UR024-010
UR024-010
    TRIPPLITE
    UR024-010
UR024-010 数据手册
Universal Reversible USB 2.0 Extension Cable (Reversible A to A M/F), Black, 10 ft. (3.05 m) MODEL NUMBER: UR024-010 Highlights ● Supports USB 2.0 speeds up to 480 Mbps to ensure reliable data transfers ● Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data ● Corrosion-resistant gold-plated contacts provide maximum conductivity and minimize data loss ● Integral strain relief helps cable move freely without stress or cracking ● Reversible male plug connects in either direction for immediate no-fuss use Package Includes ● Universal USB-A cable with reversible male connector extends a USB cable run by 10 feet. Features USB-A Extension Cable Lengthens Your Connection up to 10-ft. (3.05 m) Extend your USB-A cable run up to 10 feet with this USB 2.0 cable (M/F). It supports data transfer rates up to 480 Mbps, making it ideal for your multimedia application, such as digital signage. The cable is backward compatible with earlier USB generations, including USB 1.1. Reversible Male Plug Connects in Either Direction Unlike traditional USB cables that connect in only one direction, the reversible male connector plugs into a USB-A port in either direction for an instant connection every time. Premium Construction Results in Premium Signal Quality Molded nickel-plated connectors with gold-plated contacts provide maximum conductivity and minimum data loss to guarantee a clear transmission free of interference. Foil and braid shielding delivers reliable, error-free signal quality and protection from EMI/RFI line noise that can distort or destroy data. Integral strain relief gives the cable extra flexibility, reduces stress, and helps the cable move freely without cracking or breaking loose from the connector. Specifications OVERVIEW UPC Code 037332179609 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black Cable Length (ft.) 10 Cable Length (m) 3.05 1/2 UR024-010 Universal USB-A Extension Cable (M/F), Black, 10-ft. (3.05 m) Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.25 Shipping Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 USB A (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR024-010 价格&库存
很抱歉,暂时无法提供与“UR024-010”相匹配的价格&库存,您可以联系我们找货
