USB 2.0 Extension Cable (A M/F) 16 ft. (4.88 m)
Highlights
Extend distances of USB 2.0
cables with this extension cable
Supports faster data transfer
rates (1.5 to 480 Mbps) for low
speed and high speed devices,
especially multimedia
applications
Premium double-shielded
cables with aluminum braid and
aluminum mylar foil feature
twisted 28/24 AWG data lines
Gold plated connectors provide
superior conductivity
MODEL NUMBER: U024-016
System Requirements
Any device requiring a longer
USB cable
Package Includes
Description
This 16-ft. (4.88 m) USB gold extension cable is manufactured using USB2.0 cable. It is designed
specifically for use with USB 2.0 A/B device cables. This cable is backwards compatible and can also be
used with the older USB 1.1 cables. Made with superior foil shielding for reliable error-free data
communications. Features gold plated connectors and gold plated copper contacts for superior
conductivity. The cable is manufactured with molded connectors and integral strain relief for extra
durability and long life. The significantly faster data transfer rates of USB 2.0 (up to 480 Mbps) makes it
perfect for multimedia applications.
Features
Supports faster data transfer rates (1.5 to 480 Mbps) for low speed and high speed devices including
Premium double-shielded cables with aluminum braid and aluminum Mylar foil feature twisted 28/24
AWG data lines
Gold plated connectors provide superior conductivity
Extend distances of the fast USB 2.0 with this extension cable
Specifications
OVERVIEW
UPC Code
037332176677
Technology
USB 2.0 (High Speed)
USB Cable Type
Passive
PHYSICAL
Cable Jacket Color
Black
1/2
16-ft USB 2.0 Gold Extension
Cable (USB A M/F)
Cable Length (ft.)
16
Cable Length (m)
4.88
Shipping Dimensions (hwd / in.)
7.00 x 9.00 x 0.50
Shipping Dimensions (hwd / cm)
17.78 x 22.86 x 1.27
Shipping Weight (lbs.)
0.40
Shipping Weight (kg)
0.18
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
0% to 87% RH, Non-Condensing
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
USB A (FEMALE)
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U024-016”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+95.999261+12.42007
- 10+81.5721110+10.55353
- 25+76.4629125+9.89252
- 50+72.8121450+9.42020
- 100+69.33827100+8.97076
- 250+64.99906250+8.40937
- 500+61.89933500+8.00833
- 1000+58.948401000+7.62655
