U042-025
U042-025
    TRIPPLITE
    USB 2.0 CABLE A MALE B MALE 25'
U042-025 数据手册
USB 2.0 A to B Active Repeater Cable (M/M), 25 ft. (7.62 m) MODEL NUMBER: U042-025 Highlights ● 25-ft. (7.62 m) USB A-B Active Cable ● Overcomes the 5-meter USB barrier ● Built-in repeater maintains highspeed USB 2.0 signal quality System Requirements ● A USB 2.0 port and USB 2.0 device (with type B jack) are required to meet USB 2.0 speeds. A USB 1.1 port and/or device can be used, but you will not be able to achieve USB 2.0 speeds. ● The U042-025 provides up to 150mA of power to the connected device. If your device requires more than 150mA of power, it will either need to have its own power supply; or, to be plugged into a powered USB 2.0 hub (such as U222-007-R) that is connected to the U042-025. Locate a printer or other USB peripheral 25-ft. from your computer. Description Tripp Lite's High-Speed USB 2.0 Active A-B cable overcomes the 5-meter USB distance limitation with an active repeater in the middle of the cable. Now USB printers and other devices can be located up to 25-ft. (7.62 m) away from the computer in a single, non-daisychainable run, with no need for extension cables. Full 480Mbps speed is maintained along the entire length of the cable. Backward compatible to USB 1.1. Plug-and-play, Windows and MAC compatible. The U042-025 provides up to 150mA of power to the connected device. If your device requires more than 150mA of power, it will either need to have its own power supply; or, to be plugged into a powered USB 2.0 hub (such as U222-007-R) that is connected to the U042-025. Features ● Connect a computer to a printer or other USB device up to 25-ft. (7.62 m) away ● High-Speed USB 2.0 and USB 1.1 compatible ● Active repeater maintains 480Mbps signal integrity ● USB "A" to USB "B" connections ● Windows 98/ME/2000/XP/Vista/WIN7/8/10 and MAC compatible ● Cable length: 25-ft. (7.62 m) Weight: 1 lb. (0.6 kgs) ● Repeater Pod dimension: 16.75 x 57.3 x 31.7 (mm.) / 0.7 x 2.3 x 1.3 (in.) ● The U042-025 provides up to 150mA of power to the connected device. If your device requires more than 150mA of power, it will either need to have its own power supply; or, to be plugged into a powered USB 2.0 hub (such as U222-007-R) that is connected to the U042-025. Specifications OVERVIEW UPC Code 037332176622 Technology USB 2.0 (High Speed) 1/2 Package Includes ● 25-ft. (7.62 m) Hi-Speed USB 2.0 Active Cable USB Cable Type Active PHYSICAL Cable Jacket Color Black Cable Length (ft.) 25 Cable Length (m) 7.62 Shipping Dimensions (hwd / in.) 7.10 x 10.00 x 0.10 Shipping Dimensions (hwd / cm) 18.03 x 25.40 x 0.25 Shipping Weight (lbs.) 0.55 Shipping Weight (kg) 0.25 CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB B (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U042-025 价格&库存
很抱歉,暂时无法提供与“U042-025”相匹配的价格&库存,您可以联系我们找货
U042-025
  • 1+356.539631+46.12385
