U038-003
U038-003
    TRIPPLITE
    U038-003
U038-003 数据手册
USB-A to USB-C Cable, USB 2.0, (M/M), 3 ft. (0.91 m) MODEL NUMBER: U038-003 Highlights ● 3-ft. (0.91 m) USB 2.0 A to USB Type-C (USB-C) device cable ● USB Type-C connector is reversible, so there is no guessing on which way to plug it in System Requirements ● A device with a USB Type-C (USB-C) connector ● A USB charger, or a laptop, ultrabook or computer with an available USB A port Package Includes ● Connect devices with a USB Type-C (USB-C) connector to a USB Charger, or the USB port on your laptop, ultrabook or computer Description Tripp Lite's U038-003 3-ft. (0.91 m) USB 2.0 A to USB Type-C (USB-C) device cable connects devices with a USB Type-C connector to a USB Charger, or the USB port on your laptop, ultrabook or computer. The USB Type-C connector is reversible, so there is no guessing on which way to plug it in...it connects in either direction! Backward compatible - can be used with older USB1.1 applications as well. All Tripp Lite USB 2.0 cabling include superior foil shielding for reliable, error-free data communications. Features nickel plated connectors and gold plated copper contacts for superior conductivity. The cable is manufactured with molded connectors and integral strain relief for extra durability and long life. Features ● 3-ft. (0.91 m) USB 2.0 A to USB Type-C (USB-C) device cable ● Connect devices with a USB Type-C connector to a USB Charger, or the USB port on your laptop, ultrabook, or computer ● USB Type-C connector is reversible, so there is no guessing on which way to plug it in.....it connects in either direction! ● Supports USB 2.0 data transfer rates up to 480Mbps ● Backward compatible with previous USB generations ● Gold plated contacts and molded ends provide a lifetime of use ● 30AWG Data Pair / 24AWG Power pair Specifications OVERVIEW UPC Code 037332188564 Technology USB 2.0 (High Speed) USB Cable Type Passive 1/2 USB 2.0 A Male to USB Type-C (USB-C) Male Device Cable - 3ft. (0.91 m) PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.0MM Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.08 Shipping Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 14 to 140 F (-10 to 60 C) Storage Temperature Range -4 to 185 F (-20 to 85 C) Relative Humidity 10% to 85% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB C (MALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U038-003 价格&库存
很抱歉,暂时无法提供与“U038-003”相匹配的价格&库存,您可以联系我们找货
