UR020-006-RA
UR020-006-RA
    TRIPPLITE
    UR020-006-RA
UR020-006-RA 数据手册
Universal Reversible USB 2.0 Cable (Right/LeftAngle Reversible A to Reversible A M/M), 6 ft. (1.83 m) Highlights ● 6-ft. (1.83 m), USB 2.0, Right / Left Angle Male-to- Straight Male ● Universal, Reversible connector allows plugging in any direction MODEL NUMBER: UR020-006-RA System Requirements ● Computer with USB A-Female port ● USB device or Patch port with USB A-Female port Package Includes ● Reversible USB connector plugs in any direction Features ● 6ft USB 2.0 Right / Left Angle Male-to-Straight Male, with Universal / Reversible connectors ● USB 2.0 compliant, to 480Mbps transfer rates ● Backward compatible with previous USB generations ● Gold contacts and molded ends provide a lifetime of use Specifications OVERVIEW UPC Code 037332179425 Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Black Cable Length (ft.) 3 Cable Length (m) 0.91 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.13 1/2 6-ft. (1.83 m), USB 2.0, Right / Left Angle Male-to-Straight Male Universal / Reversible Cable Shipping Weight (kg) 0.06 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 REVERSIBLE USB A (MALE) Side B - Connector 1 REVERSIBLE USB A (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
UR020-006-RA
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
UR020-006-RA 价格&库存
很抱歉,暂时无法提供与“UR020-006-RA”相匹配的价格&库存,您可以联系我们找货
