UR022-003
UR022-003
    TRIPPLITE
    UR022-003
UR022-003 数据手册
Universal Reversible USB 2.0 Cable (Reversible A to B M/M), 3 ft. (0.91 m) MODEL NUMBER: UR022-003 Highlights ● 3-ft. (0.91 m), USB 2.0, A/B Peripheral device cable ● Universal, Reversible "A" connector allows plugging in any direction System Requirements ● Any USB device requiring a USB cable ● USB2.0 performance only when used with USB2.0 device and USB2.0 controller Package Includes ● Reversible USB "A" connector plugs in any direction Description Tripp Lite's UR022-003, 3-ft. (0.91 m) USB2.0 A/B device cable, with Universal / Reversible "A" connector, meets or exceeds USB 2.0 specifications. No guessing on how to plug into the Computer or Hub port... Connects in either direction. Backward compatible - can be used with older USB1.1 applications as well. All Tripp Lite USB 2.0 cabling include superior foil shielding for reliable, error-free data communications. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) make them perfect for multimedia applications. Features nickel plated connectors and gold plated copper contacts for superior conductivity. The cable is manufactured with molded connectors and integral strain relief for extra durability and long life. Features ● 3-ft. (0.91 m), USB 2.0 A-Male to B-Male, with Universal / Reversible "A" connector ● USB 2.0 compliant, to 480Mbps transfer rates ● Backward compatible with previous USB generations ● Gold plated contacts and molded ends provide a lifetime of use ● 28AWG Data Pair, 24AWG Power pair Specifications OVERVIEW UPC Code 037332179432 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black 1/2 Universal Reversible USB 2.0 AMale to B-Male Device Cable 3-ft. (0.91 m) Cable Length (ft.) 3 Cable Length (m) 0.91 Shipping Dimensions (hwd / in.) 0.25 x 4.80 x 7.00 Shipping Dimensions (hwd / cm) 0.64 x 12.19 x 17.78 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 USB B (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR022-003 价格&库存
很抱歉,暂时无法提供与“UR022-003”相匹配的价格&库存,您可以联系我们找货
