U025-001-PM
U025-001-PM
    TRIPPLITE
    U025-001-PM
U025-001-PM 数据手册
USB 2.0 Panel Mount Extension Cable (B to Panel Mount B M/F), 1 ft. (0.31 m) MODEL NUMBER: U025-001-PM Highlights ● Add a fixed USB B female port to a custom solution, such as an internally mounted drive ● Data transfer rates (1.5 to 480 Mbps) for low speed and high speed devices ● Premium double-shielded cables with tinned copper braid and aluminum mylar foil feature twisted 28/20 AWG data lines System Requirements ● Any device requiring a longer USB cable Package Includes ● Description This 1-ft. (0.31 m) Panel Mount USB extension cable is manufactured using USB2.0 cable. It features a panel mount connector that allows you to secure a USB B female port in a fixed location, for custom solutions such as an internally mounted drive. It is designed for use with USB 2.0 devices, but is backwards compatible and can also be used with USB 1.1. Made with superior foil shielding for reliable error-free data communications. The cable is manufactured with molded connectors and integral strain relief for extra durability and long life. Features ● Add a fixed USB B female port to a custom solution, such as an internally mounted drive ● Data transfer rates (1.5 to 480 Mbps) for low speed and high speed devices ● Premium double-shielded cables with tinned copper braid and aluminum Mylar foil feature twisted 28/20 AWG data lines Specifications OVERVIEW UPC Code 037332178473 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black Cable Length (ft.) 1 Cable Length (m) 0.30 1/2 U025-001-PM 1-ft. (0.31 m) Panel Mount USB 2.0 Extension Cable (USB B M/F) Slot or Hole Mount Measurement (Center to Center) 30mm Shipping Dimensions (hwd / in.) 0.25 x 1.00 x 6.00 Shipping Dimensions (hwd / cm) 0.64 x 2.54 x 15.24 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB B (MALE) Side B - Connector 1 USB B (FEMALE) - PANEL MOUNT STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U025-001-PM 价格&库存
很抱歉,暂时无法提供与“U025-001-PM”相匹配的价格&库存,您可以联系我们找货
U025-001-PM
  • 1+91.506231+11.86095
