) is a new standard of SCSI data transmission which supports a transfer speed of 80Mbps. Manufactured with LVD twist-n-flat ribbon cable, this cable is backwards compatible and will support SCSI 1,2 & 3 devices. Connect up to 5 internal devices including CD-ROMs and Hard Drives requiring HD68M connectors. This cable includes an LVD terminator mounted on one end. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features ● Meets SCSI 3 specifications ● Supports transfer speeds up to 80Mbps ● Backward compatible with SCSI 1 & 2 ● Connects up to 5 internal devices ● HD68 male connectors ● LVD terminator mounted on cable ● All Tripp Lite SCSI products, regardless of the SCSI generation, meet the latest specifications of ANSI ● Tripp Lite offers a complete line of internal and external solutions for SCSI/RAID and fibre channel ranging from the very latest ultra 320 to legacy SCSI- and every combination in between ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life ● Wide SCSI controller ● Wide SCSI drive or internal device Package Includes ● Specifications OVERVIEW UPC Code 037332042958 Drives Supported 5 Technology Ribbon/Internal; SCSI PHYSICAL Color Gray Cable Length (ft.) 5 Cable Length (m) 1.52 Cable Length (in.) 59 Shipping Dimensions (hwd / in.) 0.00 x 0.00 x 0.00 Shipping Weight (kg) 0.34 Shipping Weight (lbs.) 0.74 CONNECTIONS Side A - Connector 1 System Requirements INTERNAL HD68 (MALE) 1/2 59 inch internal SCSI U2 ribbon cable 6Conn HD68M with terminator Side B - Connector 1 INTERNAL HD68 (MALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
S045-59I 价格&库存
很抱歉,暂时无法提供与“S045-59I”相匹配的价格&库存,您可以联系我们找货
