UR05C-003-RARB
UR05C-003-RARB
    TRIPPLITE
    USBCABLE
UR05C-003-RARB 数据手册
This USB-A to USB Micro-B cable is designed for charging only. It will not transfer data. Micro USB Cable for Charging (M/M) - Reversible Left/Right USB-A to Right-Angle USB Micro-B, Black, 3 ft. (0.91 m) Highlights ● Left/right and right-angle plugs ideal for connecting equipment in tight spaces, such as behind furniture or flush against walls ● Dedicated USB-A to USB MicroB cable charges devices only and does not transfer data ● 20 AWG power lines allow rapid charging of compatible devices, including smartphones and tablets MODEL NUMBER: UR05C-003-RARB System Requirements ● USB Micro-B devices, including smartphones and tablets Package Includes ● USB-A to USB Micro-B charge cable keeps your smartphone, tablet and other compatible device at capacity. Description This 3-ft. (0.91 m) USB 2.0 cable (M/M) with 20 AWG power lines is dedicated to charging compatible mobile devices, including smartphones and tablets. The reversible left/right USB-A connector and the right-angle USB Micro-B connector help you connect in areas where space is at a premium, such as behind furniture. The angled male plugs reduce stress and help the cable move freely without cracking or breaking loose from the connector. Note: the UR05C-003-RARB is a charging cable only and is incapable of transferring data. Features ● Dedicated charging USB-A to USB Micro-B cable does not transfer data ● Made from 20 AWG power lines for rapid charging of compatible devices, including smartphones and tablets ● Left/right and right-angle male plugs excellent for connecting equipment in tight spaces, such as behind furniture Specifications OVERVIEW UPC Code 037332188076 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL 1/2 USB-A to USB Micro-B Charge Cable (M/M), Black, 3 ft. Cable Jacket Color Black Cable Length (ft.) 3 Cable Length (m) 0.91 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 MICRO-USB B (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR05C-003-RARB 价格&库存
很抱歉,暂时无法提供与“UR05C-003-RARB”相匹配的价格&库存,您可以联系我们找货
UR05C-003-RARB
  • 1+40.991261+5.14024
库存:2
